Question about Frigidaire FEF366 Electric Kitchen Range
Every time I use the front (Large) burners, the power meter outside spins extra fast, then slow, then extra fast again. Something's not right there.
    Problem Solver:
  • 11 Answers
The stove keeps an even temperature by constantly turning the power off when the desired temperature is reached and when the temp drops a few degrees it comes back on.
Posted on Oct 10, 2010
Atf6000fs2 does not fast spin to remove water only slow spin /checked it on all spin speeds
Either the motor cannot turn over fast enough to power the pulley system, or there is an issue with the pulley system.
Sep 04, 2012 | Frigidaire Affinity ATF6000F Front Load...
Washer is not spinning fast - so the clothes are more wet when done
sounds like washer is load sensing either overloaded or unbalanced when it decides to low spin insteasd of high spin dose it stop for second rotate 3 times and change direction 3 times the just spin slow.... if so either u have misloaded the machine by overloading orthe clothes are unbalanced in load may need add a towel or something to balance the weight evenly in the tub
Jan 28, 2011 | Whirlpool Duet GHW9150P Front Load Washer
This is for an LW7503W2B washer. We have water on the floor during agitate with large loads. The water is comming over the edge of the tub. I have noticed the tub rotates in what I would call a slow...
I had the same problem. You need a brake kit. it holds the drum still while in the agitate mode. the centrifical force of the water during that slow spin is causing the water to spill over the top of your drum. easy and cheap fix.
Oct 18, 2010 | Amana ALW780QA
My burner gets excessively hot very quickly is this normal?
That right front burner is an extremely hot burner by design. It is sold as a quick power burner. The rating on it is 12,000 btu's meaning it could easily boil a pot of soup in that time.
Here is a quote from the owners manual for your range
"There is a 12,000 BTU*
burner located in the right front position. These burners offer
higher speed cooking that can be used to quickly bring water
to a boil and for large-quantity cooking."
Use the back for slower smaller cooking and front for larger and quick heating.
I hope that helps.
May 09, 2010 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
GE Front load washer spinning too slow????
A couple of things come to mind,if the micro-processor senses the load is out of balance enough, it will control the RPMs(reveloutions per minute) or slow it down in order to avoid damage to the suspension system, so readjusting the spin speed manuallly probably would help. Although that machine should be able to handle 9 large towels easily! Next thing, have you cleaned out the trap inside the lower access panel, if it is restricted you will have draining problems. Good luck !
Jan 07, 2010 | Kenmore 22422 Top Load Washer
Does not spin clothes dry
Run the washer empty on the lowest water level. Cold will save energy. Watch it fill, close the lid, stay there. Don't advance the timer no matter how tempting as this could skip a program interval. When you hear the water draining listen for a sound change and open the top and see if it drained completely -- pumped out empty. Close the lid so the cycle can continue. During the spin cycle open the lid. See if the drum was really turning fast -- it will be slowing down as soon as you open the lid because that stops the motor. If everything seems normal, then the problem may be transmission or belt slipping under load. Do you have the problem only on large loads? If the spin speed is slow during the test then the transmission is not shifting in to high, controlled by a solenoid. Check the solenoid for power during the spin cycle. Operate the washer on blocks or outside on saw horses to see full function of underneath parts and have access to electrical wires for testing. Use precautions testing and plug into a GFCI. Take your car battery jumper cables and clamp to a water pipe ground and to the underneath frame where the motor mounts. This should keep you from getting electricuted standing in water and holding a test meter.
Dec 12, 2009 | Washing Machines
Viking professional induction cooktop large burners defective
Throw your circuit breaker that leads to this unit for a few seconds, then reset the breaker This unit is very sensitive to power fluctuations.
Mar 07, 2009 | Viking 37 in. VECU165 Electric Cooktop
Printed wash cycle info missing from front of machine
Quick wash cycle for the Hotpoint FEW12 is 'K'
A 95* White cotton, heavy soil ........ 5.5kg 2hours 30/40 mins Fast spin
B 40* White cotton Heavy soil .......5.5kg 1hour 40/50 mins Fast spin
C 95* White cotton and linen without special finishes......5.5kg 2 hours 20/30 mins Fast spin
D 60* Colour fast cotton, linen or viscose without special finishes......5.5kg 2hours 5/15 mins Fast Spin
E 40* Non-colour fast cotton, linen or viscose.....5.5kg 1hour 40/55 mins Fast spin
F 50* Synthetics, coloured nylon, polyester, acrylic & cotton mixtures, cotton or viscose with special finishes, coloured polyester & cotton mixtures.....3kg 1 hour 5/15 mins Slow Spin
G 40* Acrylics and tri-acetate blends of these fabrics with wool, polyester & wool blends....3kg 40/50 mins Slow Spin
H 40* Wool, shrink resistant machine washable wool, woolen blankets..... 1.5 kg 1 hour 15/25 mins Fast Spin
H...(Wool mixtures with cotton or rayon.....2.5 kg)
J 30* Silk, printed acetate.....3kg 55 mins/1 hour 5mins... Slow Spin
K Quick wash for freshening up lightly soiled items. Warning... not for woolen, silk or delicate items.....1kg 35/45 mins Slow Spin
L Cold wash, cold fill only, no heating action....3kg 55mins/1hour 5 mins Slow Spin
M Rinse and Fast Spin... cotton......5.5kg 55 mins/1hour 5mins...Fast Spin
N Rinse and Slow Spin... Delicates....3kg 30mins Slow Spin
P Fast Spin .... cotton.... 5.5kg 15 mins Fast Spin
Q Slow Spin.... delicates.....3kg 15 mins Slow Spin
Hope this helps
Sue
Jul 14, 2008 | Hotpoint First Edition FEW12 Front Load...
Extra Spin cycle?
(I know this is an old question, but its probably a common question for new owners - including me a couple of weeks ago...)
Power the unit back on, press the spin speed button and it will select the "drain and spin" cycle. Pressing the spin speed button again will select different spin speeds as well as just "drain".
Something you might try instead of medium spin speed is to turn on "SpinSense". To turn this on (and off), press and hold the "Stain Cycle" button for 3 seconds while any wash program is in process.
What SpinSense does is measure the imbalance by doing a very slow spin before cranking the spin speed up (and measuring how constant the very low spin speed is). If the balance is out too much, it will stop, let the clothes drop, and then try another slow spin. It will try this over and over many times until the balance is decent. Then it will let it rip. It makes a huge difference, but it can spend a lot of time getting a good balance some times.
SpinSense also seems to be able to detect if the machine is shaking terribly, shut the spin down and try again.
Our LG 2688 is on our 1st floor (wooden floor). Without SpinSense, the vibration was terrible and with it, it is tolerable.
For some reason we typically get less vibration with "Extra High" spin speed compared to "High" so that is another option you might try.
May 08, 2008 | LG WM2688H Front Load Washer
Frigidaire FEF366 Electric Kitchen Range Logo
76 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
