Question about Element Electronics FLX3711B 37 in. LCD TV
I bought this TV for the Digital tuner,cause of the change to digital. With the old analog TV I could pick-up 7 local station,VIA ANTENNA. We went Digital and this New TV would only pick-up 1 Station,Via ANTENNA. OKAY! Thought this Digital Viewing, Receivng Signals wasn't all that it's cracked up to be.. The other day I purchased a 9" Curtis portable TV.. (ARE YOU FOLLOWING ME) Plugged it into the same ANTENNA my big TV is using,and I receive 5 DIGITAL CHANNELS over the AIR .... WHATS GOING ON???????
    Master:
  • 412 Answers
To receive Digital TV, you need a set-top box from your CABLE provider. There is no TV that will receive Digital TV directly
Posted on May 20, 2017
twitchns
  • 68 Answers
SOURCE: Channels 3, 4, 5, and 7 are mute. The mute button has no effect.
there should be an audio section of your tv
Go through each of your setting s and be sure nothing was changed. goto setup and reset to factory settings. your TV will do something funky and powercycle.
THAT should fix your problem.
if not, is your cable service through your VCR? if so, remove the vcr altogether and connect your cable services directly. All should now be a go.
Posted on Aug 26, 2009
  • 8457 Answers
SOURCE: analog to digital convertion
Yes,LCD tv have digital tuner inside.Just buy a digital antena.Plug it in the antena analog whole.Go to menu setup go down to ch.rescan should have all free air channels.
Posted on Jan 16, 2010
SOURCE: analog to digital conversion for LCD TV
Bought a conversion box!!
Posted on Feb 09, 2010
supertech6
  • 513 Answers
SOURCE: my television wont get any digital channels
I don't see anything that says this TV has a digital tuner. For the price, I doubt it does. The owner's manual will say digital tuner if it has one.
If not, you will require a cable digital box. Connect it with RGB or HDMI cables for the best picture, if you can.
Posted on Mar 30, 2010
  • 19 Answers
SOURCE: i just lost all my digital channels. The problem
this is what i can tell you your tv has 2 boards a main one and a power supply one anything that has to do with your imputs tv, av, hdmi, etc has to do the main that includes the picture going off and sound you can contact the manufacturer and tv technicians, but the only place that its going to be cheap its at www.shopjimmy.com guaranteed
Posted on Apr 13, 2010
Can't change channels stuck on 4 tried scanning it but it goes back to 4 won't change on the tv or a remote
When you run a scan the TV changes to every channel and tries to tune in a station. that is why it takes so long. If your TV is only finding channel 4, I would guess that is the only station strong enough for it to pick-up. You should check and / or replace your antenna and or antenna cable. Then re-scan the channels. with a better antenna, it should find more stations.
Most older Tube type TVs need a converter to pick-up digital TV, if you have a converter, make sure it is plugged in.
You should not be getting any stations without a digital tuner TV or a converter box.
The FCC site says this:
The FCC established September 1, 2015 as the date for the termination of all analog low-power television service. Since that date, analog television should no longer exist in the United States. Until that time, LPTV stations were allowed to continue to operate their analog facilities.
Jan 28, 2016 | Televison & Video
Have put my ariel in to tv but tv will not pick up any channels
There are a couple possibilities here. Is the antenna a digital HDTV antenna, or is it a standard analog? The TV tuner must match the antenna type. Also, if you are using an analog antenna (old style), there may not be any analog broadcast stations in your area anymore as most have gone digital.
Aug 02, 2014 | Televison & Video
Can not tune tv since change over
The KV-32FS100 only has an analog tuner (NTSC). Unless there is a low-power analog station still broadcasting in your area, you will not be able to watch OTA stations. (I've got one in my area that barely comes in.) If your local cable still sends an analog signal, you won't need a set top box to watch that subscribed service.
Otherwise, you need a set top box to watch TV. A digital to analog converter (the boxes that were available with the government coupon before the switch over) will give you over the air stations. The basic models only provide SD output; there are a few HD models available. Otherwise, you can use a satellite reciever, cable box (for digital cable service), or something like the Boxee or Sling with tuner. (There are a few different models of the Boxee; one added a tuner with a USB dongle. The newest model of the Boxee has the ATSC tuner built in.)
Note: OTA digital signal quality is either a strong enough signal for the tuner or no signal will be present. You need to point the antenna in the correct direction to receive the signal from your local transmitters. The type of antenna and its placement will also change the number of watchable channels. You can use antennaweb.org or tvfool.com to get more information. Antennaweb assumes an outdoor antenna but gives a conservative list of stations. If the signal is split to several devices, you may need an amplifier to get a watchable signal. (Sometimes amplifiers fail and you won't receive any stations, so test without the splitter or amplifier by using a direct cable to one TV.)
I hope this helps.
Oct 26, 2012 | Sony FD Trinitron WEGA KV-32FS100 32" TV
I'm trying to hook up an indoor antenna to my polaroid flm-3232 do I need a digital converter box or does the tv have the necessary components?
You have an analog TV, meaning that the tuner in your TV is analog only. You must buy a digital converter to see broadcast Digital TV via your external antenna and it will be attached to the antenna input jack or other jack depending on how it comes out of the converter.
One bit of advice, there is no such thing as a "digital" antenna, they are all analog. Even a 50 year old, outside antenna aerial that you see out in the countryside will pick up the new Digital Broadcasts to be converted by a Digital Converter and displayed on a 50 year old TV.
Oct 21, 2012 | Polaroid FLM-3232 Television
Does this product have a built in digital to analog converter?
This tv incorperates a full digital PLL tuner. It does not need a digital to analog coverter since analog signals is no longer used. All tv stations now broadcast with digital signal. It will receive local broadcast stations just connect a goood quality antenna to the tv. You will need to do a scan and the tv will store all of your local broadcasting stations within range. An outdoor antenna works best for digital signals.
Sep 13, 2012 | Samsung LN32B460 32 in. LCD HDTV
How do i cahange my reception From analog to digital?
The Dynex LCD-19-09 19in LCD Tv has a digitial tuner in it already. I would recommend doing a channel scan and make sure it is on the "Antenna" setting instead of "Cable" and let it scan for channels. You will see all the analog channels like "7", "12" if they are still broadcasting, however, if you can pick up the digital channels, it will look more like "7-1" or 12-1; 12-2 etc.". To get to this, push the "Menu" button on the Dynex remote, then arrow down twice to TV, then push the right arrow and make sure it is set at Antenna and do a channel scan. Should get you whatever digital channels are available. If the digital antenna is not strong enough, you will need to get the digital one at Wal-Mart as previously suggested and hope that will convert the analog channels in your area.
Jun 12, 2009 | Dynex DX-LCD19-09 19 in. LCD TV
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
Using an over the air antenna I get all channels but one.
I experience the same thing on a day to day basis. The key, is location of the antenna. Depending on where your antenna is located, determines if u can recieve local CBS analog v. digitial. I actually tried sticking aluminum foil to my old rabbit ear antenna legs. to my surprise, I even picked up digital channel I never knew existed. Besides, when the signal transmit in Digital, u are already prepared. Your local CBS afilliate station will be accesable on maybe 2 or 3 channels. example:
Channel 10 analog
Channel 10-1, 10-2, 10-3 digital HD will all broadcast the same programming.
hope this helps u out.
Dec 06, 2008 | Dell W4200 42 in. HD-Ready Plasma...
Element Electronics FLX3711B 37 in. LCD TV Logo
50 people viewed this question
Top Element Electronics Televison & Video Experts
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
