Question about Canon PC-940 Black and White Copier
Please my copier canon ir2016 gives me paper jam but there's no paper in it or i can't find any paper in the mahcine
spinal
  • 287 Answers
SOURCE: canon copier iR2016
Hello iali307. All three error codes have to do with with an item called the fuser. This component, when working properly, is designed to provide extreme heat (to melt the powdered toner) and pressure (to force the melted toner onto the paper and"fuse" or bond the image to the paper. All manufacturers of all copiers make sure that this system (common to all) is intensely monitored as a building burrning down is not a maketing tool. Your copier's "fuser" can be rebuilt, but I would strongly advise the entire unit be replaced. My company (thet are tight assed) realizes the cost /benefit analysis of trying to rebuild these fusers and opts for replacing the unit. The part # is FM2-3345-000 if you live in a standard 120 v part of the world. I hope this helps,I wish you the best. :-) .......................SPINAL
Posted on Mar 04, 2008
Cogz
  • 1326 Answers
SOURCE: Canon PC 1060 error code E-002-000
A E002-000 is fixing unit error code. It is a power problem with the fixing unit. When you removed the paper jam did you see any piece of a blackish grey plastic pieces. If so you need to replace the fusing unit and or the upper fixing film..
Posted on May 11, 2008
SOURCE: Canon Pc720 Copier Paper Jam
Thanks Repairman99!
That was EXACTLY the problem with a copier my grantmother has! I was able to find the spring and the plastic "hook" that broke off!
Used a small screw to reattach it and works again!!!
Thanks so much for your post!!!
Posted on Nov 13, 2008
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
  • 149 Answers
SOURCE: MY CANON COPIER IR2016 HAS FUNCTIONAL ERROR E805...
there could be a problem with the main fan and or the dc controller could be bad.
Posted on Jun 09, 2010
Tip
Incorrect paper size while copy in progress for Canon iR2016 series.
Regarding pick-up error "change paper size"or "incorrect paper size" while copy/print:
These may do the trick:
Point of problem:
Paper Pick-Up Assembly
Problem:
Prevention of incorrect Paper Size Error or Pickup Assmbly Delay Jam (0104) upon Cassette Pick-up
Behaviour of copier:
When making a pick-up setting as from the Cassette and starting Copy, "incorrect paper size" error or pick-up delay
jam (0104) may occur.
Possible reason:
When considerable amount of Paper Lint is attached onto the Vertical Path Roller , the feeding power is
undermined and the paper feeding is delayed, resulting in "incorrect paper size" error or "pickup assembly delay"
jam.
Servicing work:
When the foregoing symptom occurs, be sure to replace the 27T/50T Gear [old type] with the 33T/50T Gear [new
type] and the 29T Gear with the new type simultaneously.
Affected machines are:
iR2016J 120V KQW00838 and later iR2020 230V KRS02060 and later
iR2016J EUR 230V KQX19105 and later iR2020i 120V SRB03779 and later
iR2016J 230V KQY08575 and later iR2020i EUR 230V SRC03634 and later
iR2016 EUR 230V KRB61503 and later iR2020i 230V SRE00245 and later
iR2016J EUR 230V TXK10815 and later iR2016i 120V SRH01205 and later
iR2016 120V KRE05112 and later iR2016i EUR 230V SRJ04494 and later
iR2016 230V KRJ07227 and later iR2016i 230V SRL00298 and later
iR2020J 230V KRM01592 and later
iR2020 EUR 230V KRP16433 and later
iR2020 120V KRR07615 and later
on Apr 12, 2011 | Office Equipment & Supplies
Load paper ltr
What size paper is already loaded in the printer?
Dec 10, 2013 | Canon iR 2016i Black and White Copier
CANNON IR2016R WHEN I START AFTER INITIALIZING IT
7.2 Detecting Jams 7.2.1 Delay Jams 7.2.1.1 Delay Jam in Pickup Assembly 0010-4883 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Delay Jam in Pickup Assembly The registration sensor cannot detect the leading edge of paper within the jam detection time interval after paper pickup started. T-7-2 7.2.1.2 Delay Jam in Delivery Assembly (Paper Leading Edge Jam at First Delivery Sensor/Wound Paper Jam at Fixing Assembly) 0011-0712 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Leading Edge Jam at First Delivery Sensor The first delivery sensor cannot detect presence of paper within the prescribed time after the registration clutch has been turned on. T-7-3 Wound Paper Jam at Fuser The first delivery sensor has detected absence of paper within the prescribed time after it detected presence of paper (within the prescribed time after the registration clutch had been turned on). T-7-4 7.2.2 Stationary Jams 7.2.2.1 Stationary Jam in Pickup Assembly 0010-4884 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Stationary Jam in Pickup Assembly The registration sensor does not detect absence of paper within the prescribed time before the next leading edge of fed paper reaches the registration sensor. T-7-5 7.2.2.2 Stationary Jam in Delivery Assembly (Paper Trailing Edge Stationary Jam at First Delivery Sensor/Stationary Jam at First Delivery Sensor) 0011-0733 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Paper Trailing Edge Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after the registration sensor has been turned off. T-7-6 Stationary Jam at First Delivery Sensor The first delivery sensor cannot detect absence of paper within the prescribed time after it has detected the leading edge of paper. T-7-7 7.2.3 Other Jams 7.2.3.1 Door Open Jam 0010-4886 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i Door Open Jam The door is opened when paper to be printed is in the paper feed path. 7.3 Cassette Pick-Up Unit 7.3.1 Overview 0010-4887 iR2016J / iR2016 / iR2020 / / iR2016i / iR2020i The paper picked up from the cassette is fed to the registration roller using the vertical path roller driven by the main motor (M204). The registration roller is not rotating when paper reaches there, so an arch is formed at the leading of the paper to prevent skewing. The DC controller PCB turns on the registration clutch (CL203) at the prescribed timing to transfer the main motor rotation to the registration roller, thus feeding the paper to the delivery tray through the transfer, sepa- Sensor/Solenoid Registration sensor (SR209) Pickup solenoid (SL202) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203) Sensor/Registration clutch First delivery sensor (SR203) Registration clutch (CL203
Jan 04, 2010 | Canon iR 2016i Black and White Copier
I am Guna from malaysia, iam having problem with canon ir 2016j copier. Its always paper jam at bypass feeder. so i notice that the bypass tray guide broken.so i need to order the parts. i dont have parts...
salut
d'abord je tien a vous dire que je suis un technichien par vraiment bien qualifie dans le domaine
des photocopieur mais j'ai une petite experience dans ce sens ainsi je suis de l'algerie alore je pouvais me contacte sur cette adresse fahimriad@yahoo.fr
riad of algeria 0773 70 28 71
Feb 23, 2009 | Canon iR 2016i Black and White Copier
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
Canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
Nov 30, 2008 | Canon CLC 1140 Copier
CANON IR2016
hi... try to clean up your copier... usually dust accumulates inside the copier that's why paper inserted will always jam....always see to it that you copier is free from dust and other small particles that would cause your machine to get errors....
Feb 27, 2008 | Canon PC-940 Black and White Copier
Canon PC-940 Black and White Copier Logo
69 people viewed this question
old marine
old marine
