Question about Maytag Neptune FAV6800AW Top Load Washer
I am looking for the Use and Care guide for Maytag Neptune TL, model # FAV 6800 AWW. How do I go about getting ity?
  • 8,197 Answers
You can get the manual on the link below.
http://www.ajmadison.com/ajmadison/itemdocs/PDF_MAY_FAV6800A_user.pdf
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 09, 2010
How can i bypass my maytag neptune TL aww lid lock???
You will need to open the switch and short the switch using a wire, if what you meant is that there is a switch failure which will not start the program and so the motor will not start on the machine.
Mar 14, 2012 | Maytag Washing Machines
Maytag neptune Model # mdg5500 AWW when i push
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 10, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
I NEED A OPERATING MANUAL FOR THE NEPTUNE TL FAV 6800AWW
Here is the Service Manual link on this site. You can also pull from servicematters.com.
It covers the FAV6800AW and FAV9800AW it also has the Use and Care guide.
Nov 14, 2009 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune TL fabric softener cup seems to be clogged, what do I do?
If your machine is a FAV6800AW/FAV9800AW see if this post will help you. Once the Fabric Softener top is removed you can flush the dispenser and run some pipe cleaners thru the exit ports to help remove gunk build up.
If there is a water flow issue into the Fabric Softener dispenser then further investigation may need to take place. I discuss how I would start the troubleshooting for that as a possible issue.
The Service Manual for reference use and care guide has some info
Rich
Nov 01, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Wont spin with clothes
Common problem with this model I own it. Sounds like the roller clutch bearings in your machine are seized/rusted up. Do you want to try to DIY the repair? Read thru this post for the details of what is involved. Post back with any questions. Rich
May 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptne fav 6800 aww does not fill wiht hot water. works fi
Hi Big Wags
I would remove both water hoses at the back of the washer and check the Hot & Cold inlet screens for a clog/restriction.
They look like this;
You can turn the individual valves on in service mode using the procedure on page 16 of the Service Manual.
To enter Service Mode; press and hold simultaneously the Enviro Plus and Spin Only keys for three seconds or until the control beeps and the display reads “00”.
Now go into board output test by pressing the Delicates key.
Now press the Normal button to open the Hot Water Valve you can press the Normal button again to turn off the valve or just press the Off button to end the process. Or just use the wash cycle to toggle the H/C water valves on. I like folks to become familiar with using Service Mode and the SM.
If the inlet screens are free of debris and you have good water pressure from your source valve then you may have to replace the valve assembly Here is a link to check for FAV6800AW PARTS Sears Parts Direct. Shout back If you have questions. Rich
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
117 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
