Question about Kenmore 44042 Front Load Washer
I have a Kenmore front load washer that will not spin all the water out of the clothes. After it finishes I have to run it through a rinse spin cycle and it does fine. The machine is only 14 months old
    Scholar:
  • 42 Answers
The first thing to check is probably the filter at the bottom of the machine. I'm not sure about this particular model, but the usual thing to do is to remove the machine's front lower panel - i.e. the panel at the front of the machine, closest to the floor.
You will probably find a little drawer or door, just a couple on inches in size. If you open it, you may find some lint, a couple of elastic bands, and enough coins to buy a beer. If so, it's the coins that are causing the problem! Take out all the stuff, close the little door, put the panel back on, and everything should run fine.
I hope that helps. Good luck!
Posted on Oct 09, 2010
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Kenmore top load washer 29822800 - washer-selector is set on one rinse- when machine starts the agitator starts immediately as water fills - then when machine stops after spin cycle in off position water...
if you are saying that the washer finishes the load of clothes and timer goes to off and water is filling the tub after this then you have a bad water valve on the back of the washer.disconnect the water lines and change out the valve
Aug 14, 2010 | Kenmore 24032\24036 Top Load Washer
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Machine won't spin clothes dry. I've tried the
remove the lower front panel and look to see where the electric pump hooks up to a hose and than the hose to the tub probly have a small article blocking the drain
Aug 09, 2009 | Kenmore HE2 Plus Front Load Washer
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Takes almost 2 hours to complete a wash cycle
Have you ever cleaned it out? Its likely due to a plugged drain, not allowing the system to drain fast enough for the normal cycle. Check out my solution on
http://www.fixya.com/support/t114322-kenmore_elite_h3t_washer
-Todd
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore washer series 80, Clothes still soapy
If you are getting no water spray during the rinse cycle that would cause the soapy clothes issue.
Are you getting cold water during the wash/rinse cycles? If you have the machine set to warm/warm you may only be getting hot water while the final spin is calling for cold.
If you have cold water available then the timer is not calling for the water spray. The problem is either in the mixing valve or the timer.
Jan 10, 2009 | Kenmore 23822 Top Load Washer
While the washer drains and spins, new water comes in
Drain hose must be at least 30 inchs above the floor.
Jan 06, 2009 | Kenmore 24032\24036 Top Load Washer
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore elite washer problem
sounds as if you have a drain issue, most common cause of fault is theres something stuck in the pump housing. remove the lower acess panel(3 screws along the bottom of the forn of unit) youll gain acess to the pump housing, remove the large cover to the "button trap" by uncscrewimg the cover, it will be righthin front of you in the center of machine when cover removed, im sure youll find your blockage within there
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 44042 Front Load Washer Logo
57 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
