Question about LG WM2487HWMA Front Load Stacked Washer / Dryer
Hi ,My LG washing machine WM 2487HWM won't start to run when I click the on button.
SOURCE: LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Posted on Nov 30, 2006
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
SOURCE: my washing machine does'nt start
Had that problem before. CL means child lock. You need to press the wash and rinse buttons together to unlock.
Posted on Apr 03, 2008
SOURCE: LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
Posted on Dec 14, 2008
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
Posted on Jun 16, 2009
When i wash it smells like rooting eggs i tryed bleach and the tablets but smells up the hole house what wrong its a lg tromm wm-2487hwm steam washer
I had the same problem. You must take out your clothes immediately and leave the door open after every wash to let the inside of the washer completely dry. I believe I read to run a cycle of bleach water and wipe down the inside of the door and interior with bleach/water mixture. Then let it dry. You then can start washing your clothes again, but you must be diligent about leaving the door open to air out between washings.Hope this works for you. I almost sold my machines shortly after I bought them because my clothes were always smelly after washing. Leaving the door open has worked for us.
Dec 18, 2012 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
SERVICE MANUAL FOR LG WM-2032H Front Load Washer
Hi dear.If you know what you are doing,please click the link below.Ihope thathelps.Thanks. http://dl.owneriq.net/2/2d746ee4-b30a-9074-b554-f3ce77a57775.pdf
Apr 03, 2010 | LG WM-2032H Front Load Washer
I own a lg wm-12336fd washing machine and the display it is showing cl and will not allow it to run any programs
That is CHILD LOCK...Just press at the same time buttons from the lest and right of the child picture and hold it for a little time and it will unlock..
Nov 01, 2009 | LG WM-2277HW Front Load Washer
LG WM 12230FB WASHING MACHINE
the belt which s at presently fixed is not of proper size change the belt and try it. the drum will run properly
Jul 06, 2008 | LG WM-2277HW Front Load Washer
My washing machine does'nt start
Mar 23, 2008 | LG WM-1480FHD Front Load Washer
LG WM2487HWMA Front Load Stacked Washer / Dryer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
