Question about Simply Media Greeting Card Publisher Full Version for PC
Purchased Greeting Card publisher for Windows XP, the appropriate version. Program will show slections but crashes when a card is selected. Appropriate memory available. My adult son tried it too. He thinks I've been "had".
    Genius:
  • 1,478 Answers
I will advice you try use it on another system entirely and see if it will work on a different system, if doesn't, it means the software is bad, you will need to get a replacement for it.
Take care.
Posted on Oct 09, 2010
I have greeting card 8 is this compatible with window 10 please
I suspect not since it was designed for windows XP, though will work with 7.
There's is another version designed to work with windows 8, but there's no guarantee that will work with 10. It seems some software used a component that was discontinued with any windows version 8.1. and onwards.
Oct 31, 2016 | Computers & Internet
I have American Greetings CreataCard Platinum 6. Windows 7 will not complete it. Sometimes I can skip quickly and get it to make a card but it is definitely not responding properly. What can i do? I...
You are may need to use compatibility mode for this program. It was originally intended for use on windows 98/Me/2000 and XP. To set compatibility mode to any of those operating systems, right click on the American Greeting shortcut (the icon you click to start the program) and select "properties". Now look for the "Compatibility" tab and click on the check box for "Run this program in compatibility mode for:" and in the drop down box, select "Windows XP (Service pack 2)" Or, "windows XP (Service pack 3). If there is no service pack options for windows xp, that's fine. After you made your selection, press ok. If the program works, you're set. If not, go back and change the compatibility mode operating system to another choice such as "Windows 98" or "Windows 2000". Try each one and see what works for you.
Mar 29, 2011 | Broderbund American Greetings Crafts! and...
I have amecan Greeting Card plus 3 and it will not work on my Vista 64 bit please help
This is an old piece of software. You can try right clicking the program icon, going to properties, going to compatibility and attempt to run it in Windows XP or Windows 98 compatibility modes. This may not work as the program is listed as incompatible with Windows Vista 64.
Please give me feedback for this answer, thanks.
Mar 09, 2011 | Broderbund American Greeting CreataCard...
My Art Explosion Greeting Card Deluxe Factory 2 software will not work on my Toshiba Satellite A200 laptop. I am using Windows Vista. Please can you advise?
Unfortunately the Windows OS has changed significantly since that software was released. Nova Developement now has the Greeting Card Factory Deluxe version 8 for XP/Vista/7.
If you have the 64-bit Vista, you may not be able to get the old software to work and need the upgrade or a virtual computer with an older Windows OS (see below). To check your OS version, click Start > Control Panel > System and Security > System .
You can try running the program in the compatibility mode - this will work best with software for XP not Win95-NT. Right click on the installer and select Properties. Go to the Compatibility tab and choose Run this program as compatible with (an older version of Windows). Click on the check box and use the drop-down menu to select the older OS. Save the change by clicking apply then close the window. Right click again on the installer and choose Run as Administrator.
If the program installs, do the same compatibility steps for the program's exe file itself. (You don't need to run as administrator though.)
Alternatively, you can run a dual boot or virtual computer with an older Windows OS. (Programs like Virtual PC, Parallels and VMWare let you run a virtual computer inside the Vista system with a computer that can handle virtualization.) Unfortunately, you usually need a licensed version of Windows to do this. (Win7 Pro and Ultimate let you do this free with Virtual PC and XP mode.) Then install the software normally in the virtual computer or when booted into the older version of Windows. File transfer can be tricky with the virtual computer - you need to save files to external media (flash drive or optical disc). Printers can't be installed on both the real and virtual computer at the same time.
I hope this helps.
Dec 28, 2010 | Nova Development Art Explosion Greeting...
Create a card gold fails to run on windows 7
If a program cannot be run under Windows 7 because of compatibility issues you have to right click on the executable file that will start the application and click Properties. Select Compatibility tab and check the Windows version you know the program worked with before. You can find more about this Compatibility issue on Microsoft website http://windows.microsoft.com/en-AU/windows-vista/Make-older-programs-run-in-this-version-of-Windows
Dec 05, 2010 | Broderbund American Greeting CreataCard...
Greeting card factory 5
Nova Development no longer supports Greeting Card Factory 5 on their website, but it looks like Greeting Card Factory 5 is only compatible with Windows versions up to Windows XP. You could try installing it in Windows 7, but it probably won't work right.
However, Greeting Card Factory 8 is fully compatible with Windows 7.
Jun 30, 2010 | Nova Development Greeting Card Factory...
Have greeting card magic from 1998. Is it to old
Try to find a compatibility mode in Win7 to install it.
Feb 10, 2010 | Cosmi Greeting Card Magic for PC
Is there a program out there like Greetings 99 for vista?
Art Explosion Greeting Card Factory Deluxe 7.0 - This version of Greeting Card Factory from Nova Development adds another 10,000 graphics (90,000+) and almost double the number of project templates from earlier versions (24,000+). Create all kinds of projects from greeting cards and calendars to stationery and certificates. Some of the kinds of cards include Thank You notes, Pop-Up Cards, Note Cards, and Photo CD Greeting Cards. Helpful tools: Photo Editor, Card Browser, and Drag and Drop Text Effects. It's also Windows Vista certified. This is a very good program and works with Vista. Hope this helps you.
Aug 23, 2009 | Microsoft Graphics Studio Greetings 99...
1998 gcm programme on windows xp will not import pictures from files
Simply put , it is probably because the program is too old for windows xp, especially newer service packs of windows xp.
Jul 02, 2009 | Cosmi Greeting Card Magic for PC
Simply Media Greeting Card Publisher Full Version for PC Logo
19 people viewed this question
Top Simply Media Computers & Internet Experts
David Payne
David Payne
Are you a Simply Media Computer and Internet Expert? Answer questions, earn points and help others
