Question about Refrigerators
It wont get cold anymore. I have only had it for about 10 months. ran fine and now...not good.
  • Refrigerators Master
  • 8,220 Answers
Might be a defrost issue. Look for frost building on the service panel. A sure sign of a fail defrost. The most common part to die is the defrost termination thermostat. It wont get cold anymore. - 8d4e933.jpg
Note: If it turns out NOT to be a defrost problem then look for a failed evap motor. Or dirty condenser coils. Air restrictions play a huge factor in cooling.
Does it need gas? I doubt it. I have a lot of service manuals at my foggy blog and my sublime blog.
type bottom mount in the search box after you get to them sights.
Posted on Oct 09, 2010
Car wont start. took a fuel injector out and put the same one right back in and it ran for 2 days fine now wont start again, what is the problem?
A possible fuel pump pressure issue. You will need to have a garage check the fuel line pressure. The engine requires more fuel on cold start and a failing pump may not be able to cope with supply. This may also be apparent at high revs, but not as apparent as cold start.
Oct 30, 2012 | 1996 Chrysler LHS
My bike wont stay running
What kind of bike is it? If it's a moped i would recommend to clean your carb. Also shaking the fuel tank should help.
Jul 27, 2012 | kawasaki Ninja ZX6 R Motorcycles
Code E4 on dandy wine cooler mod # dwc283bls
We had that problem in 2007, about 10 months after buying it from Costco. It was under warranty so the tech came and changed both sensors. It's worked fine until Feb 11. Now, the lower section ran so cold it froze some bottles. I am looking for a solution to that problem.
Feb 18, 2011 | Danby DWC283BLS Wine Cooler
My car wont crank its turning over but wont fire i cant here the fuel pump when i turn the key the car ran fine and then i parked it for a few months and now it wont start
Charge battery? How cold/ hot was it when parked? could have water i oil that could seaze pistons, put a little oil down spark plug holes and leave 4 couple days. Try cranking by hand with bar and socket on main pulley. Have rodents eaten your wiring? Have seen this and it wasnt preety or cheap.
Feb 13, 2011 | 2000 Mitsubishi Eclipse
First of all. We have put 2 new starters on this car recently. We thought the first might have been a fluke. However we had the 2nd checked and it tested fine as did the battery and alternator. Problem is...
what do you mean by wont start?? engine cranks but wont run? engine wont crank? Is the anti-theft light flashing? is the car in park? did you put it in Neutral and try to crank it?
Nov 19, 2010 | 1992 Saturn SL
Won't maintain a constant temp. Varies from +10 to -15
i doubt that.def sounds like bad cold control though,good news if your producing cold. Hair dryer good---- Ice Pick no good!!!
Feb 18, 2008 | Frigidaire 13 cu. ft. / 368 liter Chest...
Refrigerators Logo
67 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
