Question about Samsung LE40R73BD 40 in. HD-Ready LCD Television
It won't switch on! The stand by light just keeps flash in every few seconds, it had been taking a few seconds to come on the last 3 or 4 times iv switched it on and now it doesn't come on at all
    Scholar:
  • 143 Answers
The power supply may be bad. Sometimes, it's just a capacitor or two that needs to be replaced. Take it in for service if you don't know how to check the board yourself. Good luck!
Posted on Oct 09, 2010
Sony fd trinitron colour television kv 29ls60e
The power supply probably is failing.
Jan 10, 2014 | Televison & Video
Panasonic viera problems
The internal power supply is failing
Jun 15, 2013 | Televison & Video
I HAVE A BUSH LED22982DVDFHDS THAT WON'T TURN ON STAND BY LIGHT KEEPS FLASHING
Flashing of standby light are fault indications, technically called blinking codes. From the number of flashes that occur at one time switch ON, you can get an idea about the faulty circuit section inside it. If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2300 posts now. All are related to electronic equipment repair help. Search the site by 'Timeslide' option. It will make search easy. Or, type in the brand name to your device into its search box, and press "Enter"
Blinking codes to many brand TVs are described in detail.
Apr 21, 2013 | Bush Televison & Video
I have sony lcd hd ready 50inch rear projector tv model number KDF-E50A12U tv comes on after couple minuets tv clicks off to stand by then red light in stand by flashs 3 times gos back to green repets
Hello
Three blinks of standby light to Sony TVs indicates that the regulated voltage output from power regulator board is above thatn normal. The problem is with its power supply regulator board. Replace all the electrolytic cpacitors on that board with new ones. Replace all of them including small and large ones, at one time. OK.
Feb 04, 2012 | Televison & Video
Logitech m205 won't work, the light keeps blinking
If your unit is a wireless keyboard only, then there is a button on the bottom of the keyboard and another on the receiver that is plugged into the usb port of the computer. In order to calibrate the system when it looses its signal, you have to press and hold both buttons down at the same time for 30 to 45 seconds. That means press the button the receiver and the button on the bottom of the keyboard at the same time and hold them down for 30 to 45 seconds. This will revive the signal and bring it back to working condition.
If your unit is a wireless mouse and wireless keyboard then there are probably 3 buttons involved that need to be pressed and held for 30 to 45 seconds at the same time. One button on the mouse, one on the keyboard and the last on the receiver.
If you press and hold the buttons down as explained above, it will correct the problem.
Jul 17, 2011 | Logitech Computers & Internet
MY MONITOR APPEARS FLASH WHITE LIGHT FOR A SECOND AFTER I SWITCH OFF THE SWITCH
there may b three major reasons behind..
1) a hallucination often created to eyes..
2) due to high voltage present, it keeps/holds the last raster for some time..time lasts till discharging..
3) this may b a case of crt detoriation..!!
always better to seek professional advise of ur system admin/vendor....
Jan 16, 2010 | Samsung Syncmaster 2033SW Monitor
Ps3 turns on for a few seconds bleeps then turns back off and the red light flashes any ideas
Red light on the PlayStation three can mean lots of things it could mean a hardware failure an overheating problem or software problem
if its over heating try moving the ps3 away from cramp areas and try to keep the vent from being covered if its a hard drive problem or it might be corrupted my other recommendation is and that's if you don't want to take it to sony is a hard reset warning doing a hard reset all data will be lost and the ps3 will be returned to factor defaults please not iv warned you if you feel iffy about it don't do it
Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
but this all I can think of the might solve your problem
Jul 29, 2009 | Sony Playstation 3 (PS3) Console
My sony trinitro wont turn on, the stand by light flashes 4 times
the four flash is a signal, it means either faulty power supply or deflection circuit trouble.
Jul 27, 2009 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Samsung LE40R73BD 40 in. HD-Ready LCD Television Logo
Jerry Greenberg
Jerry Greenberg
