Question about RCA P52926 52" Rear Projection Television
Tv turns on and off by its self and turns chanels all the time
    Genius:
  • 1,622 Answers
Power supply board have problems,just not dead yet.Replaced the power supply board,will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Hope this helpout in solving the problem, Take care
Posted on Oct 09, 2010
When i switch off tv and turnit back i loose some of the chanels
You may or may not have a real problem with the set, using a antenna of some sort for this or what?
Dec 21, 2012 | Televison & Video
Once the tv is on for a short time it starts flipping Chanels by its self and will not stay on one chanel. what to do?
fishmill1,
Fist remove the batteries from the remote to eliminate that as the problem. Next if the problem exists replace the up/down tact switches on the TV control board. They are available at http://www.digikey.com or http://www.mouser.com . If this does not solve the problem look at replacing the tuner or the board that the tuner is on. I have a tip at http://www.fixya.com/support/r6981868-replace_circuit_board_in_modern_tvs which will help with the board change.
Thanks for using FixYa and for the great rating.
hardrocko
Jul 01, 2011 | Televison & Video
I have a Toshiba 40RV525U LCD TV. Wondering how to
if it is with hdmi input call toshiba--free software upgrade
Jul 12, 2010 | Toshiba 40RV525U 40 in. LCD TV
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
TV doens'nt start
Take to repair shop, must have a loose connection. I am an electronic Tech, 20 years experience. When you turn on a late model TV they do a self test and if they detect a problem then they shut down. I'm not really up on LG, I work for Panasonic and our LED's flash, and depending upon number of flashes it tells you where the problem is. I would suggest phoning LG for the address near you of their Authorized Service Agent. Get the guys who fix them everyday to do the job.
Cheers
Gordon.
Sep 27, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
My Sony 55" HD keeps turning off by it self
could be the remote sencer that is in the tv or bad swithes that are leaking. I have seen this happen before the sencer is a small electronic eye that picks up the signal from your remote when you push the buttons on it. The switches im talking about are small button switches that are soldered to a board right behind where you would push the power button and chanel buttons on the set itself. I would start with the switches frist if it was me. Some times you can trace the wires on the front where the switches are and unplug that set of wires and stil use the remote to turn on the set to see if it still does the same thing. The remote sencer on some models are pluged in seperate if so then this should help you to trouable shoot this problem.
Feb 28, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
BEKO TRW325 TV. Frozen on chanel 1.
I turned the TV off. I held in all of the (4) buttons on the front of the TV and turned the TV back on again....this seemed to free up the remote control access and I was able to work the TV normally. The four buttons were the channel and the volume controls.
Dec 25, 2008 | Beko 324250WN 28" TV
Sony Bravia KDL 52 keeps turning itself OFF
i had prob where my sony would switch off for a few secs thenh come back on . The solution was in menu / tv settings / sleep timer . Go into that and make sure its set to off. there are opions for off , 5 min 20 min 30 min etc... mine was set to nothing just blank.
Apr 06, 2008 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Tv philips 32pw6515 01
I can't turn on tv chanel. On the screen came LOCKED and after 5sec. switch off from self.
Jan 06, 2008 | Televison & Video
Memory issues
You may be having a problem with the a sleep timer or parental control.
Check you operators manual for some information on that.
Dec 17, 2007 | RCA P52930BL 52" Rear Projection...
RCA P52926 52" Rear Projection Television Logo
32 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
