Question about Whirlpool Duet GHW9150P Front Load Washer
Keeps stopping on the drain and spin flashing an f on the control front panel.
  • Whirlpool Master
  • 8,220 Answers
Have a quarter inch nut driver? Get that service panel of the bottom and clean the pump filter:
Manual
Posted on Oct 09, 2010
My machine a Bosch excel vario keeps displaying E18 and flashes and keeps pipping I canot get the door open tried two washes
E18 indicates a time out draining.
I'm assuming it's stopped full of water.
Put the machine on spin only and see if it empties and spins.
After that you'll need to check it over.
It's very likely there is a blockage preventing the machine draining.
It can also be a faulty pump or control board but this is less likely.
It's a lot of work but try the following.
Check the drain hose where it connects to the house drains.
If onto a connection, take the hose off and check both for a blockage.
This is normally under the sink.
If ok, you'll need to manually remove the remaining water from the machine.
Put a shallow dish in front of the filter/pump cover. (Bottom front of the machine)
Slacken the cap a little to drain the water.
If there is a draining tube, use that to empty the water.
Tighten the cap to stop the water when you need to empty the container.
(If you pull the machine out and tilt it rearward, you can get a larger container in place for a while).
Once the machine is empty of water, take the cap off.
Clean out any debris in there.
Once cleaned out, take the laundry out of the machine.
With the cap off, put the machine on spin only. (If it resets).
Listen at the open filter to see if the pump is running.
(You should see the pump impellor rotating)
If the pump isn't running, let me know.
If the pump is running, refit the cap and try the machine again.
Good Luck
Feb 16, 2015 | Bosch Washing Machines
My HE2 front load wouldn't drain & spin and was making noises below. i called Affordable Repair and they said the control panel had to be replaced for $200 + labor. i said the noise is coming from u
Hi.
The noise coming from underneath is symptom of a problem with drain pump or drain line.
The standard procedure consists in accessing the drain filter to check if it is blocked, then testing drain pump. Most of the time the noise is caused by blockage at drain filter. In some case the pump is gone.
The control panel gets replaced only after checking drain filter, testing drain pump and also after testing the water pressure switch that determines when to start or stop the pump.
Bye.
G.
Dec 08, 2011 | Kenmore HE2 Plus Front Load Washer
It keeps on pausing during the cycles, what do I do to stop that?
It sounds like your Door Switch assembly may be faulty. During the cycles, the machine thinks the door is open, so it pauses the cycle.
Can you hear the machine drain? If not, this could be a Drain Pump problem, or Drain filter problem. You will need to remove the panel to access the Drain pump at the bottom of the machine. Remove the Drain pump hoses and clear them out. Make sure your Drain pump is also clear and turns freely.
Does the machine's drum spin? If not, you may have a Motor or Motor control board problem.
Feb 28, 2011 | GE WSXH208A Front Load Washer
I START TO WASH AND A SUD APEARS AFTER 4 TO 6 MINUTES IT STARTS TO WASH THE WATER POURS INTO THE MACHINE AND IN A MINUTE AFTER IT STARTST IT STOPS ALL THE LIGHTS GO OUT AND A CODE F35 FLASHES CONSTANTLY...
The SUD display could mean several things. A faulty drain pump, excessive detergent, excessive suds, or an extra heavy load.
Open the front bottom panel and clean the drain pump filter of foreign objects. Also check the drain hose and make sure it is not clogged or kinked.
If too much detergent was used, run the unit thru a rinse/spin cycle then a normal cycle without adding any detergent.
Check the wire harness connections to the drain pump, pressure switch, and control board
Feb 21, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Front loading washer won't spin
my amana washer wont spin and does not drain
Sep 11, 2009 | Kenmore Washing Machines
HOTPOINT WASHER DRYER WD440G
That means that the machine detected a problem at a certain point of the cycle and stopped.
If the machine stops when filling check the inlet valve and the water supply.
If it stops because ofervilling check the water level switch.
If it stops when the cycle is hot water only , then check the heating element.
If it stops when draining, then inspect drain filter, drain pump , and drain hose. You access the drain hose removing a panel at the front side of the machine.
If it stops when motor is supposed to spin faster (rinse) then it is motor control unit or motor coupler.
If it is none of the above, then it is a defective control board.
Feb 16, 2009 | Hotpoint Ariston WD440G Front Load...
Stopped during rinse/spin cycle
try removing the bottom front panel and see if there is something blocking the drain.
Oct 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore he2 front load washer
remove bottom panel open pump port and ck for foreign objects lean washer toward rear wall this will help help keep water toward rear and reduce flooding floor might try opening door first and dipping out as much water as possible with bottom panel removed reach up to lock area there is a tear shaped plastic peace pull it down to release door
Jun 02, 2008 | Washing Machines
Kenmore Elite 4t
Try the diagnostic test by pressing Drain/Spin button then press the Prewash button four time within five seconds. It will start to ignitiate the sequence for the inlet valve. The cold then hot then wash  then drain then spin. Hope this will clear the brain of the machine and you are good to go.
F&H means you have a drain clogged, or bad pump or bad inlet valve or pressure switch or the worst ccu.
Oct 25, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
22 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
