Question about Cameras
I have a photosmart m547 camera and the flash will not work battery is ok, will take photos without the flash
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 480 Answers
Hey sheila-day,
I would make sure you have not inadvertently turned the flash off. When the camera is set to picture capture mode press the flash button, which looks like a jagged arrow, and use the left/right arrow keys to set the flash to the desired setting which I would suggest just leaving it on auto flash mode. If this doesn't work I would try resetting the camera back to the factory default setting, which can be done by removing the battery and the memory card and waiting at least 5 seconds and then reinserting them. If neither of these options work I would have it looked at by an authorized service technician. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Posted on May 30, 2008
Your service is free??? as advertized or did I reach another come-on?? batteries charged, camera battery that operates other functions working, but blank lighted screen, no response from other buttons,...
Try this...remove the battery and memory card...press every button...leave it alone for 20 minutes...insert the card and then the battery...turn it on.
Dec 15, 2010 | HP Photosmart M547 Digital Camera
Need manual for Photosmart M547 instructions to print digital pictures
Please visit this link to download the manual and user guide for your Photosmart M547 camera.
I will appreciate your feedback and positive rating for this free solution.
Sep 30, 2010 | Cameras
Does anyone know how to use an hp photosmart m547 as a web cam?
It doesn't work as a webcam. The m547 is designed primarily as a still camera, storing images to memory. While it can take videos, it also stores those to memory. It is not designed to stream live video to another device.
Aug 22, 2010 | HP Photosmart M547 Digital Camera
Hp M547 PHOTOSMART CAMERA and no MAC SOFTWARE VERSION!
Just use a card reader to download to a folder you create on your desktop. From there, you can open and view them or import them to iphoto.
Feb 11, 2010 | HP Photosmart M547 Digital Camera
Removable memory chip ?
If you own the camera, just open the battery door and you'll find the battery and the memory card. If you're considering buying this camera and want to know if it uses a memory card, the answer is yes.
Nov 23, 2009 | HP Photosmart M547 Digital Camera
Even with new batteries and they go dead before I take 3 pictures
Yes, there is definitely a fault with your camera.  You should be able to return it for a replacement.  I wouldn't experiment too much with batteries in this camera. batteries discharging this quickly are likely to overheat, causing unmentionable catastrophe.
Dec 11, 2008 | HP Photosmart M547 Digital Camera
HP photosmart M547
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 11, 2008 | HP Photosmart M547 Digital Camera
M547 camera lens will not open
My son has this camera and dropped in the sand this summer. He had the same problem.
I found this blog posting.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Read it. And try all the techniques.
I took the camera to our photo printing store and the guy sprayed it with compressed air. It didn't do the trick but I think it helped. We tried all the techniques in the article. In the end I put some WD-40 in a dish and used a toothpick to drip the WD-40 into the space between the lens barrel and the camera case. I powered on the camera while my son pulled on the lens. He pushed back the flaps and pulled from them. Somehow, after several tries - and I was ready to give up - the lens opened. We still got a lens error message. We kept brushing away and blowing out sand and turning the camera on and off. Eventually it started working. However, the zoom is not working. But we are going to go back to the photo store and have him blow more air into the lens.
Good luck. Hope this isn't too late and helps you.
Aug 10, 2008 | HP Photosmart M547 Digital Camera
Cameras Logo
89 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
