Question about GE Profile PFS22MBS Bottom Freezer French Door Refrigerator
We have a GE Profile Frdige, Model PFS22MBSBB that conitunes to rise in temperature to 52deg. The freezer is at -6deg. I have unplugged the unit for approx 10min and re-plugged it in. Will this fix the problem? Or what else could be causing it? The fridge is approx 4yrs. Thanks Bobalou
3 Suggested Answers
docjohn174
  • 943 Answers
SOURCE: PDS22SBRLSS
Hi is there any ice built up at the back of the freezer. is the fan motor going if no ice or frost build up in freezer and fan motor is going . check the compressor. thanks the appliance doc
Posted on Oct 17, 2008
peyton32034
  • 410 Answers
SOURCE: Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Posted on Feb 20, 2009
GE Profile freezer won't maintain temperature
clean the dust from underneath and make sure fan in freezer is working.
Feb 06, 2014 | Refrigerators
Temperature rising in freezer and fridge motor running constantly
The temperature in the freezer will rise if there is no air circulation. Air circulation stops when the evaporator freezes solid. When this happens the thermostat cn not respond and the fridge keeps running.
Defrost the freezer and see if things return to normal. If they do then you have an auto defrost problem.
A technician can help you with this problem
Apr 01, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
The freezer is slowly rising in temperature(0-18 deg in a week, still set at zero) and either side of the unit by the freezer door are very, very hot. Unit is about two years old. Fridge temp is slightly...
Check the condenser fan motor in the back, bottom of unit. pull off lower panel. Fan should be running when unit is running. Also check the condensor coils underneath or in back to make sure they are clear.
Jun 02, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Temperature 0 The digital display switches from normal 5 to 0. Resetting works occasionally
There is likely no problem. The temperature inside a freezer will charge incrementally during the day as the refrigerator goes through various cycles. For example, during the defrost cycle, the freezer temperature will rise significantly due to the heat from the evaporator heater. This temperature rise is temporary and should not cause a problem.
Oct 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Defrost Timer Prroblem?
Refrigerator not cooling, ice forming on back of side-by-side freezer:
Turn off unit. Empty freezer section. Remove freezer back panel (4 screws) to expose iced-over coils. Use a fan to speed up defrosting. Put a towel or a plastic drip pan in the bottom of the freezer to collect melting water (rather than letting the water collect and maybe overflowing in the drip pan underneath the refrigerator).
After defrosting, by temporarily replacing the freezer back panel and turning on the unit, the refrigerator may operate OK for about 3 weeks before the next excessive ice build up.
Possible problem- a burned out Defrost Heater.
To check: After defrosting, turn off power to or unplug the refrigerator.
Unscrew the Defrost Heater bracket (2 screws). When loose, unplug the two wires connected to the unit. Have the unit checked, or use an ohm-meter to check continuity. If unit measures "open", high resistance, replace the Defrost Heater and bracket. If the heating element shows continuity (or low resistance) the heater is probably OK and you have another problem. Now you may need to contact a repair man.
Jul 08, 2009 | GE Profile PSF26NGW Side by Side...
GE PROFILE BOTTOM FREEZER PDS20SBSALSS Digital temperature reading for freezer rising. outside of compartment very warm. Fridge temperature now 44, Freezer at 12. Settings have not been changed. quick...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 02, 2009 | GE Profile PDS20SFSLSS Stainless Steel...
Freezer temp is rising to 12 degrees and doesn't reset
Most likely your computer board got zapped. It's usually located on the back of the unit. Have you tried to reset the unit by leaving it unplugged for about 20 minutes?
Nov 29, 2008 | GE Refrigerators
PDS22SBRLSS
Mar 09, 2008 | GE PDS22SBRLSS Bottom Freezer Refrigerator
GE Profile PFS22MBS Bottom Freezer French Door Refrigerator Logo
146 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
