Question about Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB
My2 hp max e pro pump runs but barely moves any water
  • 310 Answers
Have you opened up the wet end? If you have pine trees near you, it is probably a blocked impeller and needs to be cleaned. If this is not the case, is the pump basket full of water or air?
If it is full of water, it is either the impeller, or the motor bearing.
if it is full of air, it is an o-ring or shaft seal. more likely the shaft seal. Always check the impeller first.
Posted on Oct 27, 2010
What is a Sta-Rite Max-E-Pro Pool Pump impeller
take off silver band clamp that will separate the motor from the wet end remove the plastic piece on the side with the motor impeller is inside check to see if glogged use a stiff piece of wire to clean out
Aug 08, 2014 | Sta Rite Max - E - Pro 1 1/2 Hp Dual Speed
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
Water barely lukewarm
is the heater running ? did u raise the temperature higher that the existing water temperature in pool ? are u running the pool pump long enough to achieve the temperature that you want ? IF CHECK (OK) 1- check the internal flow valve control is located between the cold and hot water little black cap, check the condition ,make sure no calcium deposit build inside, 2-is the water temperature in the heater is the same as the pool temperature ? is the pump got full prime with no air ? is the filter is clean ? is this heater propane or natural gas ?
Jun 12, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
How much sand do I need for 3/4 hp dura glas pump?
I would suggest 50lbs. If you filled it to capacity, it greatly reduces your water flow.
For more info, go to:
http://www.oskopoolnspa.com
Aug 13, 2012 | Sta Rite 21 Sand Filter System with 3/4 Hp...
Pump shuts off in very hot weather
might have the wrong motor on it, themotor hp and SF sevice facto determin the total HP output of the motor. so say it's a 1hp with a 1.65 sf it's a 1.65 hp motor ..the impeller detrmins the hp needed, it should have numbers and letters on it. welcome to my world fun huh
Jul 10, 2012 | Sta Rite Sta - Rite 2hp Max - E Pro...
I was told that the Aqua Flo Master Xp2 Spa pump 1.5 hp 2 speed pump was the equivalent to the Sta rite Max E Pro 2 speed pump but then from another source was told that the Aqua Flo was not made for in...
I responded to the previous question in regards to the motor only. The xp2 does not have the strainer basket that the max-e-pro has . If this was a regular hot tub, the xp2 would work great, if this is above ground, then you do need a pump with a strainer basket. Again the xp2 will not work for an inground hot tub as the set up is different than an above ground unit.
Jan 12, 2011 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
1/2hp Hayward Pump for existing inground pool
you will be fine with the 1/2hp. The Hayward will move quite a bit of water as well. It may not move as much water as the 3/4hp but it's very close and the 1/2hp will cost a little less to operate so if anything, you may just have to run it for one additional hour per day to compensate. You will be surprised how much water a 1/2hp will move. The only issue with smaller pumps is if you have pop-up cleaner heads or a suction driven automatic cleaner such as a kreepy krauly, however, if a 3/4hp will run it, a 1/2hp will run it as well. You can install a larger motor on the super pump but it will not move more water unless you upgrade the impeller as well. Just make sure you don't use a bigger impeller than what the motor is rated for because it will strain the motor and cause it to overheat. Hope this helps.
Feb 20, 2010 | Hayward SAND FILTER, PRO SERIES
Sta Rite STA-RITE IMPELLER 2HP FULLRATE & 2-1/2HP UPRATE, C105-238PEB Logo
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
Oloyede Monsuru
john h
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
