Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
My 32" won't power up. It's a 2004-05 model. Is their a board that I can replace or is it cheaper to replace?
  • jstone383 Oct 09, 2010
    Sharp Aquos LC 2004-05?
    Model # LC - 30HV4U
    power light does not come on tv at all. red light comes on on the power unit but not the tv itself.
  • 10,594 Answers
What is model number and brand of your tv?
Does power indicator lit/ blink of tv front when tv plugged in power socket?
Let me know above info to diagnose possible cause of problem.
Thanks.
Posted on Oct 09, 2010
  • Shahid Electronics
    Shahid Electronics Oct 09, 2010
    LC - 30HV4U
    Power indicator does not come On.
    OK, how old is this tv and how long it started this problem?
    Do you hear relay click when plugged in tv in wall socket?
Mitsubishi tv 32 inch model number cs40505 won't turn on
Check its power regulator board. Check fuse. replace it as card basis, if found irrepairable.
Jun 14, 2012 | Mitsubishi CS-40505 TV
Vizio power supply
You can look for one at places on the internet with the model number like shopjimmy.com.
If you want to try to fix it yourself look to see which is cheaper--fix or replacement.
I will presume you can safely get set apart and have looked at the filter caps on that board.
Jun 11, 2012 | Vizio L32 32 in. LCD HDTV
Red light flashing on my tv and won't come on
replace the power supply board. You should be able to get the replacement power board from www.tvcircuitboards.com send them a email customerservice@tvcircuitboards.com if you dont see it listed as they only list a few of the boards they carry
Mar 03, 2012 | Polaroid 3211TLXB 32 in. LCD Television
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
Baird lcd 32" model x32
This is a protection circuit that prevents the tv from coming on (to stop damage of the components) ....you need to check your voltages off the power supply and make sure they all read well (EX: 24v12v5v etc). Also look for popped capacitors that would make the values lower than need be for the tv to power on properly.
Once you repair the power supply then you may need to replace other components if needed (EX: backlight inverter)!
Please rate if this helps! :D
Replacing capacitors is ALWAYS the cheaper option, but you need to have experience it, or you'll create more damage than good!
May 06, 2011 | Televison & Video
No picture on the screen but light is on
that tv is very common for power supply failures. there will be several bulging vented capacitors on the power board. the capacitors are used for filtering in the power supply so they would smooth out the ouput of the certain switched supply circuit they are part of. easiest way would be to replace the power board otherwise with some minor soldering skills replacing the capacitors is cheaper route.
Jan 06, 2011 | Vizio L32 32 in. LCD HDTV
Purchased a 32"Protron FLat Screen from SHOPNBC.com and the power light comes on but no picture; now it wont' come on at all.
Your partial resonance power supply IC chip with IGBT switch is bad. On your model of TV it will cheaper to replace the whole power supply module
Aug 20, 2010 | Protron PLTV-32 Television
My Emerson HDTV 32 inch sound stopped working all together. The picture is fine, but there's no sound.
everything with sound picture av component has to do with the main board of the tv not the power supply the only thing you can do its replace the main board not the power supply board or anything else cause it may be only a resistor or a capacitor but to replace it the guy that comes to do it will charge more than replacing it go to www.shopjimmy.com and check your tv model and it will give you what you need and the price and cheaper than the manufacturer
Apr 13, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Was turning on and off before it would stay on. now it won''t even turn on
This is a power supply board problem.
I fixed this problem by replacing the board. The model number for my board is EAY42539401. It cost me $55 plus shipping. A Google search for the board model number should bring up a few suppliers.
I recommend fixing it yourself if you can (all you need is a screwdriver). Replacing it yourself is MUCH cheaper than having it repaired. I purchased it from ModusLinkPTS.
http://www.moduslinkptstvboards.com/EAY42539401-P10344.aspx
Oct 12, 2009 | Vizio VP322 32 in. Plasma TV
Vizio tv clicks on and off for a while untill it warms up.
I recommend fixing it yourself if you can (all you need is a screwdriver). Replacing it yourself is MUCH cheaper than having it repaired. It took me about 45mins to fix (all the srews). I purchased the board from ModusLinkPTS.
Oct 07, 2009 | Vizio VP322 32 in. Plasma TV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
