Question about EnGenius EAP-3660 802.11b/g Wireless Access Point
Am trying to configure new EnGenius EAP9550 as a universal repeater. With difficulty, have succeeded in taking it through the initial set-up steps -- it can see my wireless network (residential) and has been instructed as to the WEP key. When one says "apply" it responds with "loading module" but then states that it has failed to connect to my wireless network. If I logout of the setup sequence and then try to find out whether by chance it is working anyway, my laptop appears to be talking to it (signal strength is excellent, in a place where I know it would not be absent the repeater) but the internet cannot be found. If I unplug the EnGenius, the laptop promptly attaches to the wireless network and finds the internet. I have been assuming that once the EnGenius was configured I should reinstate "obtain IP address automatically" on my TCP/IP on my wireless card profile -- for some reason the EnGenius tells you to used a fix IP address while configuring the EnGenius, but I assume I should put it back to "auto" after configuration is done, right?
4 Suggested Answers
Macs R We
  • 481 Answers
SOURCE: Hi, I cannot setup my
You need to enable the DHCP server on the EOC-2611P. Then it will negotiate an IP address with your PC without you having to set one by hand.
Posted on Oct 27, 2010
Macs R We
  • 481 Answers
SOURCE: i am configuring a engenius
Every node added to a WDS network cuts the network transmission speed in half. This is just a characteristic of any WDS connection, as WDS is a repeater protocol (it has to retransmit everything it receives).
It's not clear from your description whether you are trying to add the EOC and the Cisco to the same WDS network. If that is the case, it's a wonder you got it to work at all, since WDS implementations are model-specific, and usually require every node to be exactly the same model router.
SOURCE: I am currently in the
Here is an advice ..maybe could help you . 802.11n is the third-generation Wi-Fi standard for wireless home networking. 802.11n equipment is backward compatible with older 802.11g or 802.11b gear, and it supports much faster wireless connections over longer distances.
So-called Wireless N or Draft N routers available today are based on a preliminary version of the 802.11n industry specification.
Belkin N1 Wireless Router (F5D8231-4)
Belkin N1 Wireless Router supports 802.11n ("Wireless N") networking. Besides supplying a performance boost over older 802.11g routers, the Belkin N1 offers several features to simplify home network setup as well as some higher-end capabilities often needed on business networks.
  • Supports up to 300 Mbps maximum network bandwidth and range up to 1,400 feet (450 m) using three built-in Wi-Fi radios.
  • Compatible with Microsoft Windows, Mac OS and Linux computers
  • Includes a Fast (10/100) Ethernet network switch for up to 4 wired connections
    Posted on Dec 21, 2010
    Wireless repeating between DG834G (WDS configuration)
    If you have two of the below mentioned routers and would like to extend wireless network using repeating feature between the two then you can perform the below steps to configure wireless repeating between them.
    Configuration of Wireless repeating between DG series router (Capable of WDS feature) like DG834Gv3, v4, v5, DG834N, DGN2000, DGND3300
    The below steps should be performed on both the routers so as configure same wireless settings:
    1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
    2. Access the router, usually with or
    3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
    4. Click on Wireless Settings'(under Setup) from the left menu.
    5. Change the network name SSID to NETGEAR123. Select security options as 'WEP (Wired Equivalent Privacy)'.
    6. Set the 'Authentication Type' as automatic.
    7. Set the 'Encryption Strength' as 64-bit.
    8. In Key 1 type a 10 digit number.
    9. Apply the settings.
    Now perform the steps below on the first router say router A which connects to internet through ADSL line:
    1. Click on Advanced Wireless Setting in the left hand side menu.
    2. Check the option for Enable Wireless Bridging and Repeating
    3. Select Repeater with Wireless Client Association and enter the MAC address of the router B.
    4. Click Apply.
    Now perform the same steps on router B and make sure to enter the MAC address of router A on step 3 above.
    The above steps would help you with the configuration of wireless repeating feature between the two DG routers as mentioned initially. The only thing that you need to take care is that both the routers should be configured with same wireless settings.
    on Mar 19, 2010 | NetGear DG834G Router
    When I enable the vlan option in an EAP9550 I lose wireless access
    Is the goal to use a different VLAN for each access point (AP)? If so then you will need to configure each NetGear port to use the same VLAN as the AP that is connected to it. You will then need either a switched virtual interface (SVI) for each VLAN on the NetGear or a trunk port (802.1q) from the NetGear to the Cisco. I'm not sure the NetGear will support SVIs but it will support trunks. An SVI basically creates a gateway for each VLAN's subnet. For example, let's say AP1 uses VLAN 10 and the subnet is while AP2 uses VLAN 20 with a subnet. The NetGear will need 2 SVIs, one for each VLAN/subnet. The first SVI for VLAN 10 can be configured with IP address while the second SVI can be configured with for VLAN 20. These IP addresses will be the gateway for each VLAN. Finally, the NetGear would need to act as a router and route each VLAN's subnet to the Cisco device. Once again I don't believe the FS726TP supports this.
    The other solution would be to create a VLAN trunk port between the NetGear and the Cisco device but I believe the Cisco RV042 does not support trunking. If it does the trunk would be configured to carry all of the VLANs to the Cisco device which would then have SVIs created on it.
    If neither of the above is possible you would need to use the same VLAN for each AP and each of the interfaces on the NetGear and Cisco devices which negates the need for the VLANs.
    I hope this helps.
    Mar 13, 2014 | EnGenius Computers & Internet
    Need to install on my hp laptop yes eap9550
    You do not need and installation or a driver to connect to an access point. If you need a driver, it'll be the driver of your wireless lan card.
    Feb 17, 2012 | EnGenius EAP9550 Wireless Access Point
    Cannot get in to my Engenius 3220 with
    Attach the 3220 directly to your computer with an ethernet cable (through the POE box, of course). Allow it 60 seconds to start up. Make sure the address of your computer is 192.168.1.something. Ping If it answers, browse to and it should let you in, or ask you for a name and password, however you have it set up. If the ping fails, is not the address assigned to your bridge, and you may have to perform a factory reset on the unit using these instructions:
    If the ping and browse succeed, then make sure that is not within the DHCP range of your Netgear router to avoid it giving out the same address to some other device. I assume that 192.168.1.x is in the LAN range of your router -- if not, that's your problem.
    May 02, 2009 | EnGenius EOC-3220 (EOC3220)
    EnGenius EAP-3660 802.11b/g Wireless Access Point Logo
    960 people viewed this question
    Top EnGenius Computers & Internet Experts
    Level 1 Expert
    Karen Gibson
    Level 1 Expert
    Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
