Question about RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7 pulled if off with pliers. I know. Not very bright. So as long as I get a guarntee you think I should purchase board? You think I should purchase ballast also? Or you think my ballast is ok?
  • RCA Master
  • 8,617 Answers
I would try the power supply first as the ATC336 has a history of the bad power supply boards.If the power supply doesnt fix it then I would think it may possibly be the ballast
Posted on May 31, 2008
How do I open the hood on my car if the release latch in the car breaks and it won't release when I pull on the cable under the kick panel with a pliers?
Depending upon how your Dodge was constructed, it may be necessary to access the latch from underneath. A straightened wire coat hanger is a useful substitute for the release cable. You will need a bright light source to find where to hook the hanger and pull. Someone will have to press down on the hood to release latch tension and allow release.
Jan 29, 2015 | 1997 Dodge Intrepid
How do i change the fuse for the dash lights on 95' astro?
All you do is pull the old one out and replace. Often on the fuse cover is a small plastic fuse puller. Think of them as plastic pliers. If it is missing, use a regular set of pliers, or needle nose pliers to grab the fuse and pull out. Or your fingers, but sometimes you can't get a good grip due to space limitations.
If you don't know the fuse location, check your owner's manual- it will have a fuse lay-out and descriptions.
Aug 29, 2014 | Cars & Trucks
I can't seem to figure out how to pull a fuse from the fuse panel on my 2004 lexus RX 330. I can't grab it to pull it straight out. Is there a tool I need and if so where can I buy this tool?
well ms dragon on my cheap subarus, saturns, hyundais, the tool is snapped into the fuse panel cover. so you remove the tool, use it to pull the fuse, then put it back in. i would think for the extra bucks involved in purchasing a lexus there would be one provided there also. have you looked? it is usually a different and bright color.
auto parts stores are good places to buy auto parts and auto repair tools, have you looked?
on the other hand i have always found good old needle nose pliers, hardware stores and auto parts stores, are handy for this as they are not plastic and hence do not have a tendency to slip off.
when you start to pull them, note they are color coded, obey the color codes when putting them back in.
Jul 19, 2011 | Lexus RX 330 Cars & Trucks
I have the Vector Power On Board Bright Bar model WLB26MCP and I need the recharging device. How can I get one. Thank you, fnnsmith@aol.com
You can purchase one from Black and Decker, Vector was purchased from them in 2006, here is the link;
http://www.dewaltservicenet.com/servicenet_home.aspx?r=No%20%Results
Oct 05, 2009 | Vector Power On Board High Intensity...
Ds lite green light flshing pulse sound from speaker
Check if "L2" is in place. Ususally drop from its position in the circuit board near the power switch, is a little black piece with solder in 2 sides. And the symptoms are almost the same as the blown F1 and F2 fuses.
If you opened your DS and didnt found it or wasnt aware and lost it you'll need a parts circuit board to take it from and solder it to your board, as theres no known part specification or schematics for the DS, at least as I know the only way is using a Henry meter to get the L2 value.
And you might have a water damaged board or broken top screen ribbon cable too as for the tick sound from the speaker is new for me.
Dec 19, 2008 | Nintendo DS Lite Console
Hplpw175x7
youre welcome let me know if I can assist you further.
Jun 11, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
I need to know which type lamp assembly you use there are two types type A and Type B. Let me know and I will post a link where you can get a new ballast circuit.
Jun 10, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
If the color wheel was the only problem the power supply should be good
Jun 02, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Hplpw175x7
Thats a good price as long as they guarantee that it works. How were you able to pull a capacitor off without un-soldering it?
May 30, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
RCA HDLP50W151 50" Rear Projection HDTV Logo
81 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
