Question about Refrigerators
Replacing refrigerator parts after cleaning.
Crisper bins are hanging lopsided after putting refrigerator back together. Help!
    Genius:
  • 1,122 Answers
MAKE SURE YOU HAVE BOTH SIDES ON THE TRACK AND IT SHOULD CLOSE ,THANKS-MIKE
Posted on May 30, 2008
I have tried changing the settings on my westinghouse side by side fridge freezer from 3 up to another setting of 5 but it keeps defaulting to 3 and food continues to freeze ,how do I save the new setting?
I found this link to a manual at http://manuals.appliancesonline.com.au/wtm3000pbrh/wtm3000pbrh.pdf . If it was me. The first thing I would do is to unplug the refrigerator for 15 minutes and then plug it back in. I would do this to reset the control board. If you are changing the temperatures and they reset to factory setting then you might have a problem with the control board. Try unpluging it and see if that works first. Refrigerator repair can be difficult and if that does not work you may have to contact a repairman in your area to come out and diagnose it. If I can help you please contact me HERE.
Apr 19, 2013 | White-Westinghouse WRSS25V5GW Side-by-Side...
How to completely clean the Crisper drawer
I don't know if you've already figured out how to remove the front panel on your refrigerator crisper bin, but here it is. Once the drawer is removed, pull back those clips on the top left & right of the front of the drawer.Just hold the side and pull back at the same time, then you can remove it. Once both side have been released you should be able to remove the clear plastic front and clean both pieces. I hope that is clear enough. Best of luck, unless of course you've already discovered the answer yourself.
Feb 21, 2010 | KitchenAid Refrigerators
I am looking for crisper bins for a F & P N500B fridge
Here is a parts store you can call 6 days a week and order any part you need I did not find that model listed but you can talk and find the number. here it is and hope this helps thanks for using fix-ya.
http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=E522B
Jan 24, 2010 | Fisher and Paykel Active Smart E522B...
Whirlpool refrigerator has water pooling under crisper
  1. take all things out from freezer
  2. open back wall of freezer
  3. clean the drain hole in the bottom middle
  4. put all back
  5. good job you fix it
Dec 29, 2009 | Refrigerators
Water under the crisper bins on the bottom.
Likely clogged drain line somewhere between the freezer section and the drain pan on the bottom of the appliance. The drain line should beon plain view on the back wall of the fridge. Disconnect and clean.
Oct 13, 2009 | Refrigerators
Unexplained water accumulation under the crisper/produce
OK, I am going to give you a lot of information on one page, so please read carefully and choose the parts that apply to you. PS, Please rate my solution and my thanks to all the Guru's that helped put the following page together. please click on link below, Thanks Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 10, 2009 | Whirlpool Refrigerators
Water collects in bottom of refrigerator and gets in bins
there is a cup in the back wall of the fridge that is the drain pull it out gently and clean it plus take a small hose and blow through the small hole if there is no cup check under the crisper to see if the drain hole is there
Apr 17, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Water draining under crisper bins & onto shelves. Try again
Your drain tube is stopped up. Take the panel off in the freezer section and chip away the ice in the pan below the coil. When you get to the drain hole pour hot water in it until it free flows. You will need a towel in the freezer to catch the excess water. Run some extra hot water through it to assure that you clean the drain out good.
Mar 15, 2009 | Frigidaire FRT21H8 Top Freezer...
Crisper Door broken
Repairclinic.com had the parts I needed (crisper drawer lid and the longer drawer lid.
Nov 17, 2008 | LG LRFD25850 French Door Refrigerator
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
