Question about Swisher 52" 20 Hp Riding Lawnmower #Zt2052
Trying to take off pto clutch toro 244-h & replace bearings
Toro Wheelhorse electric PTO clutch: If the clutch is bad, will it still work randomly or will it just not work at all? I replaced the PTO switch and I do not think that it an electrical issue. TY
Before you decide that it is a bad PTO clutch, carefully follow the wires back to their termination points and see if there is a broken/cut wire or bare wire occasionally shorting to ground. Check that all connections are tight and not corroded.
Oct 04, 2017 | Toro Garden
Toro 11-32 won't start.new battery. i jump the terminals it fires right up. 2nd problem is the deck won't engage I hit the switch and nothing I leave the seat it shuts off when engaged
Check and see if the Engagement termnal on the solenoid is getting power. If it is replace the solenoid.
As for the PTO check for at its connector for voltage. If voltage is there check for about 1.7 ohms resistance across pto coil. If it reads infinity or less than 1.5 ohms replace the pto clutch assembly.
If the pto reads less than 1.5 and there is no voltage at the connector than the pto switch is probably burned up due the shorted pto.
May 14, 2015 | Toro Garden
I have a Toro LX 500 Lawn tractor the pto clutch will not engage, I have 13 volt at the plug for the clutch , so ordered and installed new clutch... Still will not engage checked volts again had 9.3
PTO Clutch will not stay engaged.
There is a very fine one page discussion on evaluating electric clutches at this site:
http://www.messicks.com/Articles/FixingElectricClutch.aspx
My JD tech manual, which covers the entire LA 100 series, agrees with the electrical specifications. It states that the Electric PTO Clutch should show the following:
  • Resistance 3.7 ohms
  • Current Draw 3.25 amps.
It does not give the air gap. It does include a note to check the PTO Clutch Key for damage or if missing. So there is a drive key between the PTO Clutch and the shaft. Additionally, it recommends checking the tightness of the cap screw. That's the screw or bolt that holds the clutch on the shaft.
  • Cap Screw torque 55 lb-ft (75 N.m).
Fixing Electric Clutches
Apr 21, 2015 | Toro Garden
Toro LX468- Was replacing belt and a small (2") spring came loose from I think the PTO ? Also the PTO clutch should be in what position to permit belt guard installation? Does the guard go into the gr
Yess it goes into the groove to prevent clutch housing from turning and the position of the housing when install the retaining bolts.
The spring into the hole on the clutch housing and other end goes somewhere on the frame. It is being used as a damper spring.
The below should be correct.
Oct 23, 2014 | Toro Garden
Toro repair manuals
I have this same problem on my 36 in toro pro line sfs i ohmed the clutch the wire the safety switches and the PTO engagement switch all checked out good if u find any thing let me know the clutch its a adjustable clutch and its supposed to be set at .018 at all three springs there will b a slot that's where u check that but. U can get a multimeter and test the clutch by putting it on ohms and hooking up on both sided of the plug once u have unplugged it.the clutch should ohm out at like .003 or .004 max if more the clutch is shorted out
May 07, 2013 | Toro 52" Cut Wide Area Walk Behind Lawn...
My cub cadet tractor starts but the pto clutch stays engeged and i cant shut it off(pto)
The clutch has it's own brearings in it. You have to replace the hole PTO.Sometimes you can find a Aftermarket PTO clutch. There usually A little cheaper.
Jul 10, 2012 | Cub Cadet Lawn Mower Electric PTO Clutch...
Just replaced pto clutch brand new ,wont engage.nothing, zip not a movement.
Check that you are getting voltage to the wires that connect to the clutch when you switch on the pto. If not check that you are getting voltage to the pto switch. If you are the pto switch is faulty. Regards Phil
Apr 15, 2011 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Toro 265-6 model 72045 PTO clutch will not engage. PTO checked with 12V and works okay. Both relays checked and working okay. All fuses are good. Not sure how to check PTO switch. Any other suggestions on...
ohm out the clutch......should be 2-4 ohms any less means the clutch has an internal short and will need to be replaced. also check the saftey interlock module, however the modle numbers u gave do not come up, relays checked ok? how did u test them?
Nov 18, 2009 | Toro Lawn Mower With Toro Power Tools
Swisher 52" 20 Hp Riding Lawnmower #Zt2052 Logo
202 people viewed this question
Top Swisher Garden Experts
lnbn1975
Jim Parker
Jim Parker
Tim Whalen
Are you a Swisher Garden Expert? Answer questions, earn points and help others
