Question about Garden
Need gas/oil mixture for a John Deere BC 1600 trimmer.
    President:
  • 1,545 Answers
Some of the new machines have a 50:1 Mix ratio, but all of the older ones I've seen are 40:1 which is 3.2 oz oil/Gallon gas. The John Deere machines appear to be similar to the Homelites, just different brand names on them.
Posted on Oct 10, 2010
Gas leaking from bottom valve and getting in oil on a John Deere 110 17.5
sounds like the needle valve in the carb is not seating also check the oil gas over flows from the carb into the oil change it a couple times
Apr 24, 2012 | John Deere Garden
I have a John Deere riding lawn mower model # 406777, gas was put in the oil tank by accident. What do I do?
DO NOT RUN THE ENGINE IN THIS CONDITION
The solution is not too difficult here, but may be a little messy if you are not careful. You need to drain the oil/gas mixture into a container. CAUTION- the gas in the oil acts as a thinner and the mix will flow out very quickly so be ready to catch it in a container. Change the oil filter and refill with oil like normal oil change. Remove spark plug and rotate engine several times, this is done because the fuel in the oil washes the oil out of critical locations within the engine and rotating several times to put oil back on those critical surfaces. Reinsert plug and you are ready to start it up.
I hope this help you, if it really does please rate four thumbs up.
Jul 22, 2011 | John Deere Garden
Never owned a 2cycle product and some one gave me a John Deere t105c trimmer but dont have an owners manual and dont want to pay $20 -$40 for one just to find out how to fill with gas/oil mixture. Can you...
You need two-cycle motor oil, do not use regular motor oil. Almost all two-cycle motors are designed to run on a 50 to 1 mixture of gas and oil. Look for two-cycle motor oil at any store that carries two-cycle tools like chain saws, line trimmers, etc. A good bet is Lowe's or The Home Depot. If you get the 2.6 oz bottle you have to add that to one gallon of gas to get a 50:1 mixture. Always read the oil bottle for correct mixing amounts and mix the oil with the gas in a separate container then put it in your trimmer.
Jun 06, 2011 | Garden
Proper oil gas mixture for chainsaw 230cs
Hi and welcome to FixYa, I am Kelly
The mixture is 40:1
I use this calulator for fuel mixtures:
http://www.csgnetwork.com/oilfuelcalc.html (Awesome once you figure it out!)
Thanks for choosing FixYa,
Kelly
Apr 30, 2011 | John Deere Garden
I just brought a john deere rcs400 weedeater from a pawn shop. I search all over online for info on this equipment and can't find anything. I even went to the john deere web site and still nothing. I am...
40:1 fuel to oil should work fine if you use a modern synthetic saw oil available from home centers, hardware stores, and saw dealers. Be sure to premix in it's own container and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Make sure the fuel filter, air cleaner, and muffler are not plugged. Inspect the fuel lines for decay or other damage. Hope this helps!
Jan 23, 2011 | John Deere Garden
What is the correct gas/oil mix for a john deere weedeater?
4 oz generic 2-cycle oil to a gallon of fuel for a 32:1 ratio. It using JD Exact oil the ratio is 50:1 using 2.6 oz of JD Exact oil.
I hope this helps you.
Jun 17, 2010 | Garden
How much oil to mix with gas for the 2100C John Deere weed wacker?
3 oz. of 2 cycle oil to 1 gallon of fresh fuel
87 will work 89 octane prefered
May 28, 2010 | Garden
I have a John Deere hand held blower. I can't get
Your adjustments to the carburetor may make it worse.
Plus if the fuel mixture is over 30 old, I would replace it.
Manufacturers have told us this year any gas over 30 days old is considered bad gas and needs to be replaced. I would try some fresh gas(from the station) and some new 2 cycle oil at 40:1 Ratio(3.2 ozs 2 cycle oil to 1 gal of gas).
Good day.
Nov 07, 2009 | Garden
Gas mix for John Deere C1200
Mix one (1) ounce of two cycle oil per quart of gasoline or four (4) ounces of oil per gallon of unleaded gasoline. Hope this helped and best wishes.
Sep 04, 2009 | Garden
Garden Logo
1,077 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
