Question about Durabrand DWT1304 13" TV
Tv as protected program tv-y7 message when turned on, cna change channels but goes right back to that message how do i correct this
    Scholar:
  • 143 Answers
In the Menu of the TV, there should be a parental ratings feature. You should be able to adjust it there! Good luck!
Posted on Oct 09, 2010
AFTER TURNNING TV ON 2HOURS (+OR-) THE SCREEN GOES BLACK ON CABLE STATIONS AND THE FOLLOWING APPEARS ON SCREEN ------- PROTECTED PROGRAM BY TV-PG ------ WHAT STEPS MUST I TAKE TO CORRECT THIS ON MY TV ! ...
The parental control or V chip settings are turn ON. I would suggest to find it in the menu and turn it OFF.
What is the model number of your TV?
Dec 20, 2010 | Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
NOT SCANNING CORRECT ZONE
No! your radio is not programed properly. you will need to take it to a Motorola Dealer or back to the person that programed it. It is a simple fix but you cna not do it from the keypad.
Sorry. Bill
Apr 30, 2009 | Motorola Talkabout T4500 (7 Channels)...
Cant get digital channal on my DCP 501
From page 24 of the Installation Section
The clear protective film on the DCP501 display must be removed and transferred to the inside back cover of your
DCP501 Home Theater System User Guide. The Unit Address and Serial Number found on the protective film is
required for activation of your DCP501 cable TV receiver by your cable TV service provider.
On Page 28 -
Do not disconnect the cable connection between the RF In and To RF In ports. Removal of this
cable could disrupt operation of the DCP501.
IMPORTANT! The digital cable feature of your Motorola DCP501 can be activated only in
certain cable systems throughout North America. Contact your local cable TV provider to
determine whether the digital cable feature of your Motorola DCP501 can be activated. In cable
systems where the digital cable feature cannot be activated, you may connect an external cable
receiver provided by your local cable provider. For best results, connect an external cable
receiver through the audio and video inputs on the back of your DCP501.
Page 74 -
Using DCP501 Cab le TV Functions
The DCP501 has an advanced CATV set-top terminal that allows you to view cable channels.
The DCP501 must be authorized for cable TV operation by your cable TV operator before it will
tune channels.
To use your DCP501 to view cable channels:
1 Press SOURCE to display C ATV on your TV. C A TV and the last channel tuned are displayed
on the DCP501 display.
2 Press MENU to display the TV program guide on your TV.
3 Press GUIDE to display the television program guide on your TV.
4 Change channels by pressing CHANNEL/PRESET���� or making your selection with the
If you receive an electronic message from the cable operator, the message icon �� turns on.
You must use the TV program guide to retrieve an electronic message.
Additional DCP501 cable TV functions include CATV Record and CATV Channel Scan.
If you don't have the manual go to:
http://www.retrevo.com/support/Motorola-DCP501-Receivers-manual/id/393bh936/t/2/ and register to get it. It's free.
Mar 21, 2009 | Motorola DCP-501 Receiver
DWT1304 13''
Hi - Below is a link for your manual. You can download it and it will show you how to change it. If this solves your problem PLEASE rate this as fixed.
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
Jeff
May 16, 2008 | Durabrand DWT1304 13" TV
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
Channels blocked
Hello to all, go to your TV menu and go to V-chip set up, then go thru and see that you don't have any channels blocked. If you do and you are watching a show with that rating, you will receive the "protected program message".
Have a great day!
Oct 21, 2007 | Emerson EWC1304 13 in. TV/VCR Combo
Durabrand DWT1304 13" TV Logo
134 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
