Question about Lexmark X5470 All-In-One InkJet Printer
Paper jam on lexmark x5470
Ithe paper feeds correctly for the first sheet & then mis feeds, a message comes up saying there is a paper jam but the paper is not fed into the machine.
  • Consacre Jun 01, 2008
    I'm having the same problem and it's SO frustrating. It printed off fine, then on the third sheet it messed up, so I reloaded, it printed off one more, and now, reload after reload, it's telling me I've got a paper jam and I can't print off anything.
  • chef tony Jun 11, 2008
    yes i have the same problem. my printer says theres a papper jam but theres no papper in it.
  • 29 Answers
Fiend your solution direct from Lexmark. Here is your solution
Posted on Mar 02, 2009
  • 2,035 Answers
  1. Turn the printer off and open the access cover.
  2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
  3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
  4. Watch the paper as it feeds through and try to determine where the jam is occurring.
  5. Check to see if all the rollers are turning.
    If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
    If not, there is probably a feed motor or a gear problem and the printer may require service.
  6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
  7. Turn the printer off.
  8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
  9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Jun 11, 2008
I am positive there is no paper jam with my printer (Z2420) but message of paper jam still appears and it won't let me clear it.
Sometimes a very small piece of paper can still be in the printer paper path after clearing a jam especially if the paper tears while removing the jam. The piece of paper may be too small to notice. Try blowing out the paper area with compressed air. Other causes could be the thickness of paper you are trying to print on, ie photo paper, thicker bond paper. Make sure the print settings match the paper thickness. I have a Lexmark laser printer, and I will get feed problems if the settings are not set for the correct paper type.
I hope this helps.
Feb 10, 2015 | Lexmark Z2420 USB 2.0/ 802.11g Wireless...
Rint,copy,scan or fax on my x5470 lexmark all in one. I unplug and restart compture and the fax still says paper jam check rollars dont see noughting.
Leading cause of paper jams is debris / foreign objects that accidentally fell into the paper feed area. Please try this approach to fix the problem:
  1. Remove the sheets of paper from the feeder.
  2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
  3. If you're willing and physically able, you may also carefully turn the printer over. Any debris should just freely roll out from the feeder.
  4. If feeder is clear, place the printer on the table. Open the printer cover and remove the cartridges.
  5. Check the cartridge area for any obstructions in the paper path.
  6. Close the printer cover.
  7. Re-brick your printer by pulling out the power supply - the black box where the power cord is plugged into. Re-plug after 30 seconds.
  8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again to verify that the problem is fixed.
Dec 09, 2011 | Lexmark X5470 All-In-One InkJet Printer
My printer keeps showing the message "Clear paper jam, then press (check mark), there is no jammed paper in the printer.
If I load my paper at the 'proper' height, it will not feed. If I push the paper down too far, I get a 'paper jam' message. What works for me (even though it's a royal pain) is to feed 1 sheet of paper at a time. Put 1 sheet in so it's level with the top of the feed tray, then gently push it down 3/4 of an inch. That works for me. Good luck.
Sep 19, 2010 | Lexmark X5470 All-In-One InkJet Printer
My lexmark x5470 printer is jammed inside and I cant seem to be able to open it in order to get the paper jam out of it. Any suggestions?
You can try the following. Press and hold the check mark untill you hear the printer turning the rollers. That will cause the printer to try to feed a paper sheet. If that does not pulls the jammed paper out then you will probably have to find a way to remove maybe using some long nose pliers.
Jan 31, 2010 | Lexmark X5470 All-In-One InkJet Printer
Lexmark X5470 printer displays message "Clear paper jam, then press (check mark). There is no paper jam and it will not print with the message showing. I have cleaned the rollers but it didn't help.
try taking all of the paper out and then just print one sheet.
also make sure that it is new paper, lays flat and that you have fanned it prior to inserting it in the printer.
Jan 08, 2010 | Lexmark X5470 All-In-One InkJet Printer
Paper does not feed into lexmark X5470 all in one printer
feeding problems
not take apaper
not feed a paper
hey im tuval from israel,
first of all im sorry about my english :)
and now to the point.......
look, if you know where the feeding wheel its good (like elastic material over this wheel) , now take a"nail cleaner" (aceton)
and clean this wheel (the elastic thing), i did thet and the problem is gone!!!
after the cleanning send 15-20 empty doc to print (remember - empty, dont use you ink - you dont have to - save money), if all the paper is out from the printer,
you fix that.
i hope i help you.
hope fore replay.... :)
May 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Paper feed jamming problem
had this problem also try looking for a tiny piece of torn paper in the feed wheel and remove the snag
Aug 30, 2008 | Lexmark X5470 All-In-One InkJet Printer
Try forcing a sheet of paper or thin cardboard through the paper path in the direction the paper feeds. This may push out the jam so you can reach it.
Jul 17, 2008 | Lexmark Office Equipment & Supplies
Lexmark X5470 All-In-One InkJet Printer Logo
179 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
