Question about Teac PD-H570 7-Disc CD Changer
Teac PD H570 Multi Disc player - when turning on the power an ERR message and the number 1 disc light is flashing. No response to any buttons or the remote. Powering on and off makes no change. Would be grateful for any help and advice. Thank you.
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Teac PD-1200 Compact Multi Disc Player
Hi
I think that we can get at least one of them going again :)
I suggest
  1. take the lids off both of them.
  2. load up some Cd's and close the drawer and watch what happens.
  3. does the disc begin to spin, is not, do you hear any noise as it tries to read each disc.
  4. can you kick start the CD when it first loads(clockwise direction)
  5. if not of these things happen, can you see if the transport loads the cd up off the tray.
While you are in there, with the front drawer open you should be able to see the laser lens. Use a cotton bud moistened with windex(glass cleaner) gently clean the lens in a circular motion and then also polish it with a dry one to be sure you have left no smears on the lens. Then.... try the unit again and see if the CD reads.
If you don't have any luck this far, please post back to me and we can try some other things. All this and you give me a FixYa... YAY :)
regards
robotek
Posted on Jul 07, 2008
localwonder
  • 6784 Answers
This is a faulty loading motor. you will need to replace the entire optical lens assembly in this case. the motor is part of the assembly.
Posted on May 29, 2009
taran_2005
  • 10515 Answers
SOURCE: I turned on my TEAC
Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminum cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should then be OK. If it has been forced, the aluminum cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
Thank you - worked great. I would only add that need to unplug and let it reset after clearing the jammed plastics
Posted on May 22, 2016
After 16 months our PD-D2610 CD changer has started misbehaving. Some of the 5 positions work fine but positions 1 & 4 almost never work.
I read enough comments from unhappy TEAC owners with similar problems to learn that the drive motor is to blame and that repair sounds like sending good money after bad. I'm going to buy a Sony changer.
Nov 18, 2009 | Teac PD-D2610 5-Disc CD Changer / Player
Teac PD-D880 5-CD changer Disc Skip
The belt for the carousel has snapped and the noise is the gears continously turning and not being caught by the belt.
Oct 27, 2009 | Teac Audio Players & Recorders
May 29, 2009 | Teac CD-P1120 CD Player
Hi
I suggest
regards
robotek
Jul 04, 2008 | Teac CD-P1120 CD Player
Getting ERR message on CD Player
My kids always cause this one ! Switch off power, remove cover. Remove four screws holding top black plastic disc cover and then remove all of the black plastic ( x 7 ) disc holders. You may find that the aluminium cross structure has come adrift. Replace into the slots again and replace all the disc holders. If you want, you can check before replacing cover, by then ejecting and 'disc skipping'. It should thne be ok. If it has been forced, the aluminium cross structure thing may have also come out of the slot it should in in on the right hand side. Slide the disc frame in or out until it can be fitted and retest.
Jan 14, 2008 | Teac PD-H570 7-Disc CD Changer
"Err" message
i had err 2 screen. removed case (about 10 screws, took just a few minutes) and found 1 disc was had been knocked out of the tray. removed all discs. replaced case. works fine again
Dec 29, 2007 | Denon DCM-280 5-Disc CD Changer
TEAC PD-D2681
hi door cant be fix without a pro(bad chip) take a can of compressed air with a narrow hose find the laser eye with light and clear it good luck
Dec 14, 2005 | Teac PD-D2681 5-Disc CD Changer
Teac PD-H570 7-Disc CD Changer Logo
149 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
