Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
Doors are not even across the top - KitchenAid (KSRD22FKST) Side by Side Refrigerator
    Scholar:
  • 42 Answers
Is this a new problem? Or have the doors always been uneven?
Is your floor level? A tilting floor can make an appliance look uneven. Even if you assume your floor is level, it might be worth checking. Floors can change over time.
Is one door level but the other out of plumb? If so, the problem could be the hinges on the uneven door. This could be caused, for example, by overloading the door trays. One of the hinges could have become bent or damaged. If this is the case, it should be replaced. Check all the hinges carefully for signs of damage or wear. If both doors are out of plumb, it's possible that both doors have damaged hinges.
Another question is: just how uneven are they? Are they uneven by less than 3 millimetres? Or more than 2 centimetres? Obviously the bigger the unevenness the more likely you will need to get it fixed. But if it's tiny, it might be just cosmetic and unless it really bothers you it could be left alone.
I hope that helps a bit. Good luck!
Posted on Oct 09, 2010
My samsung freezer door does not close all the way causing frost buildup. I have replaced the gasket and leveled the fridge.
The hinges usually have some adjustment on them. Two person job, or put something under the bottom of the door to support it. Loosen the hinges a bit, pull the door forward at the hinge which should close the gap on the other side. Tighten down the hinges and check again.
Jun 16, 2016 | Samsung Refrigerators
How do I remove the inner panel when the door is stuck shut?
your going to be twisting your body remove door handle and window switches than start from backseat( if front door) and pry carefully panel from retaining clips along lower and side than lay across front seat and start prying across bottom removing remaining clips pull away slightly than up to release the window channel and panel off look for a rod that is disconnected from latch
Aug 25, 2015 | 2005 Kia Optima
The alarm dings. Why does the ice/water dispenser then shut off and lock?
Not sure if I'm reading this right. Is the alarm you are talking about the one that tells you the door is not closed all the way??? If that is correct, then the reason your ice/water system is not working is because the wiring system for the dispenser is fed through a switch on the freezer door which keeps the dispenser off when the door is opened. You need to correct the door problem causing the alarm to ding and that should also fix the dispenser problem. Possibly a door adjustment needed. Door top edges should be aligned and even across the top and the gap between the doors should also be the same distance top to bottom if this is a side x side.
Mar 21, 2015 | GE Refrigerators
What's causing frost across the doortop of our upright freezer?
Sometimes there is a little spacer at the hinge to guide the door. I would make sure the door is squared up properly to the inside so that the space of the seal is consistent with the non frosting side. Don't forget, that top hinge can be adjusted to angle the door for even spacing. You can even put a spacer on the bottom to raise the door if necessary. Later, remember the door should close slowly on its own.
Jan 23, 2015 | Frost Refrigerators
My 2000 ford ranger pickup door latches are broken how do I open the doors. Do I have to break a window to get in?
Usually you can pry the window a little bit or pry the top corner of the door out a little.. you need a metal rod.. preferably 1/4" diameter. long enough to reach across cab to catch oposit door handle and open the door. If the truck has electric door locks. you can sometime just reach down with your rod or even a coat hanger and push the unlock button.. another is a "slimjim"tool i'm not sure if it will work on a 2000 model.. what ever you do try not to break anything or tear the seal of the door. I have done this many times for people that have left their keys in car.
May 11, 2014 | Cars & Trucks
How do I open the rear tailgate on my 2002 Chevy tracker? I suspect a rod is broken that operates the handle as there is only free play when you pull up on the latch. Vehicle has a plastic trunk in it and...
same problem with mine, took us awhile but we got it. you need to fold down the back seat, snap the fake truck piece on either side, pop off the door skin, starting under the convertible top bar that runs across the door, and there it is. we managed to pop off the fake trunk thingy without breaking it, it hooks on either side but you can still use it after-wards even if you do break it. good luck
Oct 05, 2010 | 2002 Chevrolet Tracker
Both doors open at same time
check the leveling of the frige. if unlevel it will offset the doors. with the doors closed they should be as close to even across the top
Oct 29, 2009 | Refrigerators
JUST INSTALLED CRAFTSMAN 3/4 TODAY, WHEN IT OPENS IT WANT TO PULL THE WOOD FRAME FROM ACROSS THE TOP OF THE DOOR AND BEND THE DOOR ITSELF, CAN'T FIND ANY TROUBLESHOOTING ADVISE
How did door work when you opened manually. OK? Did you mount door opener at right height. Reinforce top of door with mending plates. Do not understand your description that you are pulling the wood frame across the top of door.
Apr 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Red line across top about 2" down
It could be a bad connector to the LCD a Bad LCD or even the logic board. Non of which is a good thing. Check book will feel light after a repair.
Jun 11, 2008 | Protron PLTV-37 37 in. LCD Television
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
229 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
