Question about Dymo LabelWriter 400 Thermal Printer
Changed label but now 1/2 the printout runs off label
  • 50 Answers
You have to register the roll to the top edge and hit the zero function or top of page reset. try advance paper with machine off and turn on
Posted on Oct 10, 2010
Zebra ZM400 drops interface on port 515
make sure you have no network traffic for your printer and decrease the printing speed, and make sure you are using a free port not a used and default port for the service..
Jul 20, 2014 | Zebra ZM400 Thermal Label Printer -...
Hi , I have a problem with zebra 105sl printer , everytime i print somthing i have to make changes to the settings , eg. make it darker .When i save the settings permenent next time i go tto print i have...
The settings in the printer driver are overriding the saved printer settings.
Do this:
1. Correct the printer settings and save them permanently.
2. Print saved configuration for future reference and to see if it changes.(Power on while holding cancel)
3. Print a label from computer.
4. Print configuration again (Power on while holding cancel).
5. Compare the 1st and 2nd printouts. If they are different then the printer driver is changing the printer settings. In other words the printer settings and the driver are different and the driver settings will override the printer settings before printing.
6. Change the driver settings and this won't happen. Increase the darkness setting in the driver.
Aug 13, 2011 | Zebra 105SL Thermal Label Printer
Zebra S400 does not keep the calibration settings. After calibrating or restoring factory settings (like described in the manual) first label prints OK (using BarTender software) then it's off again. Same...
After you calibrate the printer. Press feed a few times. If it feeds a single label each time, then the calibration was successful.Power off and on while holding the cancel button. (config printout). Keep config for reference. Send label print from computer. If it does not work, then check that the printer driver matches the config printout. The computer printer driver will change and overide the settings in the printer
Apr 29, 2011 | Zebra Stripe S400 Label Printer
Please i need help urgently when i print label the printout is blank at least 50 label after that print label
Are you just sending a one label job? if so its seems like you have a sensor issue. Try recalibrating it.
Mar 15, 2011 | Zebra LP 2844 Thermal Printer
Hp designjet 500 (42'')
1. remove your catridge
2. remove or change the foam which is located
at the bottom of catridge head
3. hope this will help you to solve your problem
thanks
Jun 16, 2009 | Office Equipment & Supplies
LABELWRITER RUNS THROUGH TOO MANY BLANK LABELS
Merely reboot software and then roll unused labels back on machine. That works for me.
Jun 04, 2009 | Dymo LabelWriter Thermal Printer
Mis align printout
hi, its hard to say but.... does it feed ok or skip labels??? if it skips labels, the sensor will need replacement or adjustment, also download the latest drivers, and if your driver or software gives u the option, play around with the magnification settings, also double check length, borders etc, try making the label length setting appear longer , shorter etc. Hope this is of help to you,M,
Feb 12, 2009 | Intermec EasyCoder PM4i Printer
Printer = Zebra TLP 2844-Z Problem = will not calibrate
just switch off the printer ,and then hold the green button power on the printer now and wait upto 4 bliknks of green led then remove the fingers.now printer will calibrate the label..
if still the problem exist .check the notch in the ribbon core.an adjust the spring tenson of rippon supply and take of roolers in printer
Dec 04, 2008 | Zebra 110Xi III Plus Thermal Printer
CD/DVD Labels
To answer your question accurately, we'll need the manufacturer and the style or product number of the labels you purchased. If they're Avery, or other popular brand, you should be able to use Microsoft Word or Microsoft Works templates which are provided online for free. At the very least, you should be able to (using printout on blank paper as a template) maneuver the label design to fit within the area that your labels occupy and then when you print onto the labels you'll see even more accurately how to adjust future printouts (if necessary). I always do this, even when I use the Avery DesignPro software (free version from Avery). It helps me to keep from having to throw away misprints when the print runs off the edges.
Hope this will FixYa!!!
Mar 30, 2008 | Ulead DVD MovieFactory for PC
I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Oct 27, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Dymo LabelWriter 400 Thermal Printer Logo
85 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
