I have a Zune 30 GB player, and everything was working fine, except the battery wouldn't hold a charge very long, so I replaced it. Since then, it has no sound. I see the song playing, but nothing through the headset. I did a soft reset and a hard reset, but still no sound. What did I do or what can I do?
  • 1 more comment
  • andreyoust Oct 09, 2010
    It is not headset, tried multiple ones. All I did was replace the battery. The unit still seems to work, I added songs, they seem to be playing. Tried the radio and still the same thing, no sound thru the headsets.
    How can I tell if this happened? Looks okay from the surface.
  • andreyoust Oct 10, 2010
    Thanks for your help. Do I have to remove anything to do this? I don't see any wires, it looks like a circuit board. I have another zune 30 gb with a broken screen. Would it be easier to replace the headset jack altogether or replace the screen on the broken one?
    President:
  • 2,777 Answers
It sounds like somehow the audio processor for the Zune failed in the process. This is a major failure for sure and basically requires the entire Zune be replaced. It is not cost effective to buy a new board for it, it costs as much as a new Zune. Hopefully you can still return that battery and buy a new Zune in it's place...
Sorry about the bad news but that is definitely what has happened :(
Tim
Posted on Oct 10, 2010
    Master:
  • 397 Answers
When you replaced the battery, I suspect you broke a solder connection for the headphone port. A way you can test this theory is if you have something like one of the many Zune alarm clock/docks- if you get sound from the base, then the issue is the headphone jack. Make certain the connection for the leads are solid- you may have to resolder them (will need a soldering iron with a small tip, possibly a solder extractor and some 60/40 rosin core solder)
Posted on Oct 09, 2010
  • 1 more comment
  • Susan Fender
    Susan Fender Oct 10, 2010
    Usually it's a small lead...I really don't like fiddling with microelectronics due to having very large hands and a strong dislike of solder splatter burns- but see if the wires coming off the headphone jack are able to move- if so, that's your broken connection. Also, bad solder connections are greyer- good solder connections are bright silver. You might need a magnifying glass to check it out- the wires are generally very small and fidgety.
  • Susan Fender
  • Susan Fender
    If you can replace the jack completely, that may be best
    Genius:
  • 1,478 Answers
The headset may be bad, i will advice you try use another headset and see if it makes any difference.
Take care.
My Zune 30GB Is Menuless...
Try this....
Reset Zune: Press and hold the back button while pressing up on the control pad.
Connect Zune to a power source: If the Zune device is in sleep mode, this action will wake the Zune device and turn it on. If the battery does not have a charge, you may have to wait several minutes for the Zune device to turn on.
Also, make sure that the hold button on top of your zune is turned to the off position.
Hope this helps!
May 08, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
30 gb zune problem
What you can do is change the date or time on your computer in which your Zune is plugged into, and it can fix it.
If that doesn't work, look up how to take it apart, then unplug the hard-drive chord and replug it in.
Then charge it and ureka it worked!
You may have to do this a few times for it to work.
Apr 05, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune player hardware problem
eeh, this is a pretty bad problem. I would ask you if you had a warranty, but you took it apart... I can only suggest getting a new one, not a 30 GB because that one seems to have the most problems. Fixing it though, you could ask the Geek Squad about it. Next time it freezes, just wait for the battery to die, then charge it and restart it.
Jan 20, 2009 | Microsoft Zune JS8-00001 Digital Media...
My Zune 30GB is frozen on the start up thing!
Disassemble and disconnect the battery for about 10 seconds. All Zune 30's apparently siezed this AM. MS is working on their solution, not sure when it will come out. The battery disconnect is at least a temp fix. Mine works fine after doing it.
Dec 31, 2008 | Microsoft Zune JS8-00001 Digital Media...
My 30 gb zune is frozen
http://www.rapidrepair.com/guides/zune/zuneassemblyguide.htm
goto step 4 only remove clip for battery wait ten seconds. It worked for me!
Zune screen replaced... buttons not working except 'down'
take apart = bad; the hold/lock button was probably engaged - unlock it per the manual
http://www.zune.net/en-us/support/usersguide/default.htm
Jun 25, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Zune won't turn on or charge
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 11, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune keeps freezing up...
JUST HOLD THE BACK BUTTON AND THE UP BUTTON FOR 30 SEC. AND YOU WILL BE GOOD DON'T WORRY PEOPLE.... ALSO WHEN I FREZZE ALOT THAT MEANS YOU DATA ON THE ZUNE IS COUPPORTED AND YOU WILL NEED TO RESET THE WHOLE DEVICE OK.
Feb 19, 2008 | Microsoft Zune JS8-00001 Digital Media...
Zune won't charge
now what you do is if the zune just has a black screen with a battery symbol and it stays that way forever when on the charger. you, take the zune off the charger and press the play/pause button and if it turns on for a second with the low battery symbol then turns off, your in luck, just hold the play/pause button for 10 - 20 minutes. the zune will have turned on and off alot agitating the battery. once you hold it for 10 - 20 minutes put it on the charger, then presto it works. let charge fully then die completly for every time you use it for a bout a month to let the battery get back into it's normal cycle. ~Dan herzberg~ Thank you*
Feb 18, 2008 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune is Not responding
after much research on this matter in the past few hours. To resolve this situation don't shut the zune down by holding play/pause button it does not shut down properly that way.
Hold down the down & back button down until shuts off....zune recommends as the best way to turn off your zune. Also if you are having problems holding charge, a lot of people replaced the original charge plug and found that it worked again. these cables usually become faulty from previous models and 30gigs. So buy a new cable & shut it down correctly.
Still no worky??? Call zune, within 1 year they will accept it for repairs. They may even send you a new refurbished zune...since they no longer are making the 30 gig...probably for those reasons.
I hope this advice not only helps you but myself. Who wants an expensive paperweight...not I!
Dec 11, 2007 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
48 people viewed this question
 Grubhead
Grubhead
