Question about Microwave Ovens
Bulb flickers and makes an electrical spark noise but only for around 30 seconds on starting programme
    Problem Solver:
  • 9 Answers
Is it an electrical spark noise or is it actually sparking inside your microwave oven? Watch as you heat something. This also might appear to be the bulb flickering, when it's actually a sparking. I only know how to fix it if it's an actual spark, or what might be called "arcing." This is not supposed to happen.
Inside your microwave, there is a "cover" over the area where your bulb is. If this cover has a burned place in it, or an actual hole in it, then it's your "waveguide cover." And this is the easiest thing to repair. I myself will not attempt any electrical repair, but this waveguide cover was a breeze.
You have to purchase replacement material... Then, when the replacement material arrives, remove the wave guide cover from your microwave, trace it, cut it out and put the new one in. It is very easy to fix. Sort of like paper dolls....
Google "waveguide cover" and you're on your way! IF that's the problem....
Posted on Oct 09, 2010
Panasonic NN-S563 no heat
hmmm...well..did you do a power setting? that is what is needed in the sequence just stated..try one of the presets like popcorn, to see if that works.
Oct 19, 2008 | Panasonic NN-S563 Microwave Oven
New GE coffee maker #169209 (1300 watt) 12 cup digital. House lights flicker when in hot plate warming mode. Tried on 15 amp GFI circuit and then on dedicated 30 amp #10 wired circuit -- but same...
Hi, then it might be a factory fault problem, i will advise you to call in a electrician to come and witness it whenever you put it on so that he will be able to identify weather it is the microwave's fault or an electrical fault...
Mar 11, 2010 | Microwave Ovens
Sharp Microwave Oven Model R-403kk-T
Are you talking about the light inside the microwave? The front vent I think will allow you to get to the bulb. Should be a couple of small scrrews holding the vent cover on, remove them take vent off. Start it up again and see if the light bulb wiring or socket is arcing
Sep 16, 2009 | Frigidaire FMV156EM Microwave Oven
Light bulb going out
Unplug your unit then you have to remove the cover from the microwave. Just remove the screws that are around and in the back if there are any. once you remove the cover you should have access to your bulb. Befor removing the cover just inspect the inside of the oven to make syre that ther is no access plate in there to remove the bulb. I hope this helps. Don,t forget to rate my answer, thanks.
Feb 26, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
Shuts off but everything else works
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Nov 08, 2008 | Panasonic NN-S542 Microwave Oven
1800 XL JVM1860BD - won't work
It sounds like your controller may be failing. Or it could be an electrical line problem. Any other electrical itmes giving you trouble? Has anyone measured the voltage level of your power line? It should be around 110-125 volts AC. If it's significantly lower or higher, you may have a bad connection in your breaker panel or in the wiring leading to the home.
Aug 14, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
121 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
