Question about U.S. Robotics USR7908 (USR7908US) 8x10/100 Mbps Networking Hub
What is IP this router? - U.S. Robotics USR7908 (USR7908US) 8x10/100 Mbps Networking Hub
    Brigadier General:
  • 4,044 Answers
What did you set the IP to? IP addresses are assigned manually or automatically by your network. You should be able to access it with 192.168.0.254 or 127.0.0.1. If your network is set for DHCP it assigns the IP automatically. If it isn't then someone assigned an IP manually and if that is teh case only that person would know what IP range they used.
Posted on Oct 09, 2010
Cisco 861 behind Wimax Router from ISP
> WAN IP: 44.55.66.777
> ISP Router LAN IP: 111.222.333.174
> Cisco Router WAN IP: 111.222.333.175
Really? Each "octet" must be a value between 0 and 255, inclusive. A value such as '777' is not valid
Aug 27, 2012 | Cisco 861 Router
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
When i enter the ip into the browser and press enter it says page not found
If you haven't changed the ip address to something else, the default IP address could be
192.168.0.1
192.168.1.1
192.168.2.1
those are the most common IP addresses for routers
Mar 23, 2011 | Gateway Wireless-B Router (wbr-100)
When i try to install my Linksys wireless G, it ask for a password. I don't know it and it won't let me proceed!
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Nov 04, 2010 | Linksys Wireless-G Broadband Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Step 2:
Step 3:
If you forgot the router's IP address you can:
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Step 2:
NOTE
Step 3:
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
Someone has changed my IP address hacked into in my router
I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
Jul 06, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Network card doesdie not acquire DCHP internet address from router. Router port and cables verified.
As you have said that your router assigns IP address to some other computer, its obvious that there can be no problem with your router.
So please try the following steps:
Goto your network adapter settings page
Select the circled options.
Provide the above settings. click ok.
Now disconnect the cable from your router and connect it back.
Everything should work fine, if DHCP is working properly in your router.
If still problem persists, then try "Use the following IP address " option in the above dialog box and provide IP as follows and try again.
Please ensure and change gateway and ip according to your router.
Gateway ip is the one which is your router ip ( the one which you give in internet explorer to enter into your router settings page)
In this way you should be able to connect to your router. If successfully connected, then it also implied that DHCP is not properly running in your router and now you have connected to router by providing an IP address manually.
I hope this is helpful in solving your problem
Thanks
Mar 06, 2010 | Computers & Internet
How to find router fully ip address?
if your PC still working and connecting to the internet thru this router, then open command prmpt, enter "ipconfig" and read the ip address of the default gateway. at most simple home networks, that is your router.
Jun 06, 2009 | EnGenius EOC-3220+ (EOC3220PLUS)
LINKSYS ROUTER
You need to know the ip address of your dvr. It might have a factory set ip address or a dynamic ip address from the router. You can then use this ip address to access your dvr.
If your dvr has a static ip, that static ip should be in the same range as the router's ip address so that the router can communicate with the dvr.
Mar 12, 2008 | Linksys Wireless-G WRT54G Router
U.S. Robotics USR7908 (USR7908US) 8x10/100 Mbps Networking Hub Logo
180 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
