I do not have a manuel to show me how to change the ink cartridge on my hp deskjet f2400 printer. Can you give me directions?
    Problem Solver:
  • 9 Answers
Go to their website and find your model number. See if you can find directions there. On my model, which is not the same as yours, you open the front cover, above the paper. When you do that, the ink cartridges move to in reach. You simply pull straight out, and push the new one straight in, sometimes you have to jiggle it to get it in right. Don't forget to remove the protective tape off the new cartridge. Simple, really.
Posted on Oct 09, 2010
Why does my HP Deskjet F4280 Show an E in the Start/Copy screen??
Regarding your recent inquiry about the HP 60 cartridge error message ("E in display window") and inability to print with your HP Deskjet F4280 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (please note that it is very rare for both ink cartridges to electrically fail at the same time). An electronic failure of the cartridge would be unrelated to the ink cartridge refill process; these same failures can (and frequently do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to B. and C), this will identify which ink cartridge is causing the issue:
NOTE: Unfortunately, alignment pages and internal self test prints will usually print Ok even if the cartridge is internally electrically damaged. Do not use these test pages as a proxy for determining whether a cartridge is good or bad, only the 'Tap 41/43' diagnostic test report can yield this information.
As a temporary workaround, or if you are unable to determine which cartridge is causing the issue, remove one of the ink cartridges from the printer....this might place the printer into the 'single cartridge printer mode'....print jobs may then be executed from the computer (only):
An internal electrical failure of a cartridge can be confirmed by performing the following corrective/diagnostic steps:
A.Ensure BOTH carriage/flex cables and BOTH ink cartridge contacts are thoroughly clean before proceeding: http://inkjet411.com/?page_id=1519
B.Validate the cartridge's electrical health by running the 'Tap 41' diagnostics test. Refer to DIAGNOSTIC TAP 41 video procedure at the following link on how to activate and read the service test:
http://inkjet411.com/?page_id=440 (HP 60 - Deskjet F2400/F4400/F4500 models)
    1.While holding the Power button, press Cancel (X) button 4 times, then press the Color Copy button once.
    2.Release the Power button.
    3.The 'Tap 41' diagnostic test print should print.
    http://inkjet411.com/?page_id=444 (HP 60 - Deskjet F4200 model)
      1.While holding the Power button, press Cancel (X) button 4 times, then press the 'Resume' button once.
        --- Providing the color cartridge is partially functioning the Tap 41 diagnostic test print will be printed (this is a forced service print test which is mainly used for the evaluation of ink cartridge electrical health). A good HP 60/60XL color cartridge should display 1248 good nozzles, while a good HP 60/60XL black ink cartridge should show 336 good nozzles. If the results yield anything different then the ink cartridge is likely damaged and will need to be replaced. Refer to 2nd video on how to read the printout.
        ---- If the printer attempts to print the diagnostic test pattern (1 page) then the printer is generally considered operational and functional, if nothing is printed, but the printer attempts to print the pattern, then the tri-color ink cartridge is either empty, clogged or severely electrically damaged (black ink cartridge is not used). You can remove the tri-color cartridge, reactivate the tap 41 test and the printer will print the diagnostic test print in black ink.
For any additional questions please contact us directly: Inkjet411help@gmail.com
To purchase the lowest cost ink cartridges available in the USA (remanufactured in the USA) please visit: http://www.inkplicity.com/
-Thank you
Aug 14, 2014 | HP DeskJet F4280 All In One Printer InkJet
Can you remove the battery from an hp F4480 printer to make it ignore incompatible cartridge message
Unfortunately, this does not work.
With respect to the HP 60 cartridge error message ("Incompatible Print Cartridges") and inability to print with your HP Deskjet F4480 printer, this type of error is normally associated to an electrical connection issue between the printer and the cartridge, or more likely, an internal micro-electronic failure inside the cartridge itself (which is typical of the 'incompatible error' alert). These same failures can (and randomly do) occur with brand new ink cartridges.* To help identify the root cause, please run the 'Tap 41' cartridge's electrical / diagnostic tests below (refer to A. and B), this will identify which ink cartridge is causing the issue:
Please first verify the age of the ink cartridge(s)....look at imprinted date on front of ink cartridge. If this 'warranty expiration date' has expired, then potential internal electrical cartridge failures can occur due to internal corrosion, etc.
            NOTE: To our team's knowledge there is no 'cartridge error bypass' method available for the HP Deskjet printer model. The cartridge will mostly likely need to be replaced with a new one.
            Please note that we provide professional ink cartridge refilling services in multiple countries:
            Costco USA Ink Refill Service (453+ stores): http://www.costcoinkjetrefill.com
            Costco Canada Ink Refill Service (52+ stores): http://www.ca.costcoinkjetrefill.com
            Costco Mexico Ink Refill Service (38+ stores): http://es.costcoinkjetrefill.com/
            Costco United Kingdom (select stores): http://uk.costcoinkjetrefill.com/
            Fry's Electronics USA Ink Refill Service (34 stores): http://www.frys.com/ads/page51
            Best Buy Canada (4 stores) Refill Service: Downsview, Sherway, Toronto, & Vancouver (additional Toronto Best Buy stores opening in Fall 2014).
            Micro Center USA Refill Service (8+ stores): http://www.microcenter.com/site/content/refill-service.aspx
            We also have ink refilling centers in many University bookstores across the USA & Canada:
            Brigham Young University, Brigham Young University Bookstore - Idaho (BYU-I),
            Cornell University (CU), Kansas University (KU), New York University (NYU), San Diego State University (SDSU), University of San Diego (USD), University of Wisconsin - Madison,
            University of Virginia (UVA): http://www.cavaliercomputers.com/inkjetrefill.asp?
            Queens University (Kingston, Ontario, Canada) & University of Calgary (Calgary, Alberta, Canada)
            Refill Store Map Locator: http://www.go2ris.com/#findstore
            Our network of retailers stand behind the product and performance - guaranteed. Customers who have questions regarding the use of refilled ink cartridges can visit http://www.inkjet411.com or contact us directly at INKJET411HELP@GMAIL.COM
            -Thank you
Jun 02, 2014 | HP F4480 All-In-One Printer
Hp 4480 how do you unpause it
The HP F4480 likely has a malfunctioning ink cartridge which is causing the printer hang (i.e. internal micro-electronics damage inside the HP 60 color or black ink cartridge). You can verify the electrical condition of both HP 60 ink cartridges by activating the Tap 41 diagnostic test report (see video here for complete instructions):
    For additional support please visit http://www.inkjet411.com
    -Thank you
Dec 09, 2013 | HP F4480 All-In-One Printer
How can I align my HP Photosmart C4680 printer after replacing ink cartridge.
If the new (or refilled/reman/compatible) HP 60 (or 60XL) ink cartridge refuses to complete the printer alignment following cartridge installation, then the ink cartridge either has a connectivity issue with the flexible printed circuit cable (inside unit where cartridge mates with cable), rear cartridge contacts or cable contacts are dirty with ink residue, or the cartridge is suffering from marginal internal electrical performance.
The types of 'more severe' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.), including blinking power/exclamation lights, typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
HP 60, 60XL, 61, 61XL Ink Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=BskAfa6NJSg
HP Photosmart C4600 & C4700 Printers - Diagnostics Tap 41 Test: http://www.youtube.com/watch?v=ghxjLCn07Jo
HP Photosmart C4600 C4700 D110a Printers - HP 60 Cartridge Error Bypass: http://www.youtube.com/watch?v=rNVJmKPlLsg
HP Deskjet F2400 F4400 and F4500 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=m-OM09NvNqg
HP Deskjet 4200 Printers - Diagnostics Tap 41 Test:
http://www.youtube.com/watch?v=16uXSBwTan8
HP Deskjet D2500 & D2600 Printer -Tap 10 Diagnostic Test:
http://www.youtube.com/watch?v=RTFOBtdthAc
Mar 28, 2012 | Office Equipment & Supplies
My HP Photosmart C4700 keeps saying the printer cartridge is in wrong. I have taken them both out and put them in and they are correct.
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged. The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
Sep 20, 2010 | HP PS C4780 All in One InkJet Printer
How do i bypass the ink cartridge error on the hp Deskjet F4480? It is saying ink cartridge not compatible but it is a genuine cartridge. And E is displayed on the screen and the light is flashing. How can...
These types of severe cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", etc.) typically indicate the internal micro-electronics of the HP #60-61 cartridge are electrically damaged - now, these errors can be bypassed on select printer models (temporarily). The cartridge's electrical wire runs at rear and lower side of the ink cartridge, are very delicate and are somewhat susceptible to ink attack over time, which can lead to premature failures. In addition, the older the cartridge the higher the chance of an internal electrical failure due to prolonged ink exposure and subsequent circuit corrosion. I suggest you always run a 'Tap 41' diagnostic test to check cartridges electrical health (this is a forced test); you may also bypass the error (temporarily) on C4600-C4700 models which use HP 60 cartridges. Refer to Inkjet411 youtube videos below:
May 20, 2010 | HP F4480 All-In-One Printer
jasbo
jasbo
