Question about Garmin GPSMAP 60CSx GPS Receiver
60CS When walking unit becomes disoriented and does not know which direction it is headed, in a moving vehicle unit works great, any suggestions?
  • 3 Answers
Your electronic compass is probably turned on, and if so, either it is not calibrated or you are not holding the GPS unit level.
Try turning off the electronic compass by holding the PAGE button in for a couple seconds. With the electronic compass turned off, the GPS will instead show direction of travel using the current track, which is probably what you are expecting.
Posted on Aug 07, 2008
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Walking feet droping out.
Google for a Consew Dealer and ask them for help and offer to pay for a repair/adjustment manual. Hopefully someone will take pity on you and help.
Oct 11, 2012 | Consew 226R-1
I have a toyota fielder 2007 with 1.8 engine. its starts perfectly in the morning. but during the day when i press the button it usually takes very long to start around 8-10 seconds. or atleast i have to...
Hi Cookie, These vehicles are often fitted with the new D4 Direct injection engines. I would suggest you take it for a diagnostic scan. A very common fault on these vehicles is the high pressure unit fitted to the engine becomes defective. Another is the injectors becoming fouled. I will not be surprised if the scan shows a defective temperature sender unit which is responsible for enriching the engine fuel supply during start up. Regards John
Jun 17, 2012 | 2001 Toyota Corolla Fielder
I installed a Raymarine compass sensor in a GRP sailing boat underneath the chart table at least 50 cm away from metal and magnets. It is connected to a SP X-5 computer unit and a ST6002 autopilot...
If I were troubleshooting this, I'd manually adjust the orientation of the compass sensor until it matched the true heading. Once that was done, I'd move it side to side to ensure it's changing in the correct directions. If not, the unit could be upside down. Let me know how this turns out.
May 21, 2017 | Raymarine Fluxgate Compass Module
I am going hiking in a wilderness area. I want to use mjy garmin 255wt to get back to the trail head in case I get lost. I know that I can save my location before heading out, but what then?
OK, you know how to save your trailhead by touching your vehicle icon and saving the location. At this point you can also select GoTo to provide routing. Your standard 255WT database is for driving, so it is not going to have your trails or terrain data, but you can go to the settings, route options, and select direct rather than on-roads and it will draw a straight line to your trailhead. It is still a good idea to carry a compass & map with you, but you can get a good idea of which way you are going by walking and seeing where you are headed relavent to your course line. I like using the display set to "Track-up" for off-road, so the top of the display is the direction I am going. Some people prefer North Up, but that is disorienting for me.
Sep 30, 2010 | Garmin GPS
The GPSmap 60CSx will not acquire a satellite signal even in open water with clear skies on Lake Michigan.
I suggest trying a external antenna. This will let you know if the internal antenna connector is broken. You can also do a system reset. Back up all user data first then;
Power the unit on while holding down the Page and Enter buttons. Hold them down until you get a prompt that asks you if you want to RESET. Select yes and lets hope that works. Also doing a update may fix the unit also. To update just use the free program WebUpdater found on Garmins website. For assistance please feel free to contact GPSCity the gps experts
Jul 12, 2010 | Garmin GPSMAP 60CS GPS Receiver
I live next door to a 7-11. There are 4 Hussman
Yes, I have a solution for you/them, tell them to buy weather-proof sound curtains you can get these @ and or mcmaster-carr. these work great and are cheap........
Oct 05, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenwood head unit CD and AUX sound not working
I fixed the sound problem with tech support from Kenwood. I had the blue wire from the Kenwood which is the antennae turn on wired to the amp turn on for the vehicle (2001 Blazer with Bose factory stereo). This is how I was told to wire it from the installation tech where I purchased the wiring harness. The tuning played fine because the Bose amp turned on when I played the tuner but when I played the cd or aux the amp turned off, thus no sound. The kenwood tech toldd me to wire the blue/white wire to the amp turn on for the vehicle so the amp would be on when ever power to the Kenwood was on. I rewired this way and everything works great now.
Jun 09, 2008 | Kenwood KDC -X815
Kenwood excelon kvt-815dvd
A brain is required period. The only way to use the head unit is to have the brain. I have 3 complete 815 setups in my vehicles and they all work flawless. A brain is required. Should you want to sell your head unit, let me know
Jun 02, 2008 | Kenwood Excelon KVT815DVD Car DVD Player
AVIC-N1 GPS not working
Have you tried calibrating the sensors? And is the speed sense working, i thing the unit relies primarily on the speed sense then on GPS. You can easily tell if the speed sense is woking on the calibration screen, as you drive the unit omits a bleep.
Sep 29, 2006 | Pioneer AVIC-N1 Car DVD Player
Garmin GPSMAP 60CSx GPS Receiver Logo
119 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
