Question about Olympus WS-100 Digital Voice Recorder
The lock function turned on for all files on my WS-100 and I can't get it turned off - therefore I can't record any new files or erase any old files. I've followed the directions in the manual but when I to the "lock" function on the menu I get a flashing "01" rather than the flashing "ON" or "OFF" that the manual says should appear. When I press "play" to activate the turn off or turn on feature for the lock, I just get a double beep and it won't allow me to change that setting. The menu seems to work fine for all of the other features. I've heard that other folks also seem to be having problems with this one feature. Seems pretty serious since it renders the recorder useless.
  • picarobe Oct 09, 2010
    I've already tried that a couple of times and it doesn't solve the problem. I even tried adding new batteries.
    The lock function turned on for all files on my WS-100 and I can't get it turned off - therefore I can't record any new files or erase any old files. I've followed the directions in the manual but when I to the "lock" function on the menu I get a flashing "01" rather than the flashing "ON" or "OFF" that the manual says should appear. When I press "play" to activate the turn off or turn on feature for the lock, I just get a double beep and it won't allow me to change that setting. I've tried the obvious fixes of powering off and on, removing/replacing batteries, etc... The menu seems to work fine for all of the other features. I've heard that other folks also seem to be having problems with this one feature. Seems pretty serious since it renders the recorder useless.
    President:
  • 2,777 Answers
Yes this is a serious hardware malfunction that locks you out of the device. I would suggest you take the batteries out of the device and let it sit a good 48 hours with no power to hopefully force it to do an internal reset. Otherwise the unit has unfortunately failed.
Thanks
Tim
Posted on Oct 09, 2010
    Genius:
  • 1,478 Answers
I will advice you remove the battery from your device and fix the battery back, now power on, see if it still display lock.
Take care.
Can't erase on my olympus WS-100
Do you plug into your computer? If so, you can erase from there.
Does your recorder have a "format" setting? That will erase entire contents.
May 26, 2015 | Olympus WS-100 Digital Voice Recorder
The lock function turned on for all files on my WS-100 and I can't get it turned off - therefore I can't record any new files or erase any old files. I've followed the directions in the manual but when I...
Try to reformat your device( do not use a PC.) instructions are in your operators manual...it will mean you will lose all recorded information but at the moment you cant use the machine anyway.
Oct 09, 2010 | Olympus WS-100 Digital Voice Recorder
How can I format? I lost the intenal files
Hello Press the FOLDER button to choose a folder
Press and hold ERASE button for 3 seconds or longer.
The ERASE indicator will flashes
Press the ERASE button again.
Done blinks for two seconds and the deletion will be complete
Note AN erased file cannot be restored.
During this process don’t remove batteries. Otherwise data may be damage.
The recorder should be formatted using only by using the internal FORMAT function found in the recorder's Menu. Formatting using the computer may corrupt system files needed to run the recorder, so computer formatting is not recommended
Apr 23, 2010 | Olympus WS-100 Digital Voice Recorder
My WS 100 says FULL and won't either let me put it
The recorder should be formatted only by using the internal FORMAT function found in the recorder's Menu. Using a computer to format the recorder may corrupt or delete system files needed to run the recorder, so formatting via the computer is not recommended.
Individual files can be deleted from the recorder while it is connected to a computer without negative effects.
Feb 04, 2010 | Olympus WS-100 Digital Voice Recorder
TURN OFF LOCK. I AM IN MENU MODE, BUT WHERE IS THE ON/OFF BUTTON LOCATED?
Power on…Turn the POWER switch ON.
If the POWER switch on the backside of this recorder is
turned OFF, it is not possible to use any of the functions.
Turn the POWER switch ON before operation.
Power off…Turn the POWER switch OFF.
Standby Mode and Display Shut Off
If the recorder is stopped for 5 minutes or longer during recording or playing, it goes into
Standby (power-save) mode, and the display shuts off. To exit Standby mode and turn on
the display, press any button.
Locking a file keeps important data from being accidentally erased.
Locked files are not erased when you choose to erase all files from a folder.
In Menu mode selection... On, OFF
On: Locks the file and prevents it from being erased.
OFF: Unlocks the file and allows it to be erased.
Feb 02, 2010 | Olympus WS-100 Digital Voice Recorder
Plzz
Formatting the Recorder (FORMAT)
If you format the recorder, all function settings will return to their defaults.
All files stored in the recorder will be deleted.
If you have important files that you want to save, connect the recorder to a computer and
transfer those files from the recorder to the computer before formatting the device.
1 Press the MENU button.
2 Press the FF or REW button to choose “FORMAT”.
3 When the PLAY button is pressed, “nO” is displayed.
4 Press FF or REW to select “yES”, and press the
PLAY button.
After “ARE yOU SURE” is displayed, “nO” will be displayed.
5 Press FF or REW to select “yES”, and press the
PLAY button.
“DONE” displays when formatting ends.
s It may take up to several tens of seconds to finish the initialization. Do not remove the battery or detach
the battery compartment from the recorder during that time. Otherwise data may be damaged.
s Never format the recorder from a PC.
s When the recorder is formatted, all the stored data, including locked files, are erased.
Nov 08, 2008 | Olympus WS-100 Digital Voice Recorder
Can't unlock my locked digital recorder
format the recorder through the menu and this will erase all the files
Sep 25, 2008 | Olympus WS-100 Digital Voice Recorder
Editing? Can dictation be paused, then go back part way and....
you can not do this with the Olympus ws-100, you need a dictation machine that has the editing function which allows you to easily insert, overwrite, partially erase files and continue on the same file, most of the digital dictation units have NEW FILE BUTTON , you will stay recording on the same file till you press new.
Look at Olympus DS-2300. Olympus DS-33300 or ds-4000.
Apr 23, 2008 | Olympus WS-100 Digital Voice Recorder
Is it possible to stop recording without opening a new file?
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Olympus WS-100 Digital Voice Recorder Logo
75 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
