Question about Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop
Ethernet connection Im not getting a "local area connection" icon under Lan or High speed internet. Also under the Manager Divices the ethernet controller has a yellow question mark. Could you help?
Im not getting a "local area connection" icon under Lan or High speed internet. Also under the Manager Divices the ethernet controller has a yellow question mark. Could you help? and my operating system is windows xp
Posted on Jul 10, 2008
  • 10,594 Answers
Driver of Ethernet card corrupted. download proper driver from following web link as I dont know the operating system you are using.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=97128&taskId=135&prodTypeId=12454&prodSeriesId=316510&lang=en&cc=us
Posted on May 30, 2008
Windows telling me to plug ethernet in
on the desktop task bar bottom of screen computer monitor icon.left click one time and window will open click on open network and sharing center.network and sharing center window will open look to the far left for change adapter setting.click on change adapter setting this will open up your local area and wireless connections.right click on local area connection and click on properties local area connection properties window will open make sure the internet protocol 6(tcp/ipv6) is checked as well as the 4tcp/ipv4 click on ok you should be able to go online now.keep in mind that you will need to check your wireless adapter to insure you can connect to internet wirelessly.hope this helped.
Feb 19, 2012 | ASUS Computers & Internet
Tip
Local Area Network is missing on Network Connection for XP
There are time that the LAN icon under network connections are not showing and you cannot get internet connection. These are easy steps to fix the LAN problems: - Click on start- Right-click on My Computer and choose properties- Click on the Hardware Tab- Click on Device manager - Click on network adapters- Then right click on the Ethernet controller under the Network Adpater and choose uninstall- after uninstalling, right click on Network Adapters and choose Scan for hardware changes- then let windows re-install the Ethernet drivers and reboot the computer.- you can now check the internet connection.-Enjoy!
Thank you using this Tip from Fixya.
on Jul 18, 2011 | Computers & Internet
My toshiba laptop does not work on a lan. The icon
When you look at the Manage Network Connections link on the Network and Sharing Center you do not see
Local Area Connection?
Do you see Wireless Network connection?
You need to check the device manager to see if the card has been disabled.
It should show two entries with no red or yellow marks. One for wireless (WLAN) and one for wired (Ethernet)
Apr 11, 2010 | Computers & Internet
Definition of the sound card, internet lan & wireless lan
The definition of the sound card, is a chipset integrated into the main board of your laptop, in order to provide sound to your built-in speakers, or to the headphone jack on your laptop. Internet LAN (or Local Area Network) is a port located either on the side or the rear of your computer, where you would plug in a Cable/DSL High-Speed Internet connection, using an Ethernet cable (also called RJ-45). Wireless LAN is the same idea, only instead of using an ethernet cable to provide you access to the internet, it uses a wireless signal or radio frequency, to connect to a wireless access point (usually provided by a wireless router in the area). More in-depth information can be found at the following links:
Sound Cards: http://en.wikipedia.org/wiki/Sound_card
Internet LAN: http://en.wikipedia.org/wiki/Ethernet
Wireless LAN: http://en.wikipedia.org/wiki/Wireless_LAN
May 06, 2009 | Acer 4220-2346 Notebook
Ethernet card
hi there. The ethernet card is an interface that allows your computer to be connected to a LAN (Local area network) and to a Cable/Dsl modem to be on the internet. The connector looks bigger than the one of a regular telephone jack (it's actually double). If you don't have the ethernet card you can't go on the internet or on a LAN.
From the back of the modem or router you should connect a cable to your ethernet card of yor computer. Only after you did that you can try to connect to the internet.
Let me know, or be more specific.
thanks
Mar 30, 2009 | Dell Computers & Internet
Unable to access the internet
Please Test Ethernet Card
Jan 04, 2009 | Intel Motherboard
Dell Ethernet Network Adapter not being recognised
i) Click on Start button ---->Select option Control Panel------>Select Network Connections----->
  a new window appears showing the "internet connections icon " Such as:
  Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:  Local Area Connection 1 or 2 or 3
        Network Cable Unplugged, Firewalled
        VIA compatible Fast Ethernet
        in this case u can download VIA network drivers....from internet..
                      or
       eg2: Local Area Connection 1 or 2 or 3
       Realtek RTL8139 Family Fast Ethernet NIC
       in this u can download "Realtek RTL8139" network drivers.... from internet(which is showing              model no: RTL8139 through google search engine )
                                         (OR)
ii)        Click Start button ---->Select RUN option ----> type in the text box devmgmt.msc --->Select                Network Adapters....
           but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the             correct Model NO: of VIA or Realtek....
            so i would suggest to follow the step (i)
Thanking you
M.Sridhar
Nov 23, 2008 | Dell Ethernet Card Network Adapter
Local area connection, no internet connection
My guess is the LAN port on your motherboard is bad. The simple solution would be to add a PCI ethernet card and disable the one on your motherboard in device manager.
Jun 18, 2008 | ASUS M2N-E SLI (M2N-E SLI GREEN)...
Plugged ethernet cable innto laptop from cable modem and nothing
Click Start / Control Panel / Network Connections.
Your Ethernet status should show under LAN or High Speed Internet. It might be disabled, in which case, right click & ENABLE.
Let me know how you get on.
Jan 10, 2008 | Dell Latitude C640 Notebook
Ethernet controller driver
What is the model number and brand of your PCMCIA Card ?
Dec 11, 2007 | Compaq Network adapter
Compaq Evo D510 Minitower (Open Box) (OB4700432011) PC Desktop Logo
206 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
