Question about Jenn-Air JES9800BAS Electric Kitchen Range
I am thinking about replacing my Jenn Air SVD8310S range. It is about 15 years old. I am trying to find the factory BTU output settings to compare with new model but they are not included in the manual. Do you know?
Noggin
  • 944 Answers
SOURCE: I just got this Jenn Air...bought it 2nd hand in a store..how old is it?
Have a look through this lot, there are a few problems for your model discussed, but nothing that sounds like a known problem for the model; http://www.applianceblog.com/mainforums/archive/index.php/f-64.html This link has a good description of a common problem with the model (temperature too low compared to the digital readout) and it's solution; http://applianceguru.com/forum1/955.html this link has a good collection of reviews on the stove - people were still buying them new in '98, couldn't find exactly when they started selling them; http://www.epinions.com/hmgd-Ranges-Jenn-Electric-Jenn-Air_Slide-In_30-Inch_Electric_Range_SVE47100/display_~reviews If you have any problems and need parts, there are still many companies offering them online for this model - just type "jenn air SVE47100 parts" into google and you will get a good selection. Sorry I had no luck finding a user manual online, free or otherwise, you could try contacting jenn air direct to see if they could send you one; http://www.jennair.com/content.jsp?name=contact_us Hope this helps :)
Posted on Jul 07, 2007
SOURCE: F1-1 error on Jenn-Air Range
VANMAN69, I have looked in the door under the oven door and can not find the codes. Any more suggestions? I have had a repair man come and replace my control board but I am still getting the F1-1 fault code and when using the oven I get the F3-1 fault code.
Posted on Aug 02, 2007
SOURCE: Jenn-Air JGD8130
The problem is the pot(s) is too far from the heat. Jenn-air needs to make a burner cover that is closer to the burner for boiling water...
Posted on Sep 08, 2008
SOURCE: Electronic Display
Go to, fixitnow.com for a cheap fix on these displays. It worked on my jenn air.
Posted on Feb 28, 2009
SOURCE: JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Posted on Apr 24, 2009
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
Self clean oven doesn't work
hi there,
does the keypad beep when you push the keys? if yes, the keypad is fine.
make sure that the keypad is plugged into the control board correct it. the control board is located behind the keypad
do you get any error messages? if yes, please tell me the #.
Nov 17, 2008 | Ovens
Clock/oven/temp screen for a Jenn-Air electronic range #SVE87600
I believe Jenn Air will pay a portion or electronic parts replacement on their ranges less than 5 years old.
You might try unplugging the stove for 1 hour and this is supposed to reset the stove to factory settings
Sep 06, 2008 | Kitchen Ranges
Jenn-Air JGD8130
i have the same problem.. jgd8130.. can i change out the burners or orfices..etc to make one or two of the burners for more btu's? ro9beam2002@yahoo.com
Mar 09, 2008 | Kitchen Ranges
Jenair oven valve knob
In less than 6 years of normal use, 4 burner control knobs on my Jenn-Air free standing gas range, Model JGR8875QDS, have either broken or melted.
If you want to continue to buy Jenn Air knobs, no problem - several suppliers will be glad to provide them for  $10-15, each (USD). Whirlpool's part number for the factory Jenn Air knobs is 74009148, and you can get them from repairclinic.com (#1035396), or PartsSelect.com (#PS2086597).
If, however, you want to try a different set of knobs, hoping to find some that are less prone to break or melt, then it gets a lot more complicated.
Jenn Air/Whirlpool will be no help; they will tell you the only knob that will work is the Jenn Air OEM knob. Parts suppliers won't help you either - no specifications or interchangeability data exists - and they are unable or unwilling to take measurements.
I can tell you the following 3 knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
Dec 22, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Jenn-Air Convection Oven
Our 7 year old "Jenn-Air Convection Oven", Canadian Model # SVE47600 also has a very dim display. We can barely read the temperature on the oven. Does anyone know what is wrong, how to fix it, and what it may cost us?
Dec 20, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air JGD8130
Nov 08, 2007 | Jenn-Air JGD8130 Gas Cooktop
Jenn-Air JES9800BAS Electric Kitchen Range Logo
54 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Mike Carew
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
