Question about Videoseven Slim Line L15CM (White) 15" LCD Monitor
Hi,while using monitor goes off this after 3 minutes, turning it on again -off. seems adapter causes that problemd?! Thanks for you reply Masha Cohen.
Where can I find a driver/adapter for Advent X19W LCD Monitor?
Goto device manager , uninstall the card. go into control panel and check that the driver is uninstalled from the programs list. Swich of the pc for a minute or two then reboot Windows updares does not download drivers for graphics cards so will not install or reinstall the driver that is causing the issue, 307? Users forget to uninstall from program manger in control panel which is why the card keeps reinstalling with the undesired driver.
Please let me know what happens
Dec 14, 2014 | Nvidia Computers & Internet
I have a couple VHS-C tapes that drag
This may be caused by a faulty adapter. 1. try playing in the camera. 2. try a different tape. 3. try a different adapter.99% this is a problem with the adapter or the tape. It really sounds like the tape isn't turning freely, which can be caused by a brake sticking, or spindle in the tape or adapter.
Mar 16, 2012 | Televison & Video
Kds K-92bw After about 5 min the screen goes blank..turning the unit off than back on the screen looks great for a while about 3 min than goes black..seems to be a caused by heat
This issue is most likely caused by a capasitor doing bad. There is no easy fix. It must be disembled and the power supply repaired. If done properly, it should cost somewhere between $ 50 to $125. But it may do it again as the Pwoer supply is a known issue for this monitor. Sorry.
Sep 21, 2011 | KDS K717s 17" LCD Monitor
Monitor switches off!
An internal circuit may be failing.
Jul 03, 2017 | Neovo E-17DA (Black) 17" LCD Monitor
Viewsonic ve150m problem white screen
Are you still using the same computer that was set to 200Hz? If so, start Windoze in safe mode and reset the display properties to 1024 x 768 60Hz. Reboot the computer and everything should be OK.
Does this model use an external ac adapter or an internal power supply? Twice I have seen a white screen caused by bad capacitors in the power supply. They may look good, but you should replace them anyway. Look in the 2ndary circuit of the power supply, you should see some capacitors that are (for example) 220uF 16 to 25V, 470uF 16 to 25V, 1000 uF 16 to 25V (all those capacitors could be 16V or 25V). Replace them and try the monitor again.
If it uses an ac adapter, try a different 12V adapter. Make sure it has the same or higher amperage rating. If you can't find one, you will have to measure the power going onto the board inside the unit while the adapter is plugged in and the monitor turned on. If it is less than 12V you need a new adapter.
If none of this helps, the panel or main board may be damaged. In most cases these two parts cannot be repaired.
Jan 22, 2009 | Epson Viewsonic ViewPanel VE150M Monitor
The power turns off automatically after several minters
Hi...there,
It's seems your backlight inverter it about to burnt out... 3 years old! It's time for a new inverter.
Nov 20, 2008 | Acer AL1913 19" LCD Monitor
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Apr 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
LG Flatron monitor problem
It is often difficult to diagnose/repair an intermittent problem. It could very well be any of the circuitry and components inside: video interface, CCF Lamp, inverter, power supply. All of which would require that you open the casing and poke around inside and that you be familiar with electronic components & circuitries, soldering and use of a continuity/volt meter.
Doing so would void your warranty (being just a couple of months). Perhaps your best bet would be to seek repair/replacement of the monitor from your dealer/supplier and describe fully the nature and frequency of the incidence. It may be that when they test it will check good.
Should you choose to open it up yourself, post back.
Good luck and kind regards.
Oct 23, 2007 | LG Flatron L1750S 17" LCD Monitor
Screen goes black after a few minutes, switching off and on and picture returns then goes black again
I have problem with my monitor, it is automatically switching off and switching on for 2 to 3 minutes for every 15 minutes why ?
Please mail me the solution to craju1@yahoo.com
Oct 21, 2007 | Relisys RLT1720 17" LCD Monitor
Videoseven Slim Line L15CM (White) 15" LCD Monitor Logo
43 people viewed this question
Top Videoseven Computers & Internet Experts
David Payne
David Payne
Are you a Videoseven Computer and Internet Expert? Answer questions, earn points and help others
