Question about LG 42LC2D 42 in. LCD HDTV
I'm staying at a Hotel in Atlanta that has 42 inch LG LCD TV's and I'm trying to connect a DVD Blue Ray directly to the TV with HDMI Cable and set the TV to HDMI input setting and Nothing happens except sound.
    Scholar:
  • 143 Answers
I would call the front desk. They usually have a maintenance person who can help you with the connection. If the TV HDMI port is not functioning, they may be able to swap tv's or move you to another room! Good luck!
Posted on Oct 09, 2010
LG blue ray won't play sound from RCA sound bar. HDMI cable is hooked into HDMi slot on TV
the details you provided were very vague, however from my experience when a device is connected to another device via and audio capable hdmi cable, that device renders it audio output to the device its connected to and normally turn off all other audio outputs beside optical- I would assume there is an option in the blue ray player to turn off hdmi audio, which will in turn activate other audio outputs- you may also look for audio out port on your tv, it is ideal to connect the sound bar directly to the tv set audio out ports. To sum this up,
if you plan to use your player via hdmi cable you need to turn off hdmi audio output on the blue ray player and the plug an audio cable from your blue-ray player to your sound bar
you may also as i said connect your sound bar directly to your tv, the issue is most tv sets now a days do not have an audio out port, if you do then everything you play thru your tv will have audio via sound bar
there are several way to go here but unless your sound bar has hdmi av switching capabilities (im sure not) this is one of the most simple--Good Luck.
Jan 29, 2013 | Audio Players & Recorders
When i try to play a Blue Ray DVD, the LG LCD tv gets a swath of bright green random pixels across the middle of the screen. The player is connected by an HDMI cable. I have replaced the cable twice,...
Pickled! You did right by checking the cables, the tv inputs and as well the output on the blue ray...even by replacing the blue ray. Which leads to a problem within the tv monitor. I can only guess there is something in the software of the tv that is causing the problem. I can only suggest two options. If can connect the tv to a network via CAT5 cable, you can do a frimware update to the tv. Sort of like a software update. If it is not available, try to swap the HDMI cable for the 5 RCA component video. It will still carry HD signal, just not as crisp as the HDMI. I would be floored if the same thing happened with the component cable.
Jun 30, 2010 | LG 42LC2D 42 in. LCD HDTV
Conneted HDMI cable from PS3 to TV. Get sound but no picture
Try to connect HDMI cable to any other supported devices, i.e: cable box, dvd/blue ray, etc and see what happen. If there is no difference, replace huge interface board, not the one with tuner on it, but to the left.
Good luck.
Jan 23, 2010 | LG 42LC2D 42 in. LCD HDTV
How can I use my lg lcd tv model m1994a for my ps3 there's no video signal,I try it all inputs to my lcdtv from av cable.component video,and hdmi cable still there's no video signal,but if I'll connect to...
I solve it already my problem by connecting my ps3 to an 32 inches lcdtv and I change the videosetting to my ps3 to default setting because before when I had my sony bravia 32 inches I changed it to 1080p via HDMI cable signal...After I changed to default settings I connected it again to my own LG lcdtv 19 inches but it sadly 1080p is not so very much supported but anyway I can play now ps3 games...
Nov 21, 2009 | LG 42LC2D 42 in. LCD HDTV
I have no sound with my lg blue ray player but my lg dvd player has sound throught and i am using a hdmi cable and i have set the blue ray audio settings with a lg tech anything will help thankyou
Some times the DVD player needs to be set to output digital audio through HDMI. If that is set, then do the same with the menu options on the TV/LCD/Plasma/Screen that you are using.
Jul 25, 2009 | Kenwood VR-716 6.1 Channels Receiver
42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so  there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
Feb 15, 2009 | LG 42LG50 42 in. LCD HDTV
42 inch proscan lcd
If you use the connections for DVD you must use all of them.If you are using the standard yellow,white,and red connectors connect them to the connections listed as video and not the DVD titled connectors. But my advise is get an up converting DVD player and use a HDMI cable to get the best picture with out having to brake the bank buying a Blue Ray. I once connected a DVD player to my TV in the same fashion before finding out it only gives you a purplish black and white picture. Up converting DVD players can be bought around 30 dollars and up. A 6 ft HDMI cable will cost around 15 dollars. This way you will be getting the full effect and great picture your TV can produce.
Jan 31, 2009 | Proscan 42LA30H 42 in. LCD Television
Can not get my new 42 " Aquos TV to work with my new blue ray DVD
A blu ray player will play on any television. The television might not however have the highest resolution to display the full capability of a blue ray. That being said, the blu ray player may be faulty the connections may be incorrect. I would recommend running an HDMI cable from the A/V out on the blu ray to the HDMI input on the TV. GOod Luck
Dec 23, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Best way to connect new system
After trying several ways, we decided the best picture was to run the blue ray (out) directly to the TV (in) with an HDMI and another HDMI from the sat. box(out) to TV(in), then optical audio from TV (out) to receiver (in). This way you don't have to change channels on the reciever when switching from TV to DVD. Remember that HDMI is one cable that supports audio and video. If you are using all Samsung products and want to use one remote, using the Anynet feature, I think it has to be connected with an HDMI. I'm going to try connecting an HDMI too from the reciever to the TV to see if this feature will work. It does with the Blue Ray.
Nov 21, 2008 | Samsung HT-AS720ST Theater System
LG 42LC2D 42 in. LCD HDTV Logo
206 people viewed this question
Computer Repairing
Computer Repairing
