Question about Radio Shack VGA PC Camera Webcam
My Gigaware camera is out of focus and the settings screen did not give the ability to adjust focus. Is there something I can do?
  • 50 Answers
The bezel on the cam might change the focal point(focus) try GENTLY ROTATING IN EITHER DIRECTION
BEZEL IS THE LITTLE RING JUST OUTSIDE THE LENS
Posted on Oct 10, 2010
My samsung es80 does not make sharp pictures anymore
Difficult to go on only does not make sharp pictures anymore.
Seeing one picture says more than 1000 words. Still I give it a try.
When you are sure you did not change the focus settings and don't switch over to macro settings, while shooting normal, I can't help. But I do advice to look in the manual on page 41 and put the camera in Auto focus. (Not one of the macro modes) then when shooting, wait till the camera has focused, while you pressed the shutter realise button half. When the camera is in focus, the square in the middle of the screen becomes green, press the button down. (without moving the camera)
Also select a high resolution (big photo size) because small photo size is easy seen as a blurred picture.
Success
Feb 17, 2014 | Cameras
My canon G9 does not seem to give good focusing results. Pictures seem slightly out of focus specially with flash on Auto
Your autofocus may need to be re calibrated-- this is not something you can do on your own, but it is something that could be done at a local camera repair shop. Take it in and see if they would be able to adjust it or give you an estimate.
Mar 06, 2011 | Canon PowerShot G9 Digital Camera
My webcam is really blurry on skype and no one can see me . Help Me!!
all you can do is ensure the lens is clean without removing the bezel and manually adjusting the focus. if its less than two years old its enough reason to have acer fix it if you give them a call.
Feb 25, 2011 | Acer Crystal Eye webcam
How i take photo in night ! my problem is for clearity
I have a sample image here, I'm not sure how it will load it's a crop from a full frame.
I've read into your camera specifications and have found that 15 seconds is the longest shutter speed you can use, I didn't find a "Bulb" for shutter speed and this will limit your abilities to make clear "clarity" night photographs to work within the 15 seconds you will need to increase the ISO, increasing the ISO will introduce a grain effect and the clarity will fall off.
I'll give you a starting point some things you won't like what I'm saying but I've been doing this since 1983. You will need a sturdy tripod. Shut the IS off. See if you can focus on your subject and compose. If you can't auto focus (lack of light or contrast) switch to manual focus, focus is critical if you can't obtain this the shot will be useless. After focus compose your scene set your camera at ISO 100, manual mode F11 adjust the shutter speed to give proper exposure increase ISO by one stop and decrease F stop by one (F8) check exposure once you have the exposure recompose your scene. Make sure the camera is in manual focus, IS (image stabilization) is off, set self timer to 2 second delay, check your scene again and release the shutter and don't touch the camera again until the exposure is complete. There is a whole lot more to this and you are limited because of the lack of the bulb feature or a shutter speed greater then 15 seconds.
Sample image
Jan 07, 2011 | Canon PowerShot SX30 IS Digital Camera
With camera on the AUTO setting, I can't seem to take clear, focused photos. Nearly all of them are out of focus or blurry. Does not matter if it is in the day time or at night. Also, when using the...
Try resetting your camera back to factory defaults. Press the MENU button, select the middle tools tab and scroll down to RESET ALL. Press SET, select OK and press SET. Hope this helps.
Nov 09, 2010 | Canon PowerShot S5 IS Digital Camera
When I look through the viewfinder on my Nikon D40x it is blurry and looks out of focus, but when but after I take the picture it is clear on the lcd screen. Is there a setting I can change or is something...
Adjust view finder focus as you will see setting there, to view correct focus in view finder itself.
Camera is just fine because it is taking good focus pictures.
Oct 17, 2010 | Nikon D40x Digital Camera
I have a gigaware web camera and I'm trying to video chat but it looks like I'm blurry; How can i fix this?
This happens because its out of focus.
Usually the lens can be adjusted by turning the lens left or right.
Do this until you get satisfied with the image.
Don't forget to rate this answer if it helps
Sep 17, 2010 | Radio Shack VGA PC Camera Webcam
Blurry picture
There is a focus ring around the lens of the WEB cam turn this ring until your image becomes clear, just like a camera focus knob.
Click on the WEB cam software, you will be able to go into an options or configuration, click on video setting, you should see an image of yourself, adjust the focus until the image is clear.
Jan 01, 2009 | Radio Shack VGA PC Camera Webcam
Convergence images?
The blue picture tube of a projection tv is usually the weakest in ability to focus and in most cases loses its focus ablility before the red and green. Connect a cross-hatch generator to the rf inputs of the unit and check to see which areas are most out of convergence. The corners are usually the worst. HD will always bring out the slightest imperfections. If the unit was totally out of convergence, I would have suggested replacing the convergence IC'S.In my experience with rear projection, your problem is normal wear . You could conceivably improve the picture by adjusting the blue focus on the screen focus block. Scrivitron
Jun 15, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Focus
I suppose you really can't do much when camera is set to Auto Focus? All you do is aim and shoot? Everything is set up for you. Not so sure about limitations on manual focus. Don't you have different setting when shooting indoors? Good luck.
Sep 15, 2005 | Toshiba PDR-M700 Digital Camera
Radio Shack VGA PC Camera Webcam Logo
328 people viewed this question
Top Radio Shack Computers & Internet Experts
micky dee
Mike
Rommel Balcita
Are you a Radio Shack Computer and Internet Expert? Answer questions, earn points and help others
