Question about Garden
STIHL HS74 BLADE ASSEMBLY - Garden
  • 1,807 Answers
My HS 45 seems to drip oil while cutting, I think it is damaging plants. Is it because there is too much oil in the fuel mix?
Fuel mixture for that model is 50 to 1. Stihl also sell their own premixed fuel and oil which is Ethanol free and non aromatic.
I wondered if it has a blade oiler, but it doesn't. I does however have a gearbox with oil in it. I wonder if it is leaking. Do you know where the excess oil is coming from?
You model is listed here and the Manual and details of the fuel are on his page.
STIHL HS 45 HomeScaper Series Hedge Trimmer
Oct 04, 2016 | Stihl Hs45, Hs 45 Hedge Trimmer 450mm 18"...
Hi, i am Florencio Valiente looking for grass cutter spare parts please help me to it. STIHL FS55C.. unit cranck shaft assembly, 1 set spiral gear asssembly pls. advice..
New Stihl are sold by the local dealers only per Stihl policy.
I couldn't parts labeled Spiral gear so that maybe just a description problem here.
As for the crankshaft you will need know which version you have. Affects ignition timing.
Feb 08, 2015 | Stihl Garden
Replace fuel line on stihl hs74
Here's the parts diagram, hope it is of some use.
May 19, 2014 | Stihl Hs74 Fuel Tank Part 4226-350-0400
The blade will not turn
is the cutting attachment attached to the drive shaft assembly properly
Apr 17, 2014 | Stihl Edger Blade
Stihl hs86 set blade gap
You shouldn't have to set a gap.. the gap between the blades is 'pre-determined' by a spacer between the blades that each 'blade bolt' passes through. You should be able to tighten up the blade bolts and the blades should still move. If they dont, then the spacers are worn and need to be replaced.
Apr 02, 2014 | Stihl Hedge Trimmer Pruner Cutter Blade...
Motor runs but blade stops 1" into the wood
Seems like it could be a clutch/drum issue. I have known clutches to break through the threads in the crank shaft so they appear tight but are actually broken. I'd look at the drum assembly to see why the drive to the chain is slipping.
Feb 17, 2013 | Stihl 009/010/011 Clutch/sprocket
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Stihl fc 44 edger blade not moving when I press the throttle
check both where the shaft attaches to the motor and also to the guard housing. they sometime vibrate loose and need to slide back in place. also the clutch can wear out.. try the shafts first...
Sep 07, 2012 | Stihl Fc, 36, 40, 44 Trimmer Edger Clutch...
Replacing trimmer line with blade for stihl fs 90r trimmer
If you bought the trimmer new there should be a rod about 6" long and 1/8" thick. Above the trimmer head below the trimmer gearbox there is a hole. You have to put the rod in that hole and turn the head until that locks it from turning.
From there you can screw the trimmer head off by hand, or a strap wrench if it's really tight. It may be left hand threads.
Mar 25, 2010 | Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
