Question about Husqvarna Designer I
Designer 1 machine makes noises, presser foot move up and down like it's sewing then presser foot goes all the way to the plate on bottom won't move and the screen says presser foot too high... any suggestions of what could cause this or on how to fix it?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
This doesn't sound like something that you can do yourself. Find your nearest authorized repair center and have it checked out.
Posted on Jun 12, 2008
I have a Singer Confidence 7469Q Sewing Machine. It just stopped sewing, makes a beeping noise when i push foot pedal. Can you please help me? Thanks
Something is not in the correct position to sew...perhaps the presser foot is not down, the feed dogs, etc. Check to make sure you do not have a stitch (like zig=zag) selected that the presser foot or needle plate cannot accommodate.
Jul 31, 2017 | Singer Sewing Machines
Bobbin thread will not catch unless the foot is down?
Ashleigh--Your machine will work satisfactorily ONLY if the presser foot is down. When the presser foot is up, the tension disk is released, therefore, no tension = a big knot of thread.
To free motion quilt, you should drop the feed dogs. Install a darning foot (this foot is shorter in length so when it is lowered, there is a space between the presser foot and needle plate). The space allows the fabric to be moved easily while stitching.
Some sewists will free motion quilt without a presser foot (if they don't have a darning foot), but that is very dangerous as one can easily sew through a finger. However, even when sewing without a presser foot, the presser foot mechanism needs to be lowered in order to properly form stitches.
How to Free Motion Quilt on Regular Sewing Machine
Feb 25, 2016 | Sewing Machines
Loud thumping noise CS-6000i
hmmm... Can you determine where the thumping is coming from?
In my experience thumping like this is because something has gotten out of time. You might be able to see it if you take the bobbin, and needle plates off. Take off the threads, top and bottom and you might have to take out the bobbin carrier too. Making sure to understand how it goes back in. Take off the presser foot and any presser foot holder. Locate the shuttle point. Hand rotate the machine in the direction it normally turns (NEVER backwards) and watch what the needle does. Does the needle hit the shuttle? Does the shuttle bounce up and down?
You also might try grasping the presser foot bar and the lever at the same time. Check for play of the bar by gently moving the presser foot bar up and down while "feeling" for unusual movement.
Even if you determine the issue... you'll need to take it in for repair. There are no publicly available service manuals for your machine (or my brother for that matter)
You also might want to check your bobbin for rough spots, use very fine sand paper to smooth them out if you find any.
Nov 06, 2012 | Sewing Machines
Husqvarna Designer 1 noise and thread breaking issue.
I would be willing to bet that there is a piece of thread wound around one of those pieces below the bobbin area. Get your magnifying glass out and have it a good long look. When you find thread... use tweezers to pull it out.
Sep 09, 2012 | Husqvarna Sewing Machines
I have a 9960 singer machine and am trying to use the buttonhole presser foot for the first time and I can not get it to sew T
the buttonhole foot snaps on to the presser bar, there's a little lever at the back of the presser bar that releases the foot, then put the buttonhole foot down on the needle plate & use the presser foot lifter (number 11) to lower the presser bar down onto the buttonhole foot & you'll hear a click sound when it snaps on & make sure to use the buttonhole lever(number 31) because the machine won't sew a buttonhole unless that lever is pulled down.
Apr 26, 2012 | Singer Sewing Machines
I am wondering if I need a throat plate to sew. Everytime I start sewing, it gets clogged up and makes buzzing noises. I cut the tight threads, start again, and then it happens all over again. So, Is there...
Yes, you need the throat plate, Somehow you are not threading it right. Do this, change your needle, flat side facing away from you, totally rethread, with the presser foot up, pull the threads, it should move smoothly, now put the presser foot down, the thead should barely move when pulled. This normally will seat the thread in the tension discs. I don't know what else to try without being able to see the machine.
Jan 14, 2011 | Sewing Machines
How do I move the presser foot on a Husqvarna Viking Emerald 116 sewing machine?
Not sure what exactly you need to know. Are you trying to lift the presser foot or change the presser foot to another one? If it is lifting, there will be a lever of some kind behind the machine. On one of my Husqvarna machines it was a big flat "paddle" shaped lever, not sure what shape it is on the Emerald machines. Lift the lever from the bottom upwards and outwards. Most Husqvarna machines have clip on-and-off feet. You just gently pull forwards on the foot (while the presser foot is raised) to remove it, then push the new one on making sure the small bar part of the presser foot goes into the clip on the presser foot ankle.
Jun 16, 2010 | Husqvarna Viking 1
Viking Designer 1 presser foot will not stay down
The foot should come up slightly above the fabric when in embroidery mode. If not, the fabric could not move.
The foot should come up the same distance that it would if you were to put the foot in the pivot position while sewing. If it is coming up more than that, then you have a problem and will need to see and authorized technician.
Apr 19, 2009 | Husqvarna Designer I
Presser foot 7 lever on Pfaff 1471
You may not be using the correct presser foot for your machine.
Sewing Machine Feet
You may be using a low shank when your machine needs a high shank.
May 12, 2017 | Kenmore 15218 Mechanical Sewing Machine
CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
Make sure you're using the correct foot for the stitch. Is this during sewing or embroidery? Take off the bobbin plate using the screwdriver and remove the bobbin. Make sure everything is clean under and around the shuttle. If you've ever broken a needle the tip might have fallen down into the mechanism and occasionally be jamming it.
Nov 19, 2008 | Brother SE-270D Computerized Sewing...
Sewing Machines Logo
122 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
