Question about Zenith R57W46 57" Rear Projection Television
Module any idea where i can get a module board cheap for a zenith, 009-01674-03 ? or get it repaired?
  • 4,234 Answers
This part is available from using part number 9-1674-03-tri at a cost of $299 with a dud value of $75 (get $75 back when bad part returned). There is also a "rebuild kit" available part number 9-1674-kit at a cost of $49.89. This kit includes the flyback.
Posted on May 30, 2008
TV will not power up
These flat panel Tv's, all of them, sometimes have cheap Capacitors in the power supply section. They'll keep tv off and tripping relay circuits. It's not a fault in the power supply ic's, it's a fault in the main Capacitors. The IC thinks there is a leak, so it shuts down tv. It monitors voltages through comparators, and compares them to reference voltages. So check main power Capacitors and replace as needed. A lot of Chinese made Capacitors are cheap. In the big sets, they break down a lot.
Jan 15, 2014 | Zenith Z50P3 50 in. Plasma TV
Deflection Board Part Number
Call Module Exchange at 972-298-1212
Jan 02, 2008 | Zenith D60WLCD 60" Rear Projection...
The cable connector has been broken off. is there any way of fixing this without replacing the entire board
With most tv's I've serviced, the cable connector is connected directly to the tuner module. The tuner module may be damaged beyond repair, depending upon how much physical force was applied to the cable connector. I would take it to a reputable repair shop and let them provide you a honest estimate of repair. They may be able to resolder the cable connector to the tuner module.
May 16, 2011 | Zenith B32A24Z 32" TV
Sound suddenly went out on Zenith TV Picture and everything else appears to be working fine
All of these Zenith's are modular in design. I'm sure you have a problem with the sound module. A replacement should be relatively easy to find at a local Zenith Dealership at a nominal fee. If you are handy, you can change it yourself or if not, bring it in for repair. The set is definately worth repair.
Dec 13, 2009 | Zenith Z50PX2D 50 in. Plasma HDTV
Our Zenith C32F43 went out, no picture no sound, when you pudh the on/off button you can hear it click on inside but nothing??? We have had the capasiters replaced three times and then the fourth the man...
Replace the whole board,the IC shorted can't distributes the voltage evenly,that why u keep getting burn out capacitors.Might got some things,else where burn too.Becauce keep replacing the same part that is not the main cause of the prob.
Sep 02, 2009 | Zenith C32F43 32" TV
Plasma Repair Parts
Available from are the following:
6871QZH041A Zenith/LG Z-SUS Cost: $137.44
6871QYH036A Zenith/LG Y-SUS Cost: $238.38
6871QYH053A Zenith/LG Control Board Cost: $189.39
Hope this helps,
Mar 18, 2008 | Televison & Video
Z50PX2D 50 in. HDTV... Problem
You have a problem with the STK convergence modules. They're on the center circuit board attached to an aluminum heat sink that's about 8" long and 6" tall. You may be able to recreate the problem (hour glass effect) by gently moving the heat sink (which the modules are connected to). This gives the hour glass effect on the picture and the advanced convergence screen. This is an indication that the modules pins aren't solidly connected (meaning soldered) properly. Remove the circuit board and clean the old solder off & resolder the modules pins to the circuit board reconnected the board and then retest by again pushing on the heat sink. The "factory" job was good enough for 3-4 years but the heat (and these modules do create a lot of heat) and stress created from repeated use eventually takes it's toll, weakens the pin connections and our problem occurs. take the appropriate cautions working around the high voltage of the set.
If soldering doesn't help, then the modules have died and need replacing. Don't buy the $10 cheap ones. Most of them have an upgraded version that is stronger. Also look for any burned resistors in the vicinity of the modules.
Best of luck, hope ya fix it.
Feb 11, 2008 | Zenith Z50PX2D 50 in. Plasma HDTV
Zenith TV B32A24Z
You have a power supply problem. On this set the entire board is available for exchange but it is most likely not going to be worth the repair as these boards run for about 120 to 145 bucks. Good luck
Jun 05, 2007 | Zenith B32A24Z 32" TV
Zenith 27 TV - screen jumps and suddenly turns off.
Sounds like you have a vertical failure, and is causing the power supply to shut down. A repair person can probably repair this main board in this set but it will cost more in time and labor to repair. So the right thing to do is replace the entire module. This Zenith was designed to replace the boards completely to shorten down time as well as labor. The board this set needs is a 9-02107 module, and is avail from for 52.44 + shipping. I dont think you should attemp to do this repair by yourself if you have no electronics training or tv training. This is just so you know what you need and get an idea on what this will cost you to repair. Good Luck
Aug 13, 2006 | Zenith C27A24T 27" TV
IQB64W10W high-def problem
Your problem sounds like the digital board and probably was what the repair people said. I would suggest telling them about Tri-State Module, Inc in Evansville, IN. 800.203.7484. They have a good selection of modules for about any set and most are under $150.00 with the average being $100. They rebuild boards and all boards carry a 12 month warranty. You can also access them at If they can't help try PTS in Bloomington Indiana. I use them for alot of replacement modules. Same deal as tristate.
Oct 12, 2005 | Zenith IQB64W10W 64" Rear Projection...
Zenith R57W46 57" Rear Projection Television Logo
53 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
