Question about Riso RZ220 Duplicator
T2 error message gr3750 Paper tray not rising machine says t2
Tip
CANON iR2016/2020 ERROR CODES
E000 0000 Fixing temperature abnormal rise
E001 0000 Fixing unit temperature rise detection (by main thermistor)
0001 Fixing unit temperature rise detection (by sub thermistor)
E002 0000 Fixing unit temperature insufficient rise
E003 0000 Low fixing temperature detection after standby (by main thermistor)
0001 Low fixing temperature detection after standby (by sub thermistor)
E007 0000 Fixing film rotation error
E010 0000 Main motor rotation error
E019 0001 Waste toner full detection
0002 Waster toner full detection sensor failure
E052 0000 Duplex unit connection error
E100 0000 BD cycle out of range
E197 0000 Erroneous communication with printer engine
E500 0001 Finisher communication error
E520 0000 Offset error
E531 0000 Stapling error
E540
0001 Paper surface not detected (standard tray)
0002 Not moved within the specified time (standard tray)
0003 Sensor not reached within 3 seconds (standard tray)
0005 Encoder clock failure (standard tray)
E542
0001 Paper surface not detected (optional tray)
0002 Not moved within the specified time (optional tray)
0003 Sensor not reached within 3 seconds (optional tray)
0005 Encoder clock failure (optional tray)
E575 0000 Stack delivery error
E584 0000 Shutter failure
E716 0000 Erroneous communication with optional cassette
E719 0000 Erroneous communication with card reader (serial communication)
0002 Erroneous communication with coin vender (serial communication)
E733 0000 Erroneous communication between controller and printer
E736 0000 CCU communication error
E739 0000 Erroneous communication between controller and network board
E744
0001 Language file/boot ROM/USB memory error
0002
0003
0004
E805 0000 Fan failure
E808 0000 Fixing drive circuit failure
on Aug 03, 2010 | Office Equipment & Supplies
Error code c0202
c0202 means that the top paper tray is not rising to bring the paper in contact with the feed rollers. Remove all of the paper from the tray and try turning the machine off and on with the paper tray not pushed in to the machine. Good luck.
May 20, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Is there a lever or switch that tells the printer to grab from the front tray?
On the machine panel, the "feeder" button selects paper source and media type to be used. This must match the media/paper size selected in your software.
MP - multi-purpose tray
T1 - the upper paper cassette
T2 - the optional lower paper cassette
Dec 03, 2009 | Brother HL 2060 Laser Printer
Riso GR3750
T2 indicates an elevator motor failure. Take off the back cover and check the lower limit sensor for the paper tray to make sure its not full of dust.
Reset can be done by holding the reset key down during power up.
Test mode is entered by holding down LINE/PHOTO and the M/P buttons during power up.
Test mode# 102 tests operation of the elevator motor.
Aug 27, 2009 | Eagle Signal Br1 30min Reset Timer
Reset RISOGRAPH GR3750
Check the Power PCB ,maybe some fusies' ve blown
On the bizhub C550 an error code C0204..... won't let me use paper tray 2
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
Jul 22, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Load paper error message when using legal paper. Paper tray is full and still get message. Loaded feeder tray and got clear paper jam. Yet letter size paper worked in the paper tray.
you have to program the paper size anytime you change the size of paper you use in a lot of panasonic machines. This is done through the
function" feature... go intofunction... general settings...scroll down to key operator mode...the code will be "00000000" (8- 0's) and it will be in one of the first screens up
Jul 06, 2009 | Panasonic Workio DP-1820E Copier
System error E808
Canon iR2016 / iR2016J / iR2016i / iR2020 / iR2020i Код ошибки Субкод Описание
E540 0001 Paper surface not detected (standard tray)
E542 0001 Paper surface not detected (optional tray)
E744 0001 Language file/boot ROM/USB memory error
0002
0003
0004
Mar 22, 2009 | Canon CLC 1140 Copier
Malfunction Detected Error c-0211
C0211 Manual Tray Rise Descent Error
• The Bypass Lift-Up Sensor is not blocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the standby position to the feed position was started.
• The Bypass Lift-Up Sensor is not unblocked even when the Tray 2 Vertical Transport Motor has turned for a given number of pulses after the sequence to move the Paper Lifting Plate from the feed position to the standby position was started.
This is a rank B error. To reset follow these steps:
Open and close the front door.
If error recurrs check the manual bypass again or call for service.
Dec 04, 2007 | Konica Minolta bizhub C250 All-In-One...
48 people viewed this question
Top Riso Office Equipment & Supplies Experts
Marius Chiriac
paulfvincent
Adorjani Laszlo
Are you a Riso Office Equipment and Supply Expert? Answer questions, earn points and help others
