Question about Minolta Cameras
I have an older Minolta 50mm AF lens that sticks wide open. If I tap the side of the lens, it will shut, but my Sony a550 cannot control it. What can I do to fix it? The camera runs my other two lenses fine.
  • 21 Answers
Having been there with an older Minolta lens, I'd guess the lubrication on the iris has thickened to the point that the leaves are sticking open (normal position except during time when shutter is open). Time to find a local Minolta/Sony authorized repair shop and have it cleaned and lubricated.
Posted on Oct 16, 2010
Hi where can i get instructions on how to use my nikkon 50mm prime lens?
That depends on the lens in question.
50mm f/1.8 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50mm.pdf
50mm f/1.4 AF-D:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AF50f1.4D.pdf
50mm f/1.4 AF-G:
http://www.nikonusa.com/pdf/manuals/lenses/AF/AFS50G.pdf
May 24, 2011 | Nikon 50mm f/1.8 AF Nikkor Lens
I have a Nikon D40x and purchased the AF nikkor 50 mm f/1.8D lens a couple years ago, but find that it can only be focused manually. Is there any way to "turn on" the autofocus? I have not had...
Sorry, but the D40x lacks an autofocus motor, depending on the lens to have one. Nikon calls such lenses AF-S. This particular lens does not have such a motor, relying on the camera to have one. The only 50mm lens currently available with an autofocus motor is this one:
http://www.nikonusa.com/Nikon-Products/Product/Camera-Lenses/2180/AF-S-NIKKOR-50mm-f%252F1.4G.html
Earlier this week the Nikon web site listed a new 50mm F1.8 lens with an autofocus motor, but then it was removed. Hopefully they will officially announce this lens soon.
Apr 14, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
What size lens do i need for this camera?
You just need any Minolta AF mount lens. Sony Alpha lenses also physically fit as Sony inherited the Minolta lens mount when they bought the company, but as they are a later development not all will be electronically compatible.
The size of the lens depends upon the focal length of the lens and you choose that according to how wide a field of view you desire. Typical lenses are 28 and 35mm wide angles, 50mm "standard" (approximately the same perspective of how the human eyeball sees images), 70 to 90mm short telephoto lenses (a narrower perspective and very good for portraits) and higher numbers are narrower perspective telephoto lenses for viewing increasingly distant objects. In practice, the available lenses will be incorporated into zoom lenses which incorporate a seamless range of focal lengths within one single model. The word "zoom" reflects the fact that you can seamlessly change from say 28mm wide angle through to 80mm short telephoto and every single setting between them
Any zoom which starts at less than 50mm and finishes in the short telephoto range is called a standard zoom and is the lens that most autofocus cameras were supplied with. The next most common size will be something like a 70-200mm which is a telephoto zoom (or tele zoom) and takes you from a portrait lens to a genuine 5x magnification telephoto. You may also find so-called "super zooms" which do the whole job on one, for example 28-200mm. but the more jobs a single lens tries to do, the bigger and bulkier it becomes and the image quality deteriorates due to poorer contrast and greater image distortion at each end of the zoom range.
This is not an exhaustive answer, as there are entire books on the subject, but hopefully it's been of help to you.
Please take a moment to rate my answer or to add a comment if my answer has left you with unanswered questions which need to be resolved before you can rate my reply.
Feb 18, 2011 | Minolta Maxxum 400si 35mm SLR Camera
What size lens fits a Minolta Maxxum 3xi??
It depends entirely upon what you're after and the type of photography you wish to undertake.
Any Minolta AF mount lens will fit. 28mm is a standard wide angle, 50mm is a standard lens with a field of view approximately the same as the human eye, 80mm is a slight telephoto and for distant subjects 200mm is a long telephoto. Some lenses combine a few into one, they're called zoom lenses and will typically be something like 35-70mm, or 70-200mm. The measurements relate to the focal length of the lens, but generally the larger the number the longer the lens sticks out at the front. Zoom lenses are bulkier and heavier than fixed focal length lenses, but they're also the most commonly used types these days.
Sep 03, 2010 | Konica Minolta Maxxum 3Xi 35mm SLR Camera
I have a minolta 7000i non-digital camera with several nice lenses. Are any of these lenses compatible with any new digital cameras?
I am pretty sure that your lenses are just fine for your Digital camera(Minolta or Sony only) as they have the same lens mount. I you choose a KM5 or KM7 digital cameras your lenses will be longer by a factor of 1.4x, same goes for Sony cameras except A850 and A900. They will give you the same magnification ratio as your 7000. Minolta was sold to Sony several years ago, and they have been building a great reputation since. Your AF maxxum lenses will work great on any KM or Sony camera(ADI is available on distance integrated Minolta maxxum lenses only. You can tell by looking at a lens marking which will say "D" if it is compatible with distance integration). I find distance integration an extra not a necessity. If you have some great glass that you love and hold dear, then it would be a great idea to buy Sony. Note that another answer by miket756 is mostly wrong. Yes your lenses will get longer on APS sized sensors, but a 28 mm will never become a 150mm equivalent(thats just stupid). It will look more like 40-50mm on APS-C camera. If you got 2000-2700$ for Alpha850 or Alpha900 than your lenses will retain their mag factors. Good luck.
Oct 26, 2009 | Minolta Maxxum 7000 35mm SLR Camera
I have a sony alpha 100 i want to buy a 1993 minolta maxxum 3xi with 35-70 and 70-300mm lenses. Those minonolta lenses are compatible with my alpha?
I took the following off of the Alpha website
"Sony Alpha lens mount
Identical to the Minolta A-type bayonet mount, enabling the use of a large back catalogue of existing Minolta and third party lenses"
I know that the lenses that fit my son's Maxxum will not fit my non-Maxxum Minolta bodies. VERIFY THAT THE LENS YOU WANT TO MATE TO YOUR SONY HAS THE MINOLTA A-TYPE MOUNT.
Oct 14, 2009 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Sony A100 compatibility
It would help if you actually gave details of the lens!
All the old Minolta AF and MF lenses will fit the Sony A100, but only the AF are auto-focus compatible.
Since the Maxxum 7000 was an AF camera, I would image that that is an AF lens pictured on the front.
Check out this site for more details:
http://www.mhohner.de/sony-minolta/lenses.php
Matt
Feb 29, 2008 | Sony Alpha DSLR-A100 Digital Camera
Sony A100 compatible lenses
Virtually all the old Minolta lenses are compatible with the new Sony SLRs.
For the two you mention, you will need to check whether the lenses are the AF or MF versions.
Both will fit, but AF is the auto-focus one, and MF is (obviously!) manual-focus.
If you want a definitive list with tech details on ALL the Minolta / Sony lenses, look here:
Matt
Feb 28, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
QUANTARAY FOR MINOLTA AF 70-300MM compatibility
Usually mounts are unique to a camera manufacturer. There are exceptions. Sony has the Alpha; lenses for the Konica-Minolta are the same mount. Your AF (autofocus) lens will work on it. You might also consider picking up a Konica Minolta 5D or 7D.....they're no longer made and hence are cheaply had.
The MD and Rokkor lenses won't work on the Sony Alpha.
THIS IS A CHEAP LENS (<$50 VALUE) SO I WOULDN'T LET IT DRIVE YOUR DECISIONS!!
Jan 19, 2008 | Quantaray 50mm f/2.8 AF Tech-10 for Canon...
Flashing " F EE" in the control panel
The setting should be the the other end of the scale, I.E. f16,f22. The lens needs to be at the smallest aperture opening size, not the wide open setting. The lens does have a small tab that will lock the ring in that position.
Jan 13, 2008 | Nikon Normal AF Nikkor 50mm f/1.8D...
Cameras Logo
243 people viewed this question
Top Minolta Cameras Experts
David Payne
David Payne
pontelemon
pontelemon
Tony Parsons
Tony Parsons
Are you a Minolta Camera Expert? Answer questions, earn points and help others
