I need my desktop computer, not wireless, to completely shut down on it's own, if not in use after one hour. Tried the power options. did not work
    Scholar:
  • 63 Answers
DID YOU TRY HIBERNATE OPTION..
if not then once again check on power option..
for more detail clarification, follow the following steps. ; )
  1. right click on your desktop.
  2. select properties.
  3. select screen saver tab.
  4. select power button.
  5. new window will pop-up..
    select hibernate tab.
  6. check on ' enable hibernate' then click on apply button.
  7. select power scheme tab.
    under it at the bottom ' system hibernates' give the time. it is minimum of 1minutes and maximum 6hrs.. or select never.
if you want another option then go for stand alone software.
to download software follow the link..
' http://www.365freesoft.com/uploadfies/download/PowerOff_Setup_EN.zip '
hope it helps you.
FEEL FREE TO ASK ANY QUESTION, ANY TIME.
Posted on Oct 09, 2010
Old Gateway system (Desktop), Celeron 800MHz. After being on for 30min to an hour, operating system quits. Monitor displays first "no input" then "power saving" and will indefinitely keep cycling between...
sounds like its an over heating issue,i would check the fans to make sure they are all working and clean.Check that the cpu has thermal paste and that it still good(if its stiff or crumbles when you take off the heatsink it needs to be replaced)also check the memory is seatted all the way in.
Sep 01, 2010 | Gateway (683728192730) Barebone
When i shut down my pc it shuts down, but the psu stays on, i can turn it off by the button but not by the desktop, any ideas???
Hi, "Sleep" mode or "standby" mode allows your computer to go on standby or sleep until you "wake" it up again. This is a power saving feature which is usually used for a few hours. You can change it to completely shut down everything (including power supply) in power supply options in your control panel. Check out your help section for sleep or standby options. Hank
Aug 27, 2010 | Dell Dimension E520 PC Desktop
Stuck dvd tray
There are many ways to eject a DVD. Try this.
Shut down the computer (complete power off, not restart)
Hold down the left button (Apple mouse?)
Push the power button
Keep holding the mouse button down until it either ejects or the grey pinwheel appears. (It's not an instant process)
Usually, eject/F12 will open the drive up. If that does not work try.
Open terminal and use the command "drutil tray eject"
You can also try command-option O + F and type"eject cd"
If none of this works your drive may be bad or the power cord is loose. You will need to open it up or seek professional service.
Oct 08, 2009 | Apple Power Mac G5 Desktop
When I shut down my computer, I think that it is shutting down completly. All lights are off indicating that it is shut down. Then a small blue window will appear and will say "Entering Power Safe Mode"....
If you are turning off your computer by pressing the front panel power button, it is probably just putting Windows to sleep but not shutting the computer off. If your computer has Windows Vista, the default is to hibernate and not shut down even if you shut down through Vista. The "power save" message you see is coming from the monitor, which is letting you know it isn't getting a signal from the computer anymore but the power is still on. Windows will start up again from sleep mode if someone or something moves the mouse or presses a key.
The solution is to make sure the computer is actually shut down. In Vista you can do this by clicking the arrow near the power icon on the Start menu. This gives you the option of shutting down instead of hibernating. In XP, shut the computer down using the start menu shutdown option instead of the computer power button. Then the power will shut down completely.
Jun 21, 2009 | HP Pavilion a810n (PP164AA) PC Desktop
Automatic one hour shut down
Hi there.
Click on the start menu and go to the control panel, select power options and there you can set the PC to never shut down.
Good luck and thanks for using FixYa!!
May 13, 2009 | Compaq Presario 5000 PC Desktop
Dell dimension 2350 pc turns off and on repeatedly
Sounds like a bad mobo. 8 years! Damn let it die already LOL..!!!
Feb 21, 2009 | Dell Dimension 2350 PC Desktop
My Dell Dimension 9200 will not power up reliabily.
what i did was myself i download I8KFanGUI, and turn my fan speed on high, now it has been working without shutting off, plus also I went into the bios and turned "speedstep" on, since i heard windows xp will use it regardless of the bios setting... that may have caused some problems itself causing a switch off. A few times though i could not start the pc, so i opened the case and snapped out the ram (not removing completely, just undoing the insert snaps on 1 side) and start the pc (might've had to unplug and replug a few times to get it to power on)... but i'm guessing i'll rarely have to do that... since i couldnt shut down the pc right 1 time it happened like that. But it is working now!
Jan 28, 2009 | Dell Dimension 9200 PC Desktop
Computer will not shut down
right click your desktop go down to properties and click on it. then go to the screen saver tab and select power. then set the times there and hit APPLY then Hit ok.
Jan 27, 2009 | Computers & Internet
Mouse will not respond at all. Have completely disconnected and then reconnected. Tried reboot. Tried hard shut down from power source. Let sit for over an hour. WILL not respond. Is it dead?
connect your mouse to another computer and if the mouse works the problem is with the motherboard take the motherboard to te chip level technition the packet resistance and capacitor is open need to replace them
May 05, 2008 | Computers & Internet
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
