Question about Acer Aspire™ T180 PC Desktop
Dvd drive doesn't recognize discs
The drive hasn't worked since day 1, but I've been slow to address this. I tried swapping in a different drive, but that didn't work either. The computer recognizes the drive, but clicking and trying to read the disc will freeze the computer. Any idea what might be causing this? Thanks
  • 2 more comments
  • cheese-eater May 30, 2008
    by the bye, this is running vista.
    "So I'm assuming that the drive that was swapped was also verified as working and that when you swapped it you matched the jumper settings."
    Yes, confirmed.
    "Lastly but not specifically specified the age of the drive some drives cannot read dvd-r or dvd+r disks."
    This one should (computer is relatively new), but more importantly, it doesn't read any discs (cd, cd-r, dvd-/+r, etc.)
    I appreciate the response
  • Chuck Munger May 11, 2010
    Try a known bootable CD and enable boot from CD in BIOS see if that works, if it does good, also you could try switching IDE controllers on the MB assuming that its an IDE Burner and not a SATA, if the bootable disk now reads but the HDD won't boot once again that would assume the HDD's are IDE and not SATA possibly unlikely considering you said the machine is newer but worth a a shot anyway to check. lastly assuming you have another machine can try that drive in another machine jumpered accordingly and see what results if it doesn't work then you have a bad drive.
    So I'm assuming that the drive that was swapped was also verified as working and that when you swapped it you matched the jumper settings. Lastly but not specifically specified the age of the drive some drives cannot read dvd-r or dvd+r disks.
  • 458 Answers
Check your BIOS settings. I have seen some new BIOS settings have the IDE or SATA settings turned off. To get into the BIOS hit DEL or one of the F keys to get into the BIOS.
Also since this is VISTA, are you the computer administrator? Make sure that everything that could stop you is turned off. VISTA is known for blocking users from doing things on their computer even when they are the administrator. Go through all of the Settings and make sure that everything is turned off, and then if it works correctly, turn them back on 1 at a time to see which one stopped it from working. Ignore VISTA when it tells you that something is turned off. This is a problem that I do not like in VISTA.
Posted on May 30, 2008
  • T&N Family Electronics Dean and Sherrie Terrell
    The site e-mail was down for a few day's and I did not get your reply.
    Can you please let me know if this solved your problem?
    Rate this as a fixya if your problem is solved please.
    If you need more help let me know.
Samsung DVD-R4000 not recognizing DVD-R discs
As a last resort you can try a firmware update if there is one but don't hold your breath. Unit may simply have lost ability to record and not be able to playback. Not uncommon - happens.
Sep 14, 2017 | Samsung DVD-R4000 DVD Recorder
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
I have a samsung external dvd writer, now i've got a problem because it can not be recognized anymore when i insert it into my pc. what is the main cause of this problem and how to fix it? can you give...
Try to plug it to other USB port of your PC I recommend you plug it at the USB port at the back of your CPU..If this doesn't solve the problem try to clean your DVD drive lenses with a DVD cleaning disc..Still if this doesn't solve the problem perhaps you'll need to contact a technician or for worse buy a new external DVD..Hope it will help you..
Jul 11, 2011 | Samsung 20x External Double-Layer DVD...
Dvd player is not working
Put a disc in the player and note it's position. Close and let it start loading. If it doesn't load, eject the DVD and note it's position. If it hasn't moved iit could be either a broken belt or the drive motor I think> _/)***
Feb 16, 2011 | Samsung DVD-V5500 DVD Player/VCR
Disc drive stopped recognizing discs
This is fairly common, it means the actual DVD drive has failed. You will need to call Nintendo. There is a good chance it is still under warranty and they will fix it for free. Their number is 1-800-255-3700
Aug 08, 2009 | Nintendo Wii Console
Disc consistency, dvd player not recognizing discs
Your cd/dvd drive is most likely failed. Possible controller problem but most likely dvd drive. Replacement is fairly straight forward but replacement may be a bit costly. I would search for sources for used / refurbished drives; contact me if I can assist you further.
Dec 24, 2008 | Gateway MX6448 Notebook
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Dell Cd/Dvd burner not working properly
I have a Dell XPS 400 that's about 3 years old. I have a DVD reader and a DVD-RW device. The former works - the latter takes forever to read discs (particularly DVD data discs.)
I'm starting to think some of the generic DVD-RW devices Dell uses in its computers are prone to early failure. The DVD-RW in my XPS-400 was called "HL-DT-ST DVD+-RW GSA-H21N".
I'm going to try cleaning it, and then just swap it out for a better device.
Jul 03, 2007 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
Acer Aspire™ T180 PC Desktop Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
