Question about Dell 1100 Laser Printer
Replace roller - Dell 1100 Laser Printer
Posted on Oct 10, 2010
Identical smudges 3 inch spacing
3 inches is approximately 70 or so mm so i would say you have a bad drum on your toner
27mm - charge roller - Replace toner
75mm - Photosensitive Drum - Replace toner
34mm - Developing Roller - Replace toner
39mm - Transfer roller - clean/replace transfer roller
57mm - Fuser Film - Replace Fuser
56mm - Pressure Roller - Replace Fuser
Oct 06, 2014 | HP LaserJet Pro P1102W Printer
Tip
Replace Transfer Roller
If the printer still says to replace transfer roller even after it's replaced, then remove transfer roller and manually turn the gears on the transfer roller a few times. It must get stuck or something. Then replace the transfer roller and it should work.
on Feb 07, 2008 | Dell 5100cn Laser Printer
How to replace pickup rollers
This should help. Good luck !
Cassette (Tray 2) paper pickup and feed rollers
To remove the paper pickup and feed rollers
1 Remove the cassette.
2 Locate the two rollers on the bottom of the paper pickup unit (above the cassette). The pickup
roller is the smaller roller, and the feed roller is the larger roller.
3 Pinch the tab on the end of the cassette pickup roller (callout 1), and pull the roller out.
4 Pinch the tab on the end of the cassette feed roller (callout 2), and pull the roller out.
Figure 6-24 Removing the cassette pickup and feed rollers
Note Always replace the cassette pickup roller and the cassette feed rollers at the same time. Also replace
the separation roller (located in the paper cassette) when replacing these rollers
Aug 14, 2014 | HP Color LaserJet 4600n Printer
Ricoh 430dn error sc565
Pressure roller fusing lamp consecutive full power 3
When the fusing unit is not running in the ready condition, the pressure
roller fusing lamp keeps ON full power for 30 seconds or more.
?? Broken pressure roller thermostat
?? Broken pressure roller fusing lamp
1. Replace the pressure roller fusing lamp.
2. Replace the pressure roller thermostat.
3. Replace the PSU.
May 19, 2014 | Ricoh SP C430DN Laser Printer
How to i clean the drum - there is a mark every few inches when i print
If the mark is persistent on each page and repetitive with very precise spacing, you need to determine which roller it's coming from. It could be coming from the transfer roller, before the fuser, the fuser itself, or the fuser pressure roller. Measure the spacing distance of the mark(s), then measure the diameter of the 3 above mnetioned rollers, multiply by pi (3.14159265) and compare the results to determine exactly which roller is causing the issue, then replace that particular roller. Hopefully it's not the fuser as you'd be better-off replacing the fuser film (main fuser roller lining). The fuser and pressure roller are a pain to source, and run abou $65+ for the pressure roller, and about $90+ for the fuser, not to mention this 2 last rollers will take about 1-1.5 hours to replace. They are not hard to replace using common tools. Don't forget to locate the printer service manual over the internet first.
Jun 12, 2012 | Canon imageCLASS MF5750 All-In-One Laser...
Replace ink cartridge
INK ROLLER REPLACEMENT
If printing is blurry even when the ink roller is in the proper
position, replace the roller.
Ink roller: Type EA-732R
WARNING
APPLYING INK TO WORN INK ROLLER OR USE OF
UNAPPROVED INK ROLLER MAY CAUSE SERIOUS
DAMAGE TO PRINTER.
1) Turn the power off.
2) Remove the printer cover. (Fig. 1)
3) Remove the ink roller by turning it counterclockwise and
pulling it upward. (Fig. 2)
4) Install the new ink roller and press it in the correct position.
Make sure that the ink roller is securely in place. (Fig. 3)
5) Put back the printer cover.
Jun 08, 2012 | Sharp EL-1611P Calculator
Canon LBP5200 displaying Error Code E078 What is the problem?
E078 secondary transfer roller drive
mechanism fault
Possiblle causes:
Check the connector of the roller drive sensor.
Check the connector of the roller drive clutch.
Replace the main drive assembly (roller Drive
sensor).
Replace the drum cartridge (roller drive cam).
Replace the DC controller PCB.
Jul 01, 2010 | Laser Canon imageCLASS 8180C Multifunction...
How do you replace the feed roller on a fujitsu 4097 scanner
Hi Ranji,
Thank you for contacting Fixya.
The life span of the Pick roller is about 200,000 sheets or one year. Use Abrasion counter on the operator panel to estimate when the Pick rollers need replacement. The life span may be decreased by as much as half when carbonless sheets are frequently read. To replace Pick Rollers, please follow the steps provided below:
a. Remove Guide AASY. b. To remove the Pick rollers, turn the stopper counterclockwise. c. To remove the Pick roller 1, move the Pick roller 1 toward the left then lift it. d. Right after removing the Pick roller 1, remove the Pick roller 2 with the same way. e. To attach the new Pick rollers, place the Pick roller 1 from right above the groove for the Pick roller 1. Put the shaft of the Pick roller 1 into the groove. Then, slide the Pick roller 1 toward the right side. A Pick roller 1 has the groove in its rubber. Make sure that the bushing is securely fixed to the grooves. f. Attach the Pick roller 2, then slide the Pick roller 2 to the right. Make sure that the bushing is securely fixed to the grooves. g. Turn the stopper clockwise to secure the Pick rollers.
Hope the above information is helpful.
regards,
TechSatya
May 20, 2010 | Fujitsu M4099D/FI-4990C Scanners
In my Selphy 710, the paper wont feed from the tray to the printer. The rollers are rolling, and the paper gets pushed up to the rollers, but Im not sure if its not gripping the paper, or if the timing is...
sounds to me like the Pick up rollers need to be replaced, you can try to manually clean those rollers with some rubbing alcohol and some q-tips and gently clean those rollers, if that doesn't help then the rollers need to be replaced. You can usually find replacement pick up rollers online
Nov 18, 2009 | Canon SELPHY ES1 Thermal Photo Printer
Phaser 6250 transfer roller
Hi clwest: I hope that this will help you.
Transfer Roller is at End of Life
■ Print the Supplies Usage page to verify the remaining life and Transfer
Roller install date.
■ Cycle printer power.
■ If the problem persists, follow the procedure below
Note
Look at the clear plastic window on the Transfer Roller. If toner is present in the
center of the window the Transfer Roller is at end of life and needs to be
replaced. If no toner is visible, try cleaning the CTD (ADC) Sensor.
The “Transfer Roller is at End of Life” is a warning. “Replace Transfer Roller” is
a hard stop.
Dec 15, 2006 | Xerox Phaser 6250N Printer
Dell 1100 Laser Printer Logo
802 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
