Question about Dewalt Dw087k Selfleveling Line Laser Dw087k
How do i calibrate a dw 087k laser - Dewalt Dw087k Selfleveling Line Laser Dw087k
  • 30 Answers
Here is a link for the owners manual for that particular laser. http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/593338-00,DW086.pdf
In there are the instructions for a Field Calibration Test. These units should be sent to DeWalt Factory Service for Calibration. If the unit is less than 1 year old they should calibrate it for free under their "1 Year Free Service" warranty.
Posted on Oct 10, 2010
How do I calibrate dw-94c
You can only check to see if it is calibrated, you cannot change the calibration. To test it you need a kit that contains precise weights and you place them on the scale to see what it says. If it is out of calibration, you would have to send it in to have it re-calibrated. If it is being used in a commercial application then it has to be tested yearly by the government and if it fails, they would tell you where it could be repaired at.
Dec 18, 2017 | Dishwashers
How do you calibrate a laser distance meter?
Calibrating a laser distance meter is not all that complicated. eHow.com has a really good guide. How to Calibrate Laser Distance Meter eHow
Jan 22, 2014 | Measuring Tools & Sensors
How to calibrate a hilti pri 2 laser
There is no "calibration mode".
To check calibration set the tool on a fixed surface. turn it on. let it autolevel, then mark the wall with a pencil at a distance of 15- 20 feet. rotate the laser on its axis 90 degrees, and see if it self levels to the same line. if it does not, send it to hilti, you'll have it back in a week.
Nov 13, 2012 | Hilti Laser Level. Rotating Laser PRI 2...
DEWALT DW079 LASER LEVEL CALIBRATION
You can not calibrate the Laser in the field it needs to be sent to a dewalt service center however you can check the calibration to see if it is off
download the manual here with instructions on how to check it
Jan 04, 2012 | Measuring Tools & Sensors
How to calibrate spectra precision ll500 laser
There are two brass screws under the upper most metal plate. They are the calibration adjustment screws. The manual tells you how to do a peg test. If your peg test is out, move the corresponding screw until you reach the calibration point you want.
Sep 29, 2011 | Spectra Precision Laser LL500 Exterior...
Dewalt laser dw087 is blinking and cannot self level anymore (I assume)
this unit does not have any replaceable parts, if the unis is covered by warranty, it would be exchange, if not then check with your local servicenter the max rate program to do so.
Aug 30, 2009 | Dewalt Self-Leveling Line Laser...
Power Calibration error
powe calibration error reffers to lens laser power
in other words the laser doesn't have enough power to write CD/DVD at specified speed
try to clean the lens (there are special CD-s for that)
and try to burn the cd or DVD at slower speed
but slowly your cd writer is dying
Jul 08, 2009 | Sony Computers & Internet
CDJ Laser Alignment/Calibration
They dont normally go out of focus, any trouble reading discs / freezing is usually caused by a worn out laser which will require replacement.
Jul 22, 2008 | Pioneer CDJ-1000 CD Player
Ps3 laser
hi the problem with this is replacing the laser is the easy part and more or less anybody can do it but to get the new laser to work you need to calibrate it this is what the osciloscope is for it needs to be connected to certain parts of the board and then take readings from the scope as your adjusting the laser you cant do this without it as you can damage the new laser if you get it wrong.
Now you can fit the laser yourself thats the easy part but the scope costs about £1000 or $2000 so more than a new ps3.
If you can buy a working laser out of a damaged ps3 thats over heated then you should find it will work as sonn as you fit it in but new ones need calibrating.
Try this so you get some idea of the procedure with the scope use your search engine and type in:
how to calibrate ps3 laser
or
how to calibrate ps2 laser
this will then bring up loads of sites that show you how its done with the scope.
Its not worth doing it without the scope as you will damage the laser beyond repair but buy the new laser and get someone to fit it and calibrate it for you as that would be the cheapest sollution let me know if you need further assistance ok
Mar 14, 2008 | Sony Playstation 3 (PS3) Console
Numerous errors when attempting to burn dvd's
1. go to device manager / right click on cd drive / uninstall driver / reboot and windows will reinstall driver 2. go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer
Nov 11, 2006 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Dewalt Dw087k Selfleveling Line Laser Dw087k Logo
2,470 people viewed this question
Top Dewalt Measuring Tools & Sensors Experts
ka4iup
ka4iup
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Dewalt Measuring Tool and Sensor Expert? Answer questions, earn points and help others
