Question about Black & Decker CD9600SBGB 9.6 Volt Drill With Gift Bag [Misc.]
Chuck on my drill is stuck open and I cannot close it to put in a new bit
  • 30 Answers
If the chuck is stuck open and you cant "muscle" it closed something is probably jammed up in there and it needs to be replaced. Chucks take a good share of the abuse on power tools and most manufactuers consider them a "common wear item" like brake pads or Tires on your car. A chuck is fairly simple to replace if your drill stuck open and they are commonly replaced on the higher end "Industrial Grade" Power Tools like DeWalt and Milwaukee.
Looking at the Make and Model of your drill it would probably be easiest and most cost effective to just replace the entire drill. If you tried to replace the chuck and found a chuck that will fit your tool it may cost you anywhere from $25 - $40. For Around $40 you can purchase a new drill with a fresh battery.
Posted on Oct 10, 2010
  • jvdavis Oct 14, 2010
    Same problem here except this was the 2nd time I used it. Not happy.
  • darbill737 Feb 09, 2011
    I have two 3/8 reversing B
I have a Milwaukee M18 cordless drill with a bit broken off inside and the chuck won't open.
Put your drill into reverse, and hold the chuck. With luck, that will loosen the chuck and the broken bit will fall out.
Jul 17, 2015 | Milwaukee 2610-20 18V Cordless M18 High...
The Drill came with a phillips/screwdriver bit. I don't know how to insert it. I don't know what drill bits to buy and how to insert them either. My model doesn't have a chuck key or side handle.
Most new cordless drills don't have a key. Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Drills
How to insert bit for Black and Decker 3/8 Variable Speed Reversing Drill.
Most new cordless drills don't have a key(keyless chuck). Put the drill in reverse and hold tight to the chuck barrel, pull trigger and the chuck will open. Opposite to close/tighten Best I can do with info provided
Apr 15, 2015 | Speed Drills
The chuck on my new makita drill is stuck with a drill bit in it. It won't open back up.
This is caused by tightening the chuck using the drills power, if you clamp the bit in a vice and using a pair of multi grips on the chuck in an anti clockwise direction gently bounce the grips and after a few tries it will undo, don't use too much pressure or try to unwind it in one move or myou will damage the chuck sleeve
Oct 16, 2012 | Makita Drills
I have just purchased a Makita 8391DWPETK 18V Cordless Combi Drill - how do i actually put a drill bit in? Do I need to take off the plastic ring?
The large black part of the chuck should turn left and right to extend (close) and retract (open) the three chuck teeth that hold the bit in place. Turn the chuck to open it far enough to get your bit fully in the chuck then turn it closed to hold the bit in. When the teeth make contact turn the chuck a bit further to get it tight enough that the bit won't slip. When you get used to it, sometimes it's easier to hold the chuck lightly and turn it by lightly squeezing the trigger to turn the chuck with the drill motor.
Feb 25, 2012 | Makita Drills
Mybrand new RZ20 keyless chuck will not close around a bit.
If a large enough drill bit is inserted too far so it bottoms in the chuck, the jaws run into the bottomed shank and will not close beyond a certain point due to the interference. If you hold the drill bit out about 1/2 inch from the bottom, the jaws should close on the bit. I assume you have tested the chuck without a bit to verify they can close.
Feb 15, 2012 | Drills
How do I open the chuck or drill mouth to replace the drill present in my DeWalt Heavy-Duty 3/8? Keyless Chuck Drill?
Hi Tony,
To remove the bit with a keyless chuck, just turn the chuck to the right (looking from the handle to the front) to open the jaws. To put in another bit, tighten the chuck to the left to close. You have to use both hands. You will see where the ridged portion of the chuck is in two sections. Hold on to the back section with your left hand to keep it from turning while you turn the front section with your right hand.
A lot of the time I just push the button to put the drill in reverse, hold on the front section of the chuck and turn it on. It will loosen by itself. Then when you put the new bit in, put it in forward and hold on to the chuck and press the switch. The bit will be in nice and tight.
Good luck.
Please place a vote when you accept this solution.
Thanks,
Handie Andie
Aug 19, 2011 | Dewalt Drills
A bit is stuck in the chuck of my Bosch drill
Hello. Wrap a towel around the chuck and use a pipe wrench or a pair of channel locks to put a little force on the chuck. J.
Jul 19, 2010 | Bosch Drills
How do I attach the drill bit to the chuck on a ss 120 drill
Well I couldn't find a pix of your drill so I will guess that it is a typical drill. You seem to be asking a very basic question so I will start will all the basic info I can think of.
First you have to know where the power trigger is to make it go.
2nd you have to know where the forward and reverse switch is.
Now with the switch in the forward position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the center Jaws should close up and come out of the chuck.
Now with the switch in the reverse position squeeze the trigger to make it go. Then gently grab the chuck with your hand while it is going and the cetner Jaws should open up and go into the chuck to a maximum point
Open the jaws enough to put the drill in the jaws then put the switch in the forward position. Put the drill in the chuck, sqeeze the trigger to make it go, and hold the chuck so the jaws close on the drill. All while keeping the drill from falling out of the chuck.
When it closes on the drill and the drill is in straight then hold the chuck as tight as you can while squeezing the trigger to make the jaws close very tightly on the drill. If you have very tender hands you might want to use gloves.
To get the drill out put the switch in reverse, hold the chuck very tightly, and squeeze the trigger to open the jaws off of the drill.
Nov 28, 2009 | Black & Decker Drills
How to unlock the chuck
this how to get a chuck off a drill.look inside the chuck for a screw. it will be a left handed screw.once you get the screw out put the chuck in a vice . you will need to squeeze it very tight. then put the drill in reverse and pull the trigger.if i wont come off you will need to hit the chuck with a hammer while you are holding the trigger. if you have a bit stuck in the chuck and cant get it out put the chuck in the vice and hit it very hard with a hammer until the chuck falls apart.i work on drills every day ,this is the only way we have found that works
May 30, 2009 | Milwaukee 0612-20 14.4v Cordless Drill Kit...
Black & Decker CD9600SBGB 9.6 Volt Drill With Gift Bag [Misc.] Logo
970 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
