Question about Amperite Dayton Solid State Timer On Delay Time Relay
My solid-state timer, Model EJ351 does not work any longer. Where can I buy a new one to replace it?
I have the EJ351 mechanical in-wall timer for my outdoor garage lights which are LED.I set the timer but lights go on way early Is there another method for programming the switch that I could try.
This is not a mechanical timer; it has a solid-state switch. It is designed for incandescent lights, and is not recommended for CFL or LED lamps. It may work properly with dimmable LED lights if you have at least four (total 32 Watts or more) connected.
You can try programming using the 24-hour method described at the top of page 2 of the manual. I've provided the link to the manual below.
https://www.intermatic.com/-/media/inriver/6842-8228.ashx/EJ351-Instructions-EN
Jul 08, 2017 | Hardware & Accessories
The red indicator light for the intermatic light timer EJ351 does not even go on - what can I do?
Hello Barb.
EJ351 timer indicator light problem:
Reset timer and try again.
This timer is rated for incandescent lighting only, 500 watt max, 40 watt minimum, and timer has two wires.
When replacing switch, either wire can connect to timer wires.
Check circuit breaker: click breaker all the way off, and then back on.
Use non-contact voltage tester to see if wires are live at timer.
If the timer does not work, then it has 1 year limited warranty for defects in workmanship.
Copy following link for EJ351 timer manual with instructions for resetting timer.
http://waterheatertimer.org/pdf/Intermatic-ej351c.pdf
Jul 18, 2012 | Intermatic Programmable 24 Wall Switch...
I set my timer last night. the lights went off at the designated time this morning, but now the light is blinking. What does that mean?
Troubleshoot section in manual says, 'recheck wiring.'
Cut back insulation on stranded wire so stranded is longer than solid, Then wrap stranded around solid, and apply wire nut. After nut is tight, pull on stranded wire to make sure it is not loose:
http://waterheatertimer.org/How-to-twist-electric-wire.html
Check light bulbs are tight in socket. A fellow had same problem with programmable timer and discovered light sockets were dirty and not making good contact with bulbs.
If wiring is correct, try resetting timer.
Timer could be defective.
EJ351 has 1 year warranty against workmanship defects.
http://www.intermatic.com/customer%20service.aspx
Open following link for resources:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Intermatic Programmable 24 Wall Switch...
I had a timer model EJ341C many years ago, it was broken down. I went a store and the salesman said the new model EJ351C is the substitute. My questions to you is (1) Are these two models pretty much the...
Hi Henry,
Intermatic EJ351 is sold today to replace earlier models.
EJ351 is very popular 24-hour ez-set timer with simple wiring.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Instruction manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ej351c%20-%20english.ashx
Connect wires inside box to either timer wire.
Red indicator light is helpful when setting timer program.
Add a comment if instructions are confusing, and say what part of manual does not make sense.
Apr 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
My EJ351 programmable timer has work perfectly since 2004. A few days ago the red light just started to continuously flash. I turn it off to rest and regrogram but no luck, the indicator light still...
What is amazing is that you know the year of purchase, AND remember how to set the timer.
1) Try turning off circuit breaker and see if timer resets.
2) Buy cheap circuit analyzer and plug into outlet on same breaker and see if line is clean.
3) EJ351 has limited 1 year warranty.
I test timers: usually when in-wall timer goes bad, it needs to be replaced.
There are no repair parts.
Google search: Intermatic EJ351 timer
Amazon sells EJ351
http://www.amazon.com/dp/B000Q9YUGU/ref=asc_df_B000Q9YUGU1408425?smid=ATVPDKIKX0DER&tag=nextagus0039178-20&linkCode=asn&creative=395093&creativeASIN=B000Q9YUGU
Aplus supply sells Ej351 timer.
http://www.aplussupply.com/intermatic/timer.htm
I buy timers from both these suppliers.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 28, 2011 | Intermatic Programmable 24 Wall Switch...
Where can i buy a intermatice ej341? we live in delray beach, florida
1) I searched Intermatic for EJ341 and showed no result:
http://www.intermaticstore.com/
2) I searched internet for EJ341 and showed a guy replacing EJ341 with GE 15086
http://www.fixya.com/support/t6267843-am_replacing_old_intermatic_model_ej341
3) Intermatic makes timer with similar number: EJ351 push-button-dial-type timer, which is available with internet search
4) You can choose from many timers on market today:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/Countdown.html
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/GE-timers-and-manuals.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
5) Add a comment for more free help.
Jan 22, 2011 | Solar Intermatic Single Pole Model Ej341c...
My intermatic switch won't turn off the outdoor lights. It covers the original light switch. It has a plastic cover with a extention that press smaller button underneath that says no op see inst. Please...
I answer questions for free.
I specialize in timers.
According to Intermatic, they no longer make the light switch timer.
I cannot find the instruction manual on Intermatic.
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
From my experience, I suspect that the timer is old and does not function any more.
If this is not correct, add a comment and I will answer
Hammacher makes a wall switch timer. $40
http://www.hammacher.com/Product/78709?promo=Electronics-Safety-Security&catid=106
Intermatic also makes another timer that is simple to operate.
It is called the EJ351 but it has to be wired into the wall.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers/ej351c.aspx
be3a610.jpgEJ351 cost $25 http://www.nextag.com/intermatic-timer-ej351/stores-html
Nov 01, 2010 | Hardware & Accessories
Amperite Dayton Solid State Timer On Delay  Time Relay Logo
541 people viewed this question
Top Amperite Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you an Amperite Hardware and Accessory Expert? Answer questions, earn points and help others
