Hello, I recently bought a new tv from ebuyer. It works well, apart from when i plugged in my xbox 360, the sound works fine but the colours on the screen and not what they should be. They are olive greeny and black, I've done everything i can think of. And i went to plug my xbox to another tv and the colours are fine again. Could you help me please, would be greatly appreciated.
  • 4 more comments
  • ryanfergy Oct 09, 2010
    Its a Hannspree ST321MB3. 32". The tv only has one input and it is the component.
    when i turn my console on and hold down Y and the right trigger downwards it does nothing. The console doesn't restart.
    No the colour is still the same.
    So if i bought a HDMI cable for my xbox ELITE then i wouldn't have to plug my xbox into the tv via the red, blue, green cables etc?
    Thank you very much for your help. I will buy a cable tomorrow, and if that doesn't work could i contact you again yes?
  • ryanfergy Oct 10, 2010
    I bought a HDMI cable and my xbox is working better than ever. Thanks Ekse.
  • 13,433 Answers
what brand and model tv is it? Please try connecting the xbox 360 to another input - method. for example component if the tv has such a connection.
Posted on Oct 09, 2010
  • 5 more comments
  • Ekse Oct 09, 2010
    On the back of the tv you have Inputs: Composite, Component, 4x HDMI, VGA, 2x Scart, S-Video.
    You can connect the Xbox into compoenent, any of the hdmi if its a newer model box. VGA but you don't have the special cable. Both scart would also do.
    For the best picture quality the HDMI if your xbox has it, would be the best choise. if it doesn't then either component or vga or scart as the lowest possible quality option.
    The problem might be the TV, But lets reset the xbox to default video settings, turn the console on and right away hold down the yellow Y button and the RIGHT trigger down, keep them down until the unit restarts itself, and the logo appears again.
    Now is the color problem still there or is it gone?
  • Ekse Oct 09, 2010
    Please read this page and follow the instructions therehttp://support.microsoft.com/kb/911059
  • Ekse Oct 09, 2010
    Okay, you could go and check the Display settigs and try changing reference levels settings to something else and see if it does anything, also if offered try different screen resolutions. Your tv was fullHD so 1920x1080 would be the best one to choose.
    If these do noting (do try other resolutions aswell) Then the issue is most likely the televisions component connectors or the inputboard for the component connectors might be faulty. Then I'd go with HDMI, VGA or Scart. from which HDMI is probably the best, VGA will do OK and scart might be something else entirely.
    Basically it seems a issue with the tv and we can't do much about it, unless the tv has somekind of settings that you can adjust or reset the tv entirely.
    If noting seems to help, most likely component input is faulty. Not really worth it to repair unless you get someone find and fix the problem for cheap.
  • Ekse Oct 09, 2010
    You would plug it to the HDMI port on your xbox and the other end into the HDMI port on the tv, you should have 4 of them, then you just change the TV Source - to HDMI and you get picture again.
  • Ekse Oct 09, 2010
    as far as I know you can only use one method of connecting at a time, you couldn't use both at the same time. So no you wouldn't connect the component wires.
  • Ekse Oct 09, 2010
    Yes you may, this thread stays open for 7 days from the last comment added. If you accept the solution the thread is closed but you may still add comments.
    I'd leave it open for now and just drop me a comment when and if you need more help.
  • Ekse Oct 10, 2010
    Happy to hear the problem is solved, go ahead and click on the accept button below.
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
Xbox 360 screen wont show up
try to replace again with another wires. sometimes new wires got factory defects. after you replace it with a new one, test it on their xbox if its correctly functioning after that test it on your xbox. hope that helps sir!
CHARCOIS
Aug 21, 2008 | Microsoft Xbox 360 Console
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
Hi, i have had a old tv for quite a while now and my xbox 360 played ok on it. i have recently just bought a brand new hd tv and the colours on the sceen are incorrect for example, when i play call of duty...
look on the back of the tv you might have the av cable mixed up you have to have them right to get the right colors oather wise try adjusting the colors on the tv but i would try the cables first
Jan 27, 2011 | Microsoft Xbox 360 Console
Xbox 360 plays movies fine but colour is wrong on games
i will suggest if you new tv has more inputs, just try a different imput, and make sure the plugs are in all the way. this is a new tv so it will be tight.
same with the video connection on the back of xbox well plugged and straigt.
hope this woks. and remember to rate me if i helped you
Oct 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Video Problem
Have you adjusted your tv settings at all, rather has anyone screwed aroung with your tv?
Sep 21, 2008 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
Audio but no video when i turn xbox 360 on
hi MC, power off unit unplug av cable from back of xbox.. then power up unit.. after a couple minutes the xbox will shut down.. plug the av cable back in and power up.. Good Luck
Jun 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 picture problem
check vga cables or composite cables
May 24, 2008 | Microsoft Xbox 360 Console
Hannspree 37" with Xbox 360 HD
Try to use a HDMI cable, your component cables may not be usable with your TV.
Apr 20, 2008 | Hannspree (K206-10U1-005) Television
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
