Question about Electrolux Dryers
Electrolux dryer has code of E63 - Electrolux Dryers
  • lexi6189 Oct 09, 2010
    What does E63 on my electrolux dryer mean?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 09, 2010
  • Rylee Smith
    Rylee Smith Oct 09, 2010
    Just told you what it means and you still want to know...strange.
  • 8,197 Answers
The error code E63 is a high temperature warning
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
Good Luck and please accept the answer
3 Suggested Answers
richroth
  • 9472 Answers
SOURCE: What is Electrolux Dryer Code
Error E63 in your Electrolux Dryer indicates that the temperature inside is too hot/overheating, to start with, check the vent and try to clean it. If still it's not resolved then the issue is with the thermal fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel.
Posted on Jan 15, 2011
SOURCE: electrolux dryer error code e63
E63 is .....Heater to Earth Ground
Heating element or wiring defective
Check heater coils and connections for short circuits to the cabinet. Replace
heater and/or wiring and retest... Regards
Posted on Dec 05, 2011
Electrolux
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
May 01, 2013 | Frigidaire Electric Dryer
Electrolux dryer will not start code E-63 appears on the screen
Hi boltonjamese...
E63 error code means that your dryer thinks the temperature is too hot.
If your unit is still under warranty they should fix it under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board.
Please take time to rate me
Sep 24, 2011 | Electrolux Dryers
E63 code
E63 is for a open heating circuit. could be a problem with the heating element or a sensor gone bad. Check to see if your dryer is under warranty. If it is I suggest you have the manufacturer take care of the problem. If not let me know, and we'll start by checking the heating element.
Feb 23, 2011 | Electrolux EIED55I Dryer
What is Electrolux Dryer Code E63
Jan 15, 2011 | Electrolux EIED55H Dryer
Im getting the E63 error code,what does this mean and can I fix it myself ??? Any advice is greatly appreciated. Thanks, ...
The error code E63 is a high temperature warning:
Oct 21, 2010 | Electrolux EIED55H Dryer
What doe error code E63 refer to? thanks
"E63" error code means that your dryer thinks the temperature is too hot. Most of these units should still be under warranty so I would highly recommend calling warranty to correct this issue as any problem to fix this will involve replacing a sensor or a control board which involves high risky things to be done. So its safe to reach the company service technician to fix this issue.
Thank you!!
Jun 01, 2010 | Electrolux EIED55I Dryer
Electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
Jan 02, 2010 | Electrolux Dryers
Dryer shows E63 error code? What is it? Should I call service?
Apr 11, 2009 | Electrolux EIED55H Dryer
Dryers Logo
1,815 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
