Question about Technics SL-1210 Turntable
When i turn one of my decks on it trips the electric out. ive tried changing fuse in the plug but same thing happens
  • Technics Master
  • 5,351 Answers
Something inside your deck is faulty and drawing excessive current. It could be either the transformer or anything to do with the power supply or the motor.
Posted on Oct 12, 2010
My tefal keeps tripping elcb in fuse board what could be wrong
Next time it happens and it trips.. use a dry towel to unplug kettle, just in case.
Is the base wet? Check the kettle for cracks. Check the cable. Is it damaged? Try replacing the fuse in the plug. Is the steam that the kettle produces affecting lighting or other electrical items around it? Try moving the kettle to a different location.
Aug 05, 2015 | Tefal Irons
Iron works for a little then electricity trips. why would this happen
You have a faulty and possibly a dangerous appliance. It could be a faulty/worn electrical cord. i suggest you get it checked out or throw it out and buy a new iron.
Dec 12, 2012 | Irons
2003 hyundai tiburon dual din JVC touch screen deck installation issues
Hello, Chose another powersource for your device. It is possible that you are tied into a circuit breaker that is constantly resettting. Maybe use an MP3 player for the trip and work on it when you get back.
Dec 09, 2011 | 2003 Hyundai Tiburon
Washing machine trips electric when fills with water
From the symptons described, I would suspect that the heating element is faulty, disconnect the heater, and try it again, if it does not trip, then replace heater.
Please rate my solution.
Thanks.
Aug 15, 2009 | Washing Machines
Dryer trips the fuse box
Hi.
Try running it with the heater disconnected. if it goes o/k then your heater needs replacing
Nov 22, 2008 | Zanussi TC180W Electric Portable Dryer
Sony Bravia LCD TV is tripping the fuse in the house
These things draw a huge surge current when turned on. What size fuse are you blowing? These things can surge 10-12 amps on turn-on. What about a fuse with a reset button. They will take alittle more surge before they go. Don't matter about the insignia working before because the cheaper sets tend to stay powered up more when off....thus not surging on from a dead start. Could you try a different plug on a different circuit/fuse? and see if that makes a difference. If you have a 15 amp fuse, then your pretty close with other stuff plugged in. What size is your service? Do you still have an original 60 amp box with screw in fuses? Is it an old house?
Sep 08, 2008 | Sony Bravia KDL-40S4100 40 in. LCD TV
My TV does not turn on I have a Mitszubushi 60 Inch
The first thing to do is check the outlet that it is plugged into.
Do you have a gfci outlet that may have tripped?
Sometimes the whole circuit that the tv happens to be plugged into may have tripped at the electric panel.
Chek for a blown fuse or tripped circuit breaker.
If that is ok, check inside the tv for a blown fuse close to where the power cord is attached.
If still no power, then it will take a checking of the power supply/power circuit board, which may be something a service person should check into.
Apr 08, 2008 | Televison & Video
Washing machine keeps tripping electric switch
Hiya,
there is a few things that will do this to your electics 1st & formost if your trip switch is tripping off remember this is a safty device to prevent fire so ignoring the problem & switching the power back on to try again could run the risk of fire!!
when the power trips you will need to know at what point in the wash this happens if its when the machine is emptying then it would be a pump issue if the machine is emptying no problem then the issue is more likely to be the motor either of which would need to be replaced if you are having these problems.
on rare ocasions you can spring a leak & if water gets on the electrics this will also trip the power but this is 1 of the least likely posabilatys.. rest assured if the power is tripping off then your home electrics are working fine & to confirm all sockets run from 1 main fuse all lights run from a second main fuse then there is a few other bits that run on there on fuses too i.e. cooker, power shower etc.. remember always get a qualified electrician to work on your electrics to ensure the job is carried out correctly
Hope this helps
Jan 16, 2008 | Washing Machines
Technics SL-1210 Turntable Logo
52 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
